Mopar Magnum race block #1775259
03/09/15 08:22 AM
03/09/15 08:22 AM
Australia Qld
V
VG423 Offline OP
VG423  Offline OP
V
Australia Qld
I have a mopar magnum race block P 5153452 360 mains. mopar instructions say must use 340 pan, the 340 pan appears to big at the rear seal area. the 360 pan will not sit down far enough with the milodon 41007 one pce gasket.Also the factory spider for the dog bones is hitting the lifter boss area. Has anybody ever finished one of these blocks off? Any advise greatly appreciated.
Re: Mopar Magnum race block [Re: VG423] #1775260
03/09/15 11:10 AM
03/09/15 11:10 AM
Socal
littleVAL Offline
littleVAL  Offline
Socal
That is interesting because in the US they say all of the race blocks are supposed to have 360 pans even though there are several that use 340 pans. Looks to me like 360 pan will fit perfect. The lifter area is hitting because it is cast for 48 and 59 degree lifters. You have 59 degree so can grind off the 48 degree area for the clearance you need. Does the valley have the 3 bolt holes for it though
Re: Mopar Magnum race block [Re: littleVAL] #1775261
03/09/15 12:01 PM
03/09/15 12:01 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I thought the 360 had a bigger rear main seal?
Re: Mopar Magnum race block [Re: littleVAL] #1775262
03/09/15 12:15 PM
03/09/15 12:15 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Dump the stock lifters and get some MRLs, probably still have to machine the block for clearance.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Mopar Magnum race block [Re: littleVAL] #1775263
03/09/15 03:58 PM
03/09/15 03:58 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Tons of meat to safely grind clearance for the lifter. As for the pan just put a little KY jelly on the gasket so it slides over without pulling the gasket down and distorting it and bolt it on.
