electric fan #177705
12/29/08 09:01 AM
12/29/08 09:01 AM
Minnesota
skep419 Offline OP
skep419  Offline OP
Minnesota
is a 16" spal 2350 cfm puller fan big enough? 69 dart 360
Re: electric fan [Re: skep419] #177706
12/29/08 10:13 AM
12/29/08 10:13 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Some consider Spal fans as the best available. It should be fine if you have a good radiator, a complete well-sealed shroud and wire it correctly using quality relays, fan controller and thermostat installed near the hot water "outlet" of your engine (not at the bottom of your radiator). Spal has a nice variable thermostat that helps a lot and also extends the life of your fan.
Re: electric fan [Re: jbc426] #177707
12/29/08 11:59 AM
12/29/08 11:59 AM
Andrewh Offline
Andrewh  Offline
I agree, spal has the best reputation for aftermarket fans, but I have to say they don't really pull enough air compaired to OEM ones.
For the price, it is a bad deal too imo.
Do a search, there are at least 20 posts on factory fans you can pull out of the yards that work with 22 inch and 26 inch rads for any car.
Any of them will pull more air than the spal, and be a qtr or less of the price.
Some are even half the price new if you need to go that route.
Re: electric fan [Re: Andrewh] #177708
12/30/08 03:26 PM
12/30/08 03:26 PM
Minnesota
skep419 Offline OP
skep419  Offline OP
Minnesota
i picked it up used for 30 bucks
hoping it will keep it cool with out a special shroud
Re: electric fan [Re: skep419] #177709
12/31/08 01:18 AM
12/31/08 01:18 AM
I've got a built 360 with a 26" aluminum radiator. I put a 16" spal puller with no shroud and it cools fine. Engine never gets hot in summer traffic driving in San Antonio. It is loud. Turns a few heads when it kicks on while sitting in traffic.
