Brakes - Help Me Choose #1777162
03/11/15 06:26 PM
03/11/15 06:26 PM
Norcal
W
Wildjones Offline OP
W
Norcal
Hey guys,
I am in the middle of building/rebuilding my '70 Cuda. Originally I was going for straight line fast, but recently decided I wanted to make it a bit of a corner carver, or as much as an old car can anyways. I will have a 496 up front, so it won't be as nimble as some of the small block cars.
I have gathered up all the typical handling parts for the front: 1.12 torsion bars, 1.25 sway bars, Welded K, braced LCA, Hotchkis UCAs, etc, but I still have stock 10.95 discs and drums out back.
I talked with Cass @ DoctorDiff and he was super helpful, but I am still torn between his Stage 3 and Stage 4 kit. The reality of it is I likely won't make it out to a track or autocross event all that much. Most of my time driving the car will likely be out on the street or on the twisty back roads, which seems like the Stage 3 is more than adequate for my needs.
Either way, my 15s won't fit, so I am not held back by wheels. The Stage 4 looks killer sitting behind an 18, but is it worth the extra cash? The difference in price is 2/3 the cost of new rear leafs, which I still need to buy, among a still pretty long list of parts. I know the Stage 3 is likely adequate for my needs, but I figured I would consult the gurus here in this sub before pulling the trigger.
Thanks!
Re: Brakes - Help Me Choose [Re: Wildjones] #1777163
03/11/15 06:33 PM
03/11/15 06:33 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
I don't know the diff. so any chance of listing the differenses? Yes I'm too lazy today to look at Cass's web site, am working on boat accessories, and watching tv.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Brakes - Help Me Choose [Re: amxautox] #1777164
03/11/15 06:41 PM
03/11/15 06:41 PM
amxautox Offline
amxautox  Offline
The info on the stage 3 shows it to be more than great for your intended use.
BUT! If in the future you get the autocross bug seriously, the stage 3 will be fine, but of course the stage 4 will be better. So, will you ever get 'the bug'?
Tom
author unknown
Re: Brakes - Help Me Choose [Re: amxautox] #1777165
03/11/15 06:42 PM
03/11/15 06:42 PM
Norcal
W
W
Norcal
This might help: http://www.doctordiff.com/blog/documentation/disc-brake-kit-comparison/
The stage 4 kit sounds like a replacement to the viper kit. Both stage 3 and 4 have the same rotor, but they have different calipers. The stage 3 is a Cobra based caliper. The stage 4 caliper sticks out a bit further which could cause headaches when fitting wheels.
Seems like most folks here run the stage 4 or Viper or Amg swap. I would just like some advice is all.
Re: Brakes - Help Me Choose [Re: Wildjones] #1777166
03/11/15 07:08 PM
03/11/15 07:08 PM
Illinois/Tennessee
Murfman1967 Offline
Murfman1967  Offline
Illinois/Tennessee
I'm leaning towards the Viper brackets and 11.75" C body rotors unless someone tells me its a bad idea... I already have 10" drum spindles on the car, so it seems like a viable choice.
99 Ram 2500 QCSB V-10 Stepside
72 Magnum Marine 27' Twin 5.9 Magnums
70 A-100 Sportsman /6
67 Coronet R/T 440
66 Charger 470
53 Plymouth Suburban flathead T-5
Re: Brakes - Help Me Choose [Re: Wildjones] #1777167
03/11/15 07:17 PM
03/11/15 07:17 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
The choice was simple for me as I got the biggest brake system I could afford, Cass's Stage 4 non-drilled
With the weight of our cars you can never have too much brakes
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Brakes - Help Me Choose [Re: RylisPro] #1777168
03/12/15 04:38 AM
03/12/15 04:38 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Stage 4+ for me.
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: Brakes - Help Me Choose [Re: 68cuda440] #1777169
03/12/15 04:49 AM
03/12/15 04:49 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Stage 4+ for me.
Where did you get those rotors from? After my drilled rotors get worn out or start to crack, I'm going to be looking for a slotted/non-drilled rotor.
