70 Challenger sway bar #1775617
03/09/15 02:55 PM
03/09/15 02:55 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
Did all models come with a front sway bar? If not are there provisions to add one? thanks
Re: 70 Challenger sway bar [Re: dan9] #1775618
03/09/15 03:06 PM
03/09/15 03:06 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Not all models had them. The base cars 318s etc.. usually are the ones without. Firm Feel as well as others will sell swaybar kits to retrofit their to those models. Might require some slight modification to the lower control arms. Even better would be to get some arms from a swaybar equipped model with the tabs already in place.
Re: 70 Challenger sway bar [Re: 469runner] #1775619
03/10/15 12:15 PM
03/10/15 12:15 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
Thank you
Re: 70 Challenger sway bar [Re: 469runner] #1775620
03/10/15 01:07 PM
03/10/15 01:07 PM
Georgia
Steve Bryant Offline
Georgia
Every once in a while you can find some beat up control arms on Ebay that has the sway connectors. You can cut them off or restore 'em and then you have a factory set.
My 318 Barracuda did not have bars or the tabs for the bars but it does now and I was shocked at how better it handles.
Re: 70 Challenger sway bar [Re: Steve Bryant] #1775621
03/10/15 01:54 PM
03/10/15 01:54 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
Thank you. Mine also was a 318 car. I was wondering if it was noticable with that addition.
Re: 70 Challenger sway bar [Re: dan9] #1775622
03/10/15 04:32 PM
03/10/15 04:32 PM
Georgia
Georgia
Yes, instantly noticeable. I rebuilt my entire suspension and it felt good but not great. As soon as I put the sway bar on the car every turn felt smoother. Even the gradual turns into the neighborhood are smooth and well-controlled and without any kind of front-end tilting or leaning.
Re: 70 Challenger sway bar [Re: Steve Bryant] #1775623
03/10/15 07:16 PM
03/10/15 07:16 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
You can get Hotchkis weld on sway bar tabs on Summit Racings web site.
Or, most aftermarket bars come with tabs to mount them off the lower shock mount.
