Need help identifiying 340 block #1774263
03/07/15 08:45 PM
03/07/15 08:45 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
casting numbers are 2780930-340-3 6/20/67 DAY TIME also a 0232 cast on side of block. under the cylinder head there is a strange cross looking thing stamped in block DW34023340076+. The other number behind dist hole is 8B 239741 VIN?
Re: Need help identifiying 340 block [Re: 340swing] #1774264
03/07/15 08:48 PM
03/07/15 08:48 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
2ND
Re: Need help identifiying 340 block [Re: 340swing] #1774265
03/07/15 09:40 PM
03/07/15 09:40 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes the number behind the distributor hole is the VIN sequential number. It's a 68 model year 340
DW340 ....
D=1968 Model Year
W=Windsor engine plant
340=cubic inches
2334 is Monday, December 18, 1967
0076 is the build sequence
Re: Need help identifiying 340 block [Re: ScottSmith_Harms] #1774266
03/07/15 09:50 PM
03/07/15 09:50 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Thanks scott any way of telling what car line it came out of? How about the cross thing after number. looks to be a maltese cross indicating crankshft is undersized .001 ever hear of that?
Re: Need help identifiying 340 block [Re: 340swing] #1774267
03/07/15 09:56 PM
03/07/15 09:56 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, cross = .001" Under Sized crankshaft
Re: Need help identifiying 340 block [Re: ScottSmith_Harms] #1774268
03/07/15 10:02 PM
03/07/15 10:02 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
any way to tell the car line from partial vin 8B 239741
Re: Need help identifiying 340 block [Re: 340swing] #1774269
03/07/15 10:16 PM
03/07/15 10:16 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Any idea what this is
Re: Need help identifiying 340 block [Re: 340swing] #1774270
03/07/15 10:30 PM
03/07/15 10:30 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
C22 "Scheduled Production Date" - Friday before Christmas 1967 (12/22/67)
a known B'cuda at 8B239678
-your 340 block at 8B239741 * anyone know a Barracuda or Dart between 239678 & 239849?
& a Dodge Dart at 8B239849
where's that 0262 casting number?
Re: Need help identifiying 340 block [Re: 6bblgt] #1774271
03/07/15 10:40 PM
03/07/15 10:40 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
casting no
Re: Need help identifiying 340 block [Re: 340swing] #1774272
03/07/15 10:41 PM
03/07/15 10:41 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
date time
Re: Need help identifiying 340 block [Re: 340swing] #1774273
03/07/15 10:49 PM
03/07/15 10:49 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Dan here is a better picture
Re: Need help identifiying 340 block [Re: 340swing] #1774274
03/07/15 10:56 PM
03/07/15 10:56 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
68 340 should be what color? I will send it out and have it checked, see if its any good. bores are ok some pitting will need a bore probably.
Re: Need help identifiying 340 block [Re: 340swing] #1774275
03/07/15 10:59 PM
03/07/15 10:59 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
my 68 Barracuda 340 S has a SPD of B14 and sequence number of 203175.
So did they make roughly 36,000 barracudas (if SPD's are close to be right) between Nov 14 and Dec 22? Or is that an incorrect way to interpret that.
Re: Need help identifiying 340 block [Re: 340swing] #1774276
03/07/15 11:02 PM
03/07/15 11:02 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Red
Re: Need help identifiying 340 block [Re: autoxcuda] #1774277
03/07/15 11:13 PM
03/07/15 11:13 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
P8B203175 SPD-B14 (Tuesday, November 14, 1967)
P8B239741 SPD-C22 (Friday, December 22, 1967)
36,566+ assigned VINs in ~27 UAW working days (~1,400 cars per day) out of two shifts on each of two assembly lines at the Hamtramck, Michigan plant.
These VINs would be Barracudas, Chargers, Darts, & Valiants.
"They" assembled 45,412 1968 model year Barracudas between July 31, 1967 & July 12, 1968.
Re: Need help identifiying 340 block [Re: 6bblgt] #1774278
03/08/15 01:07 AM
03/08/15 01:07 AM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Thanks Dan that's some pretty good info. So probably a 68 barracuda.I will get it checked out.
Re: Need help identifiying 340 block [Re: 340swing] #1774279
03/08/15 11:50 AM
03/08/15 11:50 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
In '68, 340's would have only come from the factory in Formula S Barracudas or Dart GTS. I'm not aware the factory ever slipped a 340 into a Valiant or a Charger that year (& that's not what Dan was saying).
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
