Re: American Power Train 5 Speed Install
[Re: 71birdJ68]
#1778075
03/14/15 01:05 PM
03/14/15 01:05 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
The number of cars that are untouched and unmolested are virtually zero at this point in the game.
Well first of all, that's absolutely false. But let's assume it were true for a minute, why not hack up the remaining uncut cars?
I went with a Passon 5 speed, I was lucky and put a couple of them on order very early on and was one of the first to receive one. What a game changer these things are! Awesome everything, 100% bolt in, 100% reversible if I ever wanted to, no cutting. Now, I realize he's having trouble filling orders on these, maybe a year out before he gets caught up, but his OD 4 speed offers almost as much performance, is also a 100% bolt in, no hacking install, it costs less, and has a shorter lead time. If you want a temporary solution it's a good way to go as well.
[Re: 71birdJ68]
#1778076
03/14/15 01:16 PM
03/14/15 01:16 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Does it bolt right in, NO., can you use any of the factory stuff, NO. Can you undo it later if you want, NO. With the Passon, you get both.
In my case, my car is an auto on the column. So even to go with a 4 speed od, technically be hacking the car according to posts here. Yes you can use the original clutch linkage, pedals etc...
To each their own, but even in my 5 speed truck, I still want to shift to a 6th gear. Now to go to a t56, that takes cutting up a car, crossmember and so on... that's one I wouldn't do to my car.
[Re: gdonovan]
#1778079
03/14/15 01:52 PM
03/14/15 01:52 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Either way you are cutting the car.
No, one is repairing a car, the other is modifying it. But we can just agree to disagree, no big deal.
[Re: ScottSmith_Harms]
#1778081
03/14/15 02:04 PM
03/14/15 02:04 PM
Posts: 235 ga
ringo440
ga
O.k. I just talked with the owner of the car and he said he was going to talk to APT Monday and see if he could return it. If they will not take it back he said still wants to get rid of the setup, even if he has to take a hit on it.He was under the impression that there was no cutting involved when he purchased it. He wants to go with passion o.d. Thanks to everyone who responded to this post,not everyone agrees, But each reply was a education, This setup was not the right one for this car, But if I was building resto mod this sound like a great setup it is just not for a finished car. Thanks
#1778083
03/14/15 02:08 PM
03/14/15 02:08 PM
Posts: 4,451 Morristown Tn.
71birdJ68
Morristown Tn.
I have watched this for a while now about the modern 5/6 speed trans installs, and have come to the conclusion that what I have said about cutting a nice floor aside, a lot of people don't have either the skills, or the tools, or the facilities, and everything else to do one of these installs. From what I have read on here, there is always something else that's needed that the installer wasn't told about, or sold in the kit that they then have to buy, and try to make it fit. The whole thing is a pile of parts from different kinds of cars that we are trying to shoe horn into cars that they weren't designed for. And that folks is why the Passon units rule, it's the right thing for about 99% of us, EVERYTHING WORKS LIKE IT CAME IN THE CAR.
[Re: 71birdJ68]
#1778085
03/14/15 08:12 PM
03/14/15 08:12 PM
Posts: 18,157 Mass
DAYCLONA
Mass
While I can agree with most of your comment, and the OP is better off in this case supplying either a Passon 3spd OD (modded 883), or Passon's new 4spd OD (5spd) for his customer seeing that the car cannot be modified to accommodate a TKO install
However regarding the TKO kits as being a bunch of parts "from other cars" is a little misleading, as the Tremec TKO is a stand alone offering from Tremec, it's never been offered in a production vehicle, it's often confused as being the same as a Tremec T5 or Tremec 3550 mfg production series transmission, the kit components offered by the various companies are often comprised of proprietory custom made bellhousings, shifters, linkage, crossmembers, etc, etc, designed for the applied applications, not a bunch of "parts from other cars"...a good segment of auto enthusiast want a TKO 5 spd installation, as evident by the 10's of thousands of TKO units sold since their inception in the early 2000's....
IMHO the 5spd thing has been "played out", yes there's still a need for them, but after driving 5 sds for many years, the natural progression is the T56 6 spd for an even deeper OD, the Mopar crowd has always been late to the table, or slow to accept change, but at least there is a multitude of offerings in the OD market now to satisfy the requirements of the many different needs/views required
Mike
[Re: DAYCLONA]
#1778086
03/14/15 10:30 PM
03/14/15 10:30 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Mike I was referring to Supra transmissions being used with Dakota bellhousings or the less than desirable Dakota/Ram NP3500.
People have been trying to stuff 5-speeds into Mopars before Keisler was offering kits.
"I think its got a hemi"
[Re: Supercuda]
#1778091
03/17/15 01:02 AM
03/17/15 01:02 AM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I never dealt with Passon but I bought a T56 kit from American Powertrain for my 56 Dodge and am very happy with the quality of the kit, responsiveness to my questions and overall experience. I used a lot of heat and a big hammer to clearance the floor without cutting.... but most cars wont ever be stripped to the bare shell which made that possible for me. Call American Powertrain they will have the answers about how to get it installed.
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: Supercuda]
#1778092
03/17/15 01:51 AM
03/17/15 01:51 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Wide gear ratio or a gear ratio comprimize is all that's left for you.
Go look at the specs of the Passon OD conversion gearset then come back and comment on compromises and wide gear ratios.
In a nutshell:
Passon's 5 speed and a standard 833's 1-4 gears are almost identical ratio's, making the 1-2 shift RPM drop the same - from 6000 to about 4400.
Both the TKO's 3.27-1.98 1-2 ratios and the Passon Hemi 4 speed O/D's 2.66-1.59 ratios drop the RPM's on the shift from 6000 all the way down to about 3600. The 2-3 on the TKO drops to 4000, and the 3-4 to about 4400 - the Passon 2-3 to 3800.
So, by the specs - both the TKO and the Passon 4 speed O/D are wide ratio transmissions and a compromise. If you need closer ratios - stick with and 833, or wait on your Passon 5 speed.
Personally, I think both the TKO and the Passon Hemi O/D 4 speed's 6000-3600 RPM drop is an excessive drop for most small blocks, and marginal at best for a big block. The TKO's advantage is a lower 1st gear, and less RPM drop on the 2-3 and 3-4.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#1778093
03/17/15 02:13 AM
03/17/15 02:13 AM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Well, the numbers don't lie, but your ability to shift it quickly is also a factor in maintaining RPMs and in that case the Passon is the hands down winner.
#1778094
03/17/15 06:28 AM
03/17/15 06:28 AM
Evil Spirit
Newport, Mi
There's only so much that can be done to a transmissions hard parts to make it shift smoothly or fast. But when a trans shifts, the countershaft, pilot shaft, and clutch disc must all be slowed down until the shift ring and syncro speeds are even and the next gear can be engaged. Lighter parts help, but this FACT is an inherent flaw in transmissions that have wide ratios and large RPM drops between gears - it simply takes longer to slow the disc down to 3600 than it does to 4400. This is why a trans may shift smooth as butter at 4500 and horrible at 6500. Wide ratio's are also harder on the wear parts - again, because they have to work harder to slow down the front of the trans.
