Help me pick a rear axle for Dad's car... #1775069
03/08/15 11:19 PM
03/08/15 11:19 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
Dad is building a 10.5:1 408ci roller motor for his Coupe and we're having some serious reservations about the 8.25 that is in the car now. The trans is a 727 and the car will be street driven mostly with 295 radials in the back; it will occasionally see slicks for track use. The motor will be pushing 500HP and the budget for the axle is $1,000 give or take. So far our options seem to be:
8.75: The original idea was to grab one out of a 66-70 B body as the flange to flange width is 55" vs the 54.34" of the original axle. Problem is finding one of these isn't very easy to do anymore.
9.25: I did manage to find one out of an early 80's Ram with a 5x4.5 bolt pattern, SG and 3.23 gear. All it would need is new brakes, perches, and to be cut down. Junkyard wants $150 for it.
D60: We're not opposed to it, but don't know what to look at for one that will require the least amount work to get it to fit. I assume it would need everything the above 9.25 would need with the addition of axles to change to the bolt pattern.
Thoughts? Thanks guys..
Re: Help me pick a rear axle for Dad's car... [Re: MarkZ] #1775070
03/09/15 12:06 AM
03/09/15 12:06 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
If there is a place near you that can narrow a D60 that's by far the cheapest and best way to go. Get a truck one with either a 3.54 or 4.10, get a set of the correct length axles and the differential unit of your choice from Dr. Diff and have at it. The end cost will be the same as the 8 3/4 or the 9.25 by the time you fix them and you'll never do anything to the D60 after you bolt it in.
Sheldon
Re: Help me pick a rear axle for Dad's car... [Re: MarkZ] #1775071
03/09/15 02:07 AM
03/09/15 02:07 AM
The trans is a 727 and the car will be street driven mostly with 295 radials in the back; The motor will be pushing 500HP and the budget for the axle is $1,000 give or take. So far our options seem to be:
Thoughts?
There's gotta be the right width 8&3/4 somewhere (try local Cl in your/nearby cities). This'd let you change ratios later on if desired. 727 Auto/street tires I wouldn't be afraid of an 8&3/4
Re: Help me pick a rear axle for Dad's car... [Re: MarkZ] #1775072
03/09/15 02:14 AM
03/09/15 02:14 AM
smyrna,tn
draginmopars Offline
smyrna,tn
Since you are changing the rear
and may run slicks
You might want to look at "Wheel spacing"
left to right
So either set of wheels will fit with out rubbing.
I like the 80"s ford 3/4 ton rears
The tubes are thick almost a 1/2"
and 3" dia
watch out for the D-61,
pinion has alot of off-set.
Not a good gear selection
We just finished a Dana with Set up kit from Dr. Diff.
has 3.55 ratio, Tru trac unit
all new brake hardware, lines
ONLY, due to logistics
Moser narrowed the rear, welded on housing ends and spring pads
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Help me pick a rear axle for Dad's car... [Re: MarkZ] #1775073
03/09/15 04:51 PM
03/09/15 04:51 PM
If you want to reuse the brakes off of the 8 1/4 on the Dana 60 that works very well (these are off of a 8 1/4 I had) As long as you have the proper axle ends put on it I use the Moser brand 8 3/4, Dana 60 ends this dana 60 was out of a Van with 3.54 gears and a open carrier, I found a 3 sereis clutch type posi and converted it to 35 spline Dana axles Oops, forgot to atttach the picture
Re: Help me pick a rear axle for Dad's car... [Re: RapidRobert] #1775074
03/09/15 08:25 PM
03/09/15 08:25 PM
Georgia
Steve Bryant Offline
Georgia
8 3/4's are not hard to find. Last year I picked one up for my E-Body and cost me $200 plus the drive to pick it up.
Re: Help me pick a rear axle for Dad's car... [Re: Steve Bryant] #1775075
03/10/15 02:10 AM
03/10/15 02:10 AM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I heard that Ford Explorer 8.8's are the right width and can be found with disc brakes. Cheap in the yards and a few gear ratio options.
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
