Driveshaft length question??? #1774857
03/08/15 05:23 PM
03/08/15 05:23 PM
Clinton Township, Michigan
Dartin Offline OP
Dartin  Offline OP
How much play is too much? When I installed the driveshaft and bottomed out the trans yoke I took a measurement. Installed the joints into pinion yoke and took another measurement. I got 1.180". Is that extra .180" too much? I plan to call Dynotech tomorrow morning, but wanted to see what your guys opinion was.
Randy
Re: Driveshaft length question??? [Re: Dartin] #1774858
03/08/15 09:19 PM
03/08/15 09:19 PM
I push the tranny yoke in all the way until it bottoms out on the output shaft of the tranny and the slide it out 3/4 inch and go from their on the effective center to center length That is with the chassis compressed (weight sitting on all four wheels ) like it will be sitting on the ground, not with the rear suspension hanging down unloaded
Re: Driveshaft length question??? [Re: Cab_Burge] #1774859
03/08/15 10:21 PM
03/08/15 10:21 PM
Dartin Offline OP
Dartin  Offline OP
Thanks Cab. I did measure at ride heigth. Dynotechs online order form shows 1" for movement. Just not sure if that .180" is too much?
Randy
Re: Driveshaft length question??? [Re: Dartin] #1774860
03/08/15 11:41 PM
03/08/15 11:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Randy
The trans book calls out for 3/4" travel.. when I
bought any of my shafts from Dynotech I gave them
the length I wanted.. 3/4" short of bottoming out
Re: Driveshaft length question??? [Re: Dartin] #1774861
03/09/15 04:34 PM
03/09/15 04:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The "bottom it out and pull back one inch" only works with a rear seal that doesn't have the dust boot.
The factory dimension for the 727/833 slip yoke is 3 3/4" from the rear of the tailhousing to the center of the u-joint.
Re: Driveshaft length question??? [Re: John_Kunkel] #1774862
03/09/15 10:00 PM
03/09/15 10:00 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It'll be fine. That leaves plenty of yoke surface to ride in the bushing.
Doug
Re: Driveshaft length question??? [Re: John_Kunkel] #1774863
03/18/15 10:53 AM
03/18/15 10:53 AM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
Hi john, Is the yoke dimension in the factory service manual or the parts manual? I have been thumbing thru 1966 to 1969 section 16 and can't find it. thanks, ronnie
Re: Driveshaft length question??? [Re: 1969ronnie] #1774864
03/18/15 04:53 PM
03/18/15 04:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The dimension is from the Mopar Performance chassis manual.
Re: Driveshaft length question??? [Re: John_Kunkel] #1774865
03/19/15 04:09 PM
03/19/15 04:09 PM
1969ronnie Offline
1969ronnie  Offline
thanks john. I know I have seen those fac pics dozen of times on page 185 for autos and page 226 for manuals. the mopar chassis book was right in front of my eyes,but I kept thumbing thru different years of service manuals looking for that info.
