426 Hemi throttle arm linkage #1774526
03/08/15 12:33 AM
03/08/15 12:33 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang...
Anyone have pictures of their OEM 426 Hemi's and the relationship between the front and rear carb throttle arms and the linkage connecting the two. I believe I have the arm out of adjustment... When I drive slowly around, the throttle feels hits a hard spot and I believe it is the linkage moving the front carb arm too soon....
Troy
Houston Mopar Connection Club
Re: 426 Hemi throttle arm linkage [Re: hemi68charger] #1774527
03/08/15 12:45 AM
03/08/15 12:45 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: 426 Hemi throttle arm linkage [Re: hemi71x] #1774528
03/08/15 11:27 AM
03/08/15 11:27 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Troy,
Unless something is bent or in a bind the front carb should not be tipping in at slow speeds. Do you have the green can gizmo hooked up to the vacuum advance? I had mine originally set up with one and about a year or so later I would get weird symptoms of just off-idle surges and the engine speed taking longer to settle coming back at idle. I bypassed it and the engine seems much happier. It was not necessarily a huge change but enough to notice. I know the FSM has a procedure to test/adjust but just have not taken the time to do it yet. Good Luck.
Re: 426 Hemi throttle arm linkage [Re: hemi68charger] #1774529
03/08/15 04:43 PM
03/08/15 04:43 PM
Jefferson State
srt Online content
ESYC
srt  Online Content
ESYC
Jefferson State
I still have the fsm out. If you need the dash-pot adj inst let me know.
If you don't have a fsm, I suggest it, lots of measurements to check to set the carbs back to oem.
Re: 426 Hemi throttle arm linkage [Re: srt] #1774530
03/08/15 04:45 PM
03/08/15 04:45 PM
Jefferson State
srt Online content
ESYC
srt  Online Content
ESYC
Jefferson State
Re: 426 Hemi throttle arm linkage [Re: srt] #1774531
03/08/15 04:47 PM
03/08/15 04:47 PM
Jefferson State
srt Online content
ESYC
srt  Online Content
ESYC
Jefferson State
Re: 426 Hemi throttle arm linkage [Re: srt] #1774532
03/08/15 04:48 PM
03/08/15 04:48 PM
Houston, Tx
Houston, Tx
I think myu linkage is adjust so the rear carb throttle arm engages the linkage too early. I need to make the distance travel a little longer on the slotted area of the rear carb...
Thanks..
guys...
Troy
Re: 426 Hemi throttle arm linkage [Re: hemi68charger] #1774533
03/08/15 06:01 PM
03/08/15 06:01 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Troy,it needs adjusted so both carbs reach full open at the same time,hold rear full open and adjust front swivel accordingly.
Re: 426 Hemi throttle arm linkage [Re: 62maxwgn] #1774534
03/10/15 02:23 AM
03/10/15 02:23 AM
Jefferson State
srt Online content
ESYC
srt  Online Content
ESYC
Jefferson State
above is important so that front carb butterflys are not becoming the "stop" for the accel pedal.
