Re: Need help finishing off inside of enclosed car trailer [Re: Bigbeep] #177576
12/30/08 09:46 AM
12/30/08 09:46 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
What did you use for trim on the floor, ceiling and top of carpet?
I reused the trim at bottom of wall/floor transition. Top of carpet I bought trim at home depot in the flooring dept. where I got the linoleum.
Do you glue the carpet on? If so, did you just use liquid nails?
Yes it is carpet glue that comes in 2-3gal buckets. Apply glue to area with notched trowel, then I would stick the carpet on and staple the top edge to prevent any movement while glue sets up. Apply trim.
Re: Need help finishing off inside of enclosed car trailer [Re: StrokedW7] #177577
12/30/08 09:53 AM
12/30/08 09:53 AM
San Diego CA
65 Hemi Offline
65 Hemi  Offline
San Diego CA
I aslo wondered if there wouldnt be some paint that I could use on the floors that would work or what about something like Rhino lining? Just thinking out loud.
Steve
I work for Rhino Linings and it is a bare to clean on an old floor if you have a oil leak. I personally would use the garage floor coating from Home Depot or U Coat It.
Re: Need help finishing off inside of enclosed car trailer [Re: 65 Hemi] #177578
12/30/08 10:28 AM
12/30/08 10:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Steve
This was the reason I put the diamond plate down
on the floor, you dont have to worry if the paint
will stick and also the plate is easy to clean even
if you had a oil leak(blown engine)
Re: Need help finishing off inside of enclosed car trailer [Re: MR_P_BODY] #177579
12/30/08 11:04 AM
12/30/08 11:04 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Steve...whats up??
Whats with the trailer?
Are you actually going to take the car somewhere to race it??
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Need help finishing off inside of enclosed car trailer [Re: B3422W5] #177580
12/30/08 05:21 PM
12/30/08 05:21 PM
Kalamazoo, MI
StrokedW7 Offline OP
Kalamazoo, MI
Steve...whats up??
Hey... No comments from the peanut gallery!!!
Hope things are going well and... congrats on engagment.
Steve
Steven M. Hamacher, CPA, MST
For ALL your tax, accounting, and payroll needs
www.Kalamazoo-CPA.com
Re: Need help finishing off inside of enclosed car trai [Re: MegaDart] #177581
12/30/08 10:25 PM
12/30/08 10:25 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I put some pics of mine...
I ordered it with cabinets/work bench,,floor treatment,,and wall/ceiling covering...
I like the flooring,,,kinda marble like stuff,,linoliem ?,,,wipes up easy,,,
I have since put down some more diamond plating running into the trailer,,,for the tires so they dont chew up the flooring ,,,
Also put in a S4000 winch,,and a I-Home(25$) on ebay,,,so i can hear the announcer,,,and play my ipod...
Re: Need help finishing off inside of enclosed car trai [Re: 69CHARGERMD] #177582
12/31/08 02:27 AM
12/31/08 02:27 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Looks like 69Charger and I have similar tastes. I too have a Warn S4000 winch, but I went ghetto with the old boombox. Anyway here is my new one..
My old trailer I carpeted the inside floors. Actually I think I prefer the carpet to the linoleum I currently have. I was going to go with rubber coin but have a couple of buddies who have had it come up. On my wood floor I used some Home Depot trim on the bottom and for any entry point we simply used some aluminum angle.
Re: Need help finishing off inside of enclosed car trai [Re: Al_Alguire] #177583
01/02/09 12:11 PM
01/02/09 12:11 PM
Kalamazoo, MI
Kalamazoo, MI
Looks like I am also going to have to replace a couple of the exterior panels. He ran into them with his motorhome. Anyone ever done this? Should I just take it back to the factory and have them fix it? Any idea what the aluminum costs to fix? I have two aluminum panels and one diamond plate panel on the front to replace.
Steve
Re: Need help finishing off inside of enclosed car trai [Re: StrokedW7] #177584
01/02/09 04:00 PM
01/02/09 04:00 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I'd be interested in knowing how hard/costly it is to replace an aluminum panel...