Re: Brakes - Help Me Choose [Re: 68cuda440] #1777170
03/12/15 10:42 AM
03/12/15 10:42 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Stage 4+ for me.
Hey! Those are the aluminum hat rotors I wanted to buy,
but Cass never sold me a set.
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Brakes - Help Me Choose [Re: RylisPro] #1777171
03/12/15 04:13 PM
03/12/15 04:13 PM
Norcal
W
W
Norcal
Thanks for everyones opinion. I opted for Stage 3 for now. The extra cash saved will go towards getting the car back on the road for now. In the future I would love to be able to autocross the car and take it to track events, but until then I know I will need to spend a lot of time dialing everything in, even after everything is put together. I hate buying things twice though.
I almost caved and went Stage 4, purely because of aesthetics.
Re: Brakes - Help Me Choose [Re: RylisPro] #1777172
03/12/15 05:43 PM
03/12/15 05:43 PM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Cass AKA Dr Diff. They were a added cost option on the Stage 4 kit. They are Baer rotors. I asked they be slotted but not drilled, took a little longer to get. The other "option" I opted for was the aluminum hubs. The aluminum hubs swallow up a 2" stud, so I have since swapped them out to 3".
I'm sure if you call him and give him your credit card info he can fix that for you.
Re: Brakes - Help Me Choose [Re: 68cuda440] #1777173
03/12/15 06:15 PM
03/12/15 06:15 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I have called him enough times that I'm sure he has it memorized haha!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Brakes - Help Me Choose [Re: Wildjones] #1777174
03/12/15 06:36 PM
03/12/15 06:36 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Only 2 of us have done AMG swaps. I think a couple more used Andy F's Mercedes rotor kit.
I think the Cobra calipers are a great way to go. They will do everything a street car needs and are easier to fit under a set of wheels.
- Stu Harmon
Re: Brakes - Help Me Choose [Re: feets] #1777175
03/12/15 08:41 PM
03/12/15 08:41 PM
Illinois/Tennessee
Murfman1967 Offline
Murfman1967  Offline
Illinois/Tennessee
What is the consensus on the Dr Diff Viper caliper kit using c body 11.75 x 1.25 rotors?
67 Coronet R/T 440
66 Charger 470
Re: Brakes - Help Me Choose [Re: feets] #1777176
03/12/15 10:20 PM
03/12/15 10:20 PM
Winnipeg, Manitoba, Canada
JRC Offline
JRC  Offline
Just wondering what Mercedes rotors guys are using, all the ones ive found are a 5x112 bolt pattern? Id think the newer dodge rotors at 5x115 would be a closer fit no?
Re: Brakes - Help Me Choose [Re: JRC] #1777177
03/12/15 10:33 PM
03/12/15 10:33 PM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
The Mercedes rotor is what he uses for the Stage 4 kit. He redrills it to a 5x114.3.
Re: Brakes - Help Me Choose [Re: feets] #1777178
03/13/15 01:39 AM
03/13/15 01:39 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
One of which was on a Holden..
Re: Brakes - Help Me Choose [Re: OzHemi] #1777179
03/13/15 08:28 AM
03/13/15 08:28 AM
The Netherlands, OV
dickdale Offline
dickdale  Offline
The Netherlands, OV
I'm in the process of doing a Brembo ZR/Zl18, 6 piston caliper swap...
Using the Dr.Diff hubs, modified Mercedes 13" rotors, 72 disc brake spindle or the drum brake spindle. Haven't figured it out yet...
I have to make a bracket like this one:
Back on topic! I think the Stage 4 kit is the best way to go...
Re: Brakes - Help Me Choose [Re: dickdale] #1777180
03/13/15 04:11 PM
03/13/15 04:11 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The disc brake spindle will likely offer better solutions.
Those calipers are going to be tought to mount either way. Luckily, the 8 piston AMG calipers I used had a removable bracket that allowed a radial mount.
- Stu Harmon
