Compressor is avail thru the aftermkt,,,
as is the condensor, I used both when I did this one.
I got lucky and found an NOS receiver dryer, and nos clutch and coil assy for the compressor.
The condensor fit like a glove.
There is a repop evaporator and heater coil assy,,but I've heard they dont fit very well. So I had both ck'd and redone locally
Lines themselves I had new hoses replaced locally as well.
If you need any of the lines, good luck,,,,, they are one year only and are big block only.
I've got more pics if you need them
