R1 block - solid mounts or motor plate #1775664
03/09/15 03:58 PM
03/09/15 03:58 PM
indianapolis, in
rt1976 Offline OP
rt1976  Offline OP
indianapolis, in
I'm currently building a 66 cuda vintage drag car with r1 block and jerico 4 speed. Car will have a 12 point cage. Inner fenders and a frame have been replaced with 2x3 rails. Engine will be n/a and hopefully around 600 hp (goal is low 10s). Initial plans were to use solid stock style mounts on the engine and a rubber trans mount. I was wondering if I should upgrade to a front / mid plate combo? Or is the r1 stout enough to use the ears on the block?
Re: R1 block - solid mounts or motor plate [Re: rt1976] #1775665
03/09/15 04:35 PM
03/09/15 04:35 PM
AndyF Offline
AndyF  Offline
Go high tech - two piece timing cover with motor plate and remote water pump. It will look sharp!
http://arengineering.com/products/sb-timing-chain-cover/
Re: R1 block - solid mounts or motor plate [Re: rt1976] #1775666
03/09/15 04:47 PM
03/09/15 04:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The front and mid plate help stiffen the chassis..
keep the rubber trans mount but add a engine limiter
Re: R1 block - solid mounts or motor plate [Re: MR_P_BODY] #1775667
03/09/15 08:48 PM
03/09/15 08:48 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
For the record, lots of people out there going very fast with a motor plate, limiter, and stock trans mounts.
Re: R1 block - solid mounts or motor plate [Re: SpareParts] #1775668
03/09/15 09:43 PM
03/09/15 09:43 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I am running solid motor mounts and a rubber trans mount and a small block stock block making over 600 hp.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: R1 block - solid mounts or motor plate [Re: D-50] #1775669
03/09/15 09:45 PM
03/09/15 09:45 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
More room for headers with a motor plate.
Re: R1 block - solid mounts or motor plate [Re: tubtar] #1775670
03/09/15 11:53 PM
03/09/15 11:53 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I find my cars with motor plates makes it way easier to r/r the engine.
Re: R1 block - solid mounts or motor plate [Re: J_BODY] #1775671
03/10/15 12:11 AM
03/10/15 12:11 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I run stock motor mounts and poly trans mount. Also have mid plate.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: R1 block - solid mounts or motor plate [Re: tubtar] #1775672
03/10/15 01:41 AM
03/10/15 01:41 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Why ? Or do you Mean for the mid plate.
Re: R1 block - solid mounts or motor plate [Re: fishy340] #1775673
03/10/15 10:52 AM
03/10/15 10:52 AM
indianapolis, in
rt1976 Offline OP
rt1976  Offline OP
indianapolis, in
Thanks for the help. I'm getting ready to put the engine and trans between the frame rails for mock up. I'll get a better visual on how everything is laying out.
1967dartgt - I was thinking about doing it the same as you. Solid factory up front with a mid plate. Any pics of your set up?
Car is being built to race at vintage drag events so it sort of needs to look the part as well. I love that two piece timing cover but modern ele water pumps aren't accepted.
Re: R1 block - solid mounts or motor plate [Re: fishy340] #1775674
03/10/15 11:05 AM
03/10/15 11:05 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Just more flexibility in where you route the tubes.....but I had to build mine.
Store boughts won't have that problem , but not a lot of choices for store bought headers that don't require compromise some where.
Re: R1 block - solid mounts or motor plate [Re: rt1976] #1775675
03/10/15 09:31 PM
03/10/15 09:31 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Here a pic.
Re: R1 block - solid mounts or motor plate [Re: 1967dartgt] #1775676
03/10/15 09:34 PM
03/10/15 09:34 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Another.
Re: R1 block - solid mounts or motor plate [Re: rt1976] #1775677
03/10/15 09:47 PM
03/10/15 09:47 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
From the front.
Re: R1 block - solid mounts or motor plate [Re: 1967dartgt] #1775678
03/11/15 12:20 AM
03/11/15 12:20 AM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Brad, Quit teasing me. My eyes hurt from trying to see your K-Frame
[img] [/img]
