Milodon dual line help #1774221
03/07/15 05:59 PM
03/07/15 05:59 PM
Chesterfield Twp. Mi.
John Burdine Offline OP
I'm gonna do a Milodon dual line oil system. I have a pan and swinging pick up. I gonna use the billet cover p/n MIL21225. I need a pump to facilitate the second line. with the billet pump I think you have to add a plate in the middle, or older style pump with the billet cover. do I have this correct?
Re: Milodon dual line help [Re: John Burdine] #1774222
03/07/15 06:14 PM
03/07/15 06:14 PM
Look at the Milidon pump # 21815 for your deal Do NOT use the plate , it is to small on the transition from the line into the pump
Re: Milodon dual line help [Re: Cab_Burge] #1774223
03/07/15 08:30 PM
03/07/15 08:30 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
if you use the plate, you will need a longer oil pump drive.
Without Data, you’re just another guy with an opinion.
Re: Milodon dual line help [Re: Cab_Burge] #1774224
03/08/15 07:43 AM
03/08/15 07:43 AM
that's one that I was looking at with the billet cover. I thought they would have a billet pump for a dual line application, guess not.
Re: Milodon dual line help [Re: John Burdine] #1774225
03/08/15 12:59 PM
03/08/15 12:59 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
RBRE Billet oil Pump..........No Issues
using dual line to Charlies O/P . instant oil at start up .
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
