ring end gap/ how much is too much? #1775264
03/09/15 08:46 AM
03/09/15 08:46 AM
ILLINOIS
V
volaredon Offline OP
V
ILLINOIS
putting together a .030 over 360 for a daily driver Ramcharger, LA block, Magnum heads, 4 barrel carb, Speed Pro Hyper pistons,(#405CP)
Mahle Moly ring set. Out of the box, the rings were tight/ .013-.014 was typical, file fit them, instructions with rings said that .016 was minimum allowable, though I had read somewhere (here, I thought) about having to run a larger ring gap with hyper pistons than stock cast.
Got all of them to .022/.023 except for one ring, had my son helping me measure and file, I let him file the last few cylinders' worth of them while I measured, and we have one top ring that he over did a bit, somehow that one wound up at .032. Are we screwed, having to buy another set of rings to replace that one?
Re: ring end gap/ how much is too much? [Re: volaredon] #1775265
03/09/15 10:57 AM
03/09/15 10:57 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the larger top ring gap is for KB hyper pistons due to the location of the top ring...as being higher on the pistons...
the speed pro or seal power pistons use standard ring gaps for their bore sizes.
Tony
70 AARCuda Vitamin C
Re: ring end gap/ how much is too much? [Re: volaredon] #1775266
03/09/15 04:25 PM
03/09/15 04:25 PM
I've seen many NOS racers use .050 or larger on top ring gaps with no problems Is that ring a top or second ring? If second I wouldn't be a bit concerned on it If it's a top ring put it in the #7 or #8 cylinder, they run the hottests of all the cylinders Either way it isn't a deal breaker in either location
Re: ring end gap/ how much is too much? [Re: volaredon] #1775267
03/09/15 05:17 PM
03/09/15 05:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You can get 1 set if you call the company... .010 is
a bit much on the top ring... if your not in a hurry
to put it together I would call for a single set...
that would put your mind at ease... JMO
Re: ring end gap/ how much is too much? [Re: MR_P_BODY] #1775268
03/09/15 09:58 PM
03/09/15 09:58 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
It won't bother a thing. Ring gap is way overrated. If the ring seals to the cylinder wall and the piston groove that is the secret. Hypers need the extra gap to keep the ends from butting(VERY BAD). Educate yourself here: http://www.diagnosticengineers.org/journal_%20articles/Ring%20Gaps%20vs%20Knowledge%20Gaps.php
Doug
Re: ring end gap/ how much is too much? [Re: dvw] #1775269
03/09/15 10:24 PM
03/09/15 10:24 PM
ILLINOIS
V
V
ILLINOIS
interesting read. It is a top ring, and according to the box the top rring is "steel" not listed as "cast" like most. 2nd ring is moly in the set.
Re: ring end gap/ how much is too much? [Re: volaredon] #1775270
03/09/15 10:40 PM
03/09/15 10:40 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Most sets will be a moly top, cast second. The moly ring will have a semi shiney silver face, the cast will be dark gray.
Doug
Re: ring end gap/ how much is too much? [Re: dvw] #1775271
03/10/15 08:38 PM
03/10/15 08:38 PM
ILLINOIS
V
V
ILLINOIS
Doug
Yup when we initially put them in, we switched the 1st and 2nd rings, going by the cross section views provided with them, did not initially see the markings on the box end tabs/ we did get all the dots "up" motor still on stand, short block not quite complete, my son is buying parts as his CC will allow ("student card" not much of a ceiling) between Summit and feebay. just got the cam today via the Brown truck, We are going with a COMP 260H, but I made him spend the extra to buy it "nitrided" because of todays (commonly available) oils.. an off the shelf cam suddenly becomes a "custom" because of 1) the nitride treatment and 2) It's a mopar not a Shivvy or Furd.
Summit carries already nitrided "commonly sold" COMP cams for the other 2 companies but not for Mopar. $180 cam n lifter kit becomes a $330 cam n lifter kit... for Furd and Shivvy it would have been only $30-40 more NOT $150.
Re: ring end gap/ how much is too much? [Re: volaredon] #1775272
03/10/15 11:38 PM
03/10/15 11:38 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Take it slow. Ask questions. Make sure everything has clearance. Enjoy.
Doug
Re: ring end gap/ how much is too much? [Re: MR_P_BODY] #1775273
03/11/15 03:28 AM
03/11/15 03:28 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Re: ring end gap/ how much is too much? [Re: 451Mopar] #1775274
03/11/15 01:53 PM
03/11/15 01:53 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
So you have .006 piston to wall clearance and you've filed the ring .010 too much so the "port" is now .006 by .010 too big. That's like the size of this dot . !! I sure as hell wouldn't lose sleep over it on one piston in a daily driver.
Re: ring end gap/ how much is too much? [Re: volaredon] #1775275
03/11/15 03:45 PM
03/11/15 03:45 PM
Make sure and degree that cam in the motor I check them on the cam lobes for cam timing and then set a head on with checking springs and check the piston to valve clearances and then check the intake lobe center for advancing the cam to where it is suppose to be
Re: ring end gap/ how much is too much? [Re: volaredon] #1775276
03/14/15 05:40 PM
03/14/15 05:40 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Similar pistons to what you used, I did the H116CP (which just gets you a slightly higher CR and valve cut-outs)
Rings part #R-9343 25
TOP SECOND
0.020 0.022
0.020 0.022
0.020 0.022
0.020 0.022
0.020 0.022
0.021 0.022
0.022 0.022
0.020 0.022
I used to be worried about oil consumption since I was using a lot of oil..turned out to have been a valve seal (cursed Teflon PC seals) issue. With these gaps, blueprinted 9.8:1 static CR and my Hughes HE3844AL cam I have 175 PSI cranking pressure. All is good...
Re: ring end gap/ how much is too much? [Re: Diplomat360] #1775277
03/17/15 10:50 AM
03/17/15 10:50 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Pay close attention to installing the second ring correctly, if just one is upside down and everything else is correct, your oil consumption will almost DOUBLE. (I saw this in a test Hastings mfg had published). BTW,a bit more gap on the second ring is actually beneficial.
Don't be too hard on your son, the additional top ring gap on one cylinder will likely cost you under 2HP, maybe less than one on a mild build.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
