Engle Roller Lifters #1777355
03/11/15 08:32 PM
03/11/15 08:32 PM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
Hi
I was wondering what the difference between small block and big block Engle roller lifters would be?
I have a set of small block lifters and was wondering if they could be used in a big block . Tie bars ? Anybody...................
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Engle Roller Lifters [Re: chryco] #1777356
03/11/15 09:57 PM
03/11/15 09:57 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
the center to center may be differant.... stock RB stuff is 1.8" center to center
Re: Engle Roller Lifters [Re: chryco] #1777357
03/11/15 10:47 PM
03/11/15 10:47 PM
Cab_Burge Online work
Cab_Burge  Online Work
Are your tybars captured or removeable and changeable? If changeable try them in your block and see if the ones(tybars) on there will work or not. Both motors use the same diameter roller lifters, if there captured, not changeable, call Engle562-232-7079 and ask them
Re: Engle Roller Lifters [Re: chryco] #1777358
03/11/15 10:56 PM
03/11/15 10:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've used BB lifters in a SB and if I recall the
spread is very close but the shape of the bar is way
different to clear... I ones I used I cut the rivets
loose and changed the tie bar then welded the rivets
back on
Re: Engle Roller Lifters [Re: MR_P_BODY] #1777359
03/13/15 10:14 AM
03/13/15 10:14 AM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
Thanks all . I don`t currently have a BB to check m just wondering.
chryco
