Re: Who needs a big block ?
[Re: HotRodDave]
#1778392
03/16/15 06:33 PM
03/16/15 06:33 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
HP is what makes you go fast, you can always use gear multiplication to make TQ if you have HP.
Now that is out of the way I like SB strokers the best.
Torque is what makes you go Quick.
Steep gears can help with torque but will increase your trap RPM and make street driving more difficult. I had around 7 grand in each of the big blocks that I ran 9.80's with. Although alot of the parts were lightly used, there's no way I could have stayed with a small block and met the goals I wanted, which was a pump gas combo with some streetability and enough torque to run 9's.
When money allows I really do want to build a nasty stroker small block someday though, I especially like the extra room in the engine bay.
[Re: 1967dartgt]
#1778394
03/16/15 11:02 PM
03/16/15 11:02 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
Why? I went [Email]9.55@140[/Email] with a 422 small block that I had 10k in. I went 9.90 with a stock block and 360-1 Indy heads. I had 8500 in that motor.
You should give me hints then........! Dan
[Re: 1967dartgt]
#1778396
03/16/15 11:23 PM
03/16/15 11:23 PM
ProSport
Akron, Ohio
Why? I went 9.55@140 with a 422 small block that I had 10k in. I went 9.90 with a stock block and 360-1 Indy heads. I had 8500 in that motor.
See, you spent alot more than I did. And it needed more RPM, and more octane. I made the last 2 up, only guessing. Some of you guys have above average small blocks, it's not the norm to run that quick with a fairly low dollar small block. You really know what you're doing. Running 9's with a cheap mild big block was easy for me and I had a ton of fun doing it. Still want to do a stroker SB soon though.
[Re: ProSport]
#1778397
03/16/15 11:35 PM
03/16/15 11:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Hell.. my back up engine is a stock block 395ci W-2 that I run 9.50s in.. home ported heads and a roller cam.. the biggest price thing is the roller cam and they are that bad.. thats with a small stroker 3.79
[Re: Porter67]
#1778400
03/16/15 11:53 PM
03/16/15 11:53 PM
Posts: 12,388 Taxes & Virus's R-US, NY
Dragula
This is a good one here and good points on both sides. Ive a purpose built street car made for one thing and there is not one area I skimped on.
With that said the parts list alone is enough to make me sick and its odd how many run race blocks around here (mopar, ford and chevy) on the street and oem blocks at the strip.
I do think dollar for dollar if I had went the BB route, aftermarket block and it would have to be a long stroke BB that I would not need to spray it on a controller like I do the small block stroker.
But just like many who have been into small blocks and it seems equally with long stroke big blocks the money factor will keep me from ever changing over.
I would think only the ones who have the same model cars and as close to being done as equal money, one with a small block stroker and one with a big block stroker could give us the true answer.
So for now its just wallet vs wallet and possibly ego vs ego and a grudge match (which is fun).
Well we have been running 9's in our pump gas unported but stroked RB in the Duster....We keep the r's down and have put a lot of passes on her. Its been a great combo as I had my doubts, but it has worked really well at 735hp.
This year, I sold the little 484 Hemi in my street car and built a pump gas 605 all aluminum Hemi. I was very disappointed with it as far as performance goes. I decided to change all the things I hated about the old engine. With that said, my street car (Cuda) is only good to 10.0 and I think 850hp will put it well under that, so if things go well, it will land in the race car for a season and the 512 wedge in the street car....Take any bets what it will run if we do? Mine is 9.1ish
[Re: Dragula]
#1778401
03/17/15 12:03 AM
03/17/15 12:03 AM
Posts: 9,836 MI, usa
dvw
MI, usa
My big block has been 9.12@147 but that's at 3340lbs with Eddy carbs. At some of these lighter weights that have been posted it has been 8.10@169 with Holleys. Doug
[Re: dvw]
#1778402
03/17/15 12:18 AM
03/17/15 12:18 AM
MR_P_BODY
My big block has been [Email]9.12@147[/Email] but that's at 3340lbs with Eddy carbs. At some of these lighter weights that have been posted it has been [Email]8.10@169[/Email] with Holleys. Doug
I learned years ago that its weight to HP and also learned that its cheaper and easier on parts to build a light car... I know guys were making 800+ hp out of my type of sb but at more cubes.. I just wanted something simple and no maintenance.. thats what I had.. so if I wanted I could have gone much quicker
[Re: MR_P_BODY]
#1778403
03/18/15 09:27 AM
03/18/15 09:27 AM
ProSport
Akron, Ohio
I had the pleasure of installing a starter last night on my big block Duster. Pull steering column, remove valve cover, wrestle with starter for an hour or so just trying to get fingers in there, try to remove starter wires, wrestle new starter in there, fight wires again, install steering column, drink a cold one. 2 hour process. Anyone want to buy a healthy big block?
[Re: MR_P_BODY]
#1778404
03/18/15 09:38 AM
03/18/15 09:38 AM
Wedgeman
9.50 ! how much does your car weight ?
Dan
[Re: Wedgeman]
#1778405
03/18/15 11:29 AM
03/18/15 11:29 AM
MR_P_BODY
Dan
Thats the race car.. with me its 2400#.. race weight
[Re: Wedgeman]
#1778407
03/18/15 04:07 PM
03/18/15 04:07 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
One question has been haunting me for sometime now.....
Who needs a big block when your small block stroker makes 660 + ponies ?
Does a big block will make you go faster in the same body with more torque ?
I see here big block builds hoping to get 600-650 hp and go fast....faster than my 606 hp small block ? should I go big block to get better et's ?
I'm confused.....................
Dan best 60ft 1.30 best 1/8 mile so far 6.40 sec
because it's easier and cheaper to do with a BB especially in b-body. I'd also wager a 500ci wedge, even w/ the same HP #'s will have lots more torque and at a lower rpm. It will also require less converter and gear to do the same work. But to each his own.
[Re: mopar65]
#1778409
03/18/15 10:14 PM
03/18/15 10:14 PM
Dragula
I do I do that is if i had the money. lol so far i have been in the mid 10 with my mild stock stroke pump gas 440 in my 73 dodge dart. but there are some very empresive small blocks are here too.
Mine in my Duster is not so bad with the RB....I have fender well headers and a Magnumforce k-member....But the Hemi might route the headers that way, so I might end up in the same position at a later date.
