What vehicle and what year to find a 518 tranny?? #17782
10/19/05 01:27 PM
10/19/05 01:27 PM
Diego-Town, CA
Diego_Ted Offline OP
Diego-Town, CA
Is one year better then the other?? What should I expect to pay? Do I need to rebuild?? What performace mods should be done for the tranny to be good to about 400hp?
thx diego
Re: What vehicle and what year to find a 518 tranny?? [Re: Diego_Ted] #17783
10/20/05 10:13 AM
10/20/05 10:13 AM
Diego-Town, CA
Diego-Town, CA
Somebody!! Anybody!!
Re: What vehicle and what year to find a 518 tranny?? [Re: Diego_Ted] #17784
10/20/05 10:46 AM
10/20/05 10:46 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
518 trannys are very common in the Dodge Ram trucks.. The older ones used the 47RH (hydraulic) and the newer ones use the 47RE (electonic)...
Check out this place for all information on 518's
518 Trannys
Re: What vehicle and what year to find a 518 tranny?? [Re: Jeepmon] #17785
10/20/05 11:00 AM
10/20/05 11:00 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
i got my 518 NON lockup out of a 92 3500 van - it had a 360 in it and I believe it was a NON MAGNUM motor... they are out there...
Re: What vehicle and what year to find a 518 tranny?? [Re: DJVCuda] #17786
10/20/05 01:08 PM
10/20/05 01:08 PM
San Diego
StrokedDart Offline
StrokedDart  Offline
San Diego
Ted you know who to call, Steve Kary!!
1968 Dart
Re: What vehicle and what year to find a 518 tranny?? [Re: Diego_Ted] #17787
10/20/05 01:37 PM
10/20/05 01:37 PM
I got mine thru www.car-part.com Its a great site and easy to use basically connects you with every junk yard in the country. depending on what you plan to use your car for, a non lockup unit may be better. you can use a 727 converter which are widely available. lockup converters (performance) are scarce and expensive.
Re: What vehicle and what year to find a 518 tranny?? #17788
10/20/05 06:08 PM
10/20/05 06:08 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
IIRC, the '95 and earlier versions are the ones to look for because they are easy to wire.
The non-lockup units will have two pins (contacts) towards the back of the main case just ahead of the rear oil line port. It needs one fuse protected hot wire and one switch controlled ground wire to control OD. Mine came from a 91 Ram 5.9 Reading-bodied work truck.
The lockup units will have three pins towards the back of the main case just ahead of the rear oil line port. It needs one fuse protected hot wire, one switch controlled ground wire to control OD and one switch controlled ground wire for LU.
I think after '96, the 518s are controlled by electronics and would be hard to adapt to an older car.
Re: What vehicle and what year to find a 518 tranny?? [Re: Jeepmon] #17789
10/20/05 07:37 PM
10/20/05 07:37 PM
Detroit, MI
uwntsumrtII Offline
uwntsumrtII  Offline
Detroit, MI
on that note...APS, Martin Saine, (JPT) Jim's Performance Trans all make good trannies. i did a 518 swap into my 2000 Dak R/T. i'm gonna have JPT build it for race over this winter.
Re: What vehicle and what year to find a 518 tranny?? [Re: uwntsumrtII] #17790
10/21/05 04:11 PM
10/21/05 04:11 PM
If the plan was to cut the bellhousing off and install a JW bellhousing, would it make sense to get a trans from a diesel ?
Re: What vehicle and what year to find a 518 tranny?? #17791
10/21/05 05:06 PM
10/21/05 05:06 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
high stall torque converters are the issue with a diesel trans....IIRC a gas tc won't interchange with a diesel TC...
also, for a 518, '91-92 were non lockup, IIRC, 93-9? are the hydraulically controlled (the cutoff seems kinda unsure, could be as early as 96 (when OBDII came on the trucks) or as late as '98 (when the trucks were freshened)
2017 Grand Cherokee Overland
Re: What vehicle and what year to find a 518 tranny?? [Re: patrick] #17792
10/21/05 05:15 PM
10/21/05 05:15 PM
Aside from the converter- I could have a custom one built- would the diesel trans be a better core ? More HD parts i would think ? Remember, I'll be changing the bellhousing no matter what, it's going on a big block.
Re: What vehicle and what year to find a 518 tranny?? [Re: patrick] #17793
10/21/05 06:02 PM
10/21/05 06:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The diesel transmissions have the same input shaft and drive hub as the gas versions so, once the bellhousing is hacked off for an Ultrabell, a diesel trans will work as well as any other.
