Page 2 of 3 1 2 3
Re: Which automatic shifter are you using !!?? [Re: an8sec70cuda] #1776745
03/11/15 10:19 AM
03/11/15 10:19 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
PPP because you have options on set up. I like to push on the upshift and they can do that with a reverse pattern valve body.
"Just a Bracket car dressed up like a streetcar"
Re: Which automatic shifter are you using !!?? [Re: an8sec70cuda] #1776746
03/11/15 12:05 PM
03/11/15 12:05 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Hurst 1/4 stick...b/c I hate ratchet shifters.
That's what I would use if I ever parted ways with my cheetah, I feel the same about ratchet shifters.
68 Barracuda Formula S 340
Re: Which automatic shifter are you using !!?? [Re: Bad340fish] #1776747
03/11/15 12:25 PM
03/11/15 12:25 PM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
B&M Pro Stick for the same reason in the aspen. ^^^^
Dads 67 has the stock shifter in it still with rmv.
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: Which automatic shifter are you using !!?? [Re: Bad340fish] #1776748
03/11/15 12:30 PM
03/11/15 12:30 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I have a kilduff lightning rod in one truck and the column shifter in my other one. While the lightning rod is gimicky (fake lenco) it works awesome for what I do, mud bogging.
Re: Which automatic shifter are you using !!?? [Re: CTD5.9] #1776749
03/11/15 01:31 PM
03/11/15 01:31 PM
jersey
Spaceman Spiff Offline
jersey
Factory push buttons. Reverse manual valve body.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Which automatic shifter are you using !!?? [Re: Spaceman Spiff] #1776750
03/11/15 01:46 PM
03/11/15 01:46 PM
Super Scamp Offline
Super Scamp  Offline
PPP 3 speed in the Challenger and Stealth black Pro Bandit 2 speed in the Scamp. Both great shifters. Both also air shifted
Just One Man's Opinion Mopar Mafia Racing
Re: Which automatic shifter are you using !!?? [Re: RAY1969CARS] #1776751
03/11/15 02:33 PM
03/11/15 02:33 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
PPP, I like the rear entry cable configuration. It eliminates the routing issues around the headers & starter, much easier to adjust.
Re: Which automatic shifter are you using !!?? [Re: Super Scamp] #1776752
03/11/15 02:37 PM
03/11/15 02:37 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Is a rear exit shift cable the best setup for a street car with full exhaust?
Re: Which automatic shifter are you using !!?? [Re: Lee446] #1776753
03/11/15 02:56 PM
03/11/15 02:56 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
ANY Mopar benefits from a rear exit shifter cable IMO.
Clearing the starter, header and torsion bar can be a real challenge with the front exit cables!
Re: Which automatic shifter are you using !!?? [Re: RAY1969CARS] #1776754
03/11/15 04:44 PM
03/11/15 04:44 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Hurst Promatic 2.........stupid simple.
Re: Which automatic shifter are you using !!?? [Re: GY3] #1776755
03/11/15 05:00 PM
03/11/15 05:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
... I have to rap the shifter cable with high
temp covering just to make sure it doesnt burn.. no
big deal.. but if I could get a rear exit on the
pro ratchet that would be the ultimate ... JMO
Re: Which automatic shifter are you using !!?? [Re: MR_P_BODY] #1776756
03/11/15 05:14 PM
03/11/15 05:14 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Wrapped mine for sure and did a little creative bending of the bracket during install to keep it away from heat and redirect it's path.
Too bad no one makes an aftermarket setup similar to a slapstick with an adjustable metal rod instead of a cable!
Re: Which automatic shifter are you using !!?? [Re: Thumperdart] #1776757
03/11/15 05:22 PM
03/11/15 05:22 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Ran one in the Mirada.... worked fine. Bought one for the Duster......nothing but problems. Swapped shift arms between the cars.... Same crap. Something was amiss on it internally. Chit canned it.
Re: Which automatic shifter are you using !!?? [Re: Super Scamp] #1776758
03/11/15 05:22 PM
03/11/15 05:22 PM
CA.
RAY1969CARS Offline OP
CA.
What doz one of those bad boys go for ??? 400.00
Re: Which automatic shifter are you using !!?? [Re: RAY1969CARS] #1776759
03/11/15 05:23 PM
03/11/15 05:23 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
better sit down son.....
Re: Which automatic shifter are you using !!?? [Re: J_BODY] #1776760
03/11/15 05:25 PM
03/11/15 05:25 PM
CA.
CA.
Lolol no air shifter lololo
Re: Which automatic shifter are you using !!?? [Re: J_BODY] #1776761
03/11/15 05:34 PM
03/11/15 05:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I never cared for that PPP shifter... I could make
that in my shop... 2 panels of alum with a arm.. no
thanks.. but I know some guys like it
Re: Which automatic shifter are you using !!?? [Re: MR_P_BODY] #1776762
03/11/15 05:40 PM
03/11/15 05:40 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
Well I was going to put a B&M Pro Ratchet in my GTX build but now I am leaning towards the PPP. The rear exit is too good to pass up.
How do you even put a front exit cable with a CSR shield? I have a Cheetah in my race car with the rear entry and it is wonderful to have the rear entry, but the Cheetah is not a street shifter.
Re: Which automatic shifter are you using !!?? [Re: RAY1969CARS] #1776763
03/11/15 05:41 PM
03/11/15 05:41 PM
Morrow, OH
Morrow, OH
$490 delivered for the better one without air shift.............
Re: Which automatic shifter are you using !!?? [Re: markz528] #1776764
03/11/15 05:53 PM
03/11/15 05:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I burnt 1 shifter cable using the pro ratchet.. that
was the very first cable.. it was a bit short and I
didnt cover it.. I was being brave.. since then I
use a longer cable and I DONT use the heavy duty one..
they are a lot stiffer and harder to bend to clear
things... but I heat wrap it just to be sure... never
burnt up another... I'll wrap it just so I can use
the shifter I like... this cable has been in there
14 years now
Page 2 of 3 1 2 3
