Page 1 of 3 1 2 3
Highway RPMs #1773436
03/06/15 05:05 PM
03/06/15 05:05 PM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
My Duster with 3.91s runs about 3500-3600 rpm at 68-70 mph. Usually I will run around 3300-3400 rpm on the highway, but sometimes you need to run a little quicker to keep up. Eventually a 4 speed will be going in. Tires are 255/60/15s. Motor is a warmed over stock compression 318 (with XE268 cam) with 45K since the last rebuild. Doesn’t use a drop of 15w40 Delo oil between changes. The engine buzzing doesn’t bother my ears, but with regular oil changes (every 1500 miles), am I flirting with danger at the revs mentioned? I don’t think so, but just wanted to hear some opinions!
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: Highway RPMs [Re: MoparJ] #1773437
03/06/15 05:22 PM
03/06/15 05:22 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Nothing wrong with that. Cars did that for years before OverDrive became a standard item.
Re: Highway RPMs [Re: stumpy] #1773438
03/06/15 05:35 PM
03/06/15 05:35 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
If you plan to swap in a Standard 4-Speed Transmission, fourth gear is Direct, as in no different than Third Gear in a 3-Speed manual transmission, or Drive/Third Gear in a 727 or 904 Automatic Torqueflite.
You would need a an Overdrive Transmission to bring the RPM down at freeway speeds. Higher continuous RPM does accelerate engine wear, though you may be able to live with that.
Swapping to Taller tires works similar to swapping in, say, 3.54 or 3.23 rear axle gear ratio, but off-the-line performance would suffer a bit as well, and there are practical limits on how tall a tire you can fit in your wheel wells.
There are lots of great Gear Ratio calculator applications available, wherein you input rear-axle ratio, transmission ratio (1-to-1 in high gear for a Standard, non-overdrive transmission) along with Tire Diameter which will calculate Engine RPM based on Speed in MPH.
You can run the numbers to determine what combination would produce your desired results, though it is always a compromise.
Re: Highway RPMs [Re: D_C] #1773439
03/06/15 05:38 PM
03/06/15 05:38 PM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
If it is a Standard 4-Speed Transmission, fourth gear is Direct, no different than Third Gear in a 3-Speed manual transmission, or Drive, Third Gear in a 727 or 904 Torqueflite.
Swapping to Taller tires works similar to swapping in, say, 3.54 or 3.23 rear axle gear ratio, but off-the-line performance would suffer a bit as well.
904, with TF-2 kit, 2800 stall.
Moved away from 3.23s a while ago, so the 91's are here to stay.
Re: Highway RPMs [Re: MoparJ] #1773440
03/06/15 05:45 PM
03/06/15 05:45 PM
D_C Offline
D_C  Offline
Always a choice/compromise. I have 4:10 gears and a 727 in my Charger. Engine screams on the freeway, but I don't drive it like that all that often.
Say, driving from 40-miles East of Los Angeles to Woodley Park in Van Nuys (Spring Fling) for an hour-and-a-half on the freeway, wouldn't be healthy for all involved on a regular basis.
Re: Highway RPMs [Re: D_C] #1773441
03/06/15 05:46 PM
03/06/15 05:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Except for the converter slippage.
Re: Highway RPMs [Re: D_C] #1773442
03/06/15 05:50 PM
03/06/15 05:50 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The manual transmission will lower by 200 rpm his highway cruise rpm.
Re: Highway RPMs [Re: John_Kunkel] #1773443
03/06/15 05:54 PM
03/06/15 05:54 PM
D_C Offline
D_C  Offline
Yes. Some of the gear-ratio calculator programs/apps allow you to factor in torque-converter slippage as well.
Even with slippage, 200 RPM helps, but is it enough to solve the problem?
Re: Highway RPMs [Re: D_C] #1773444
03/06/15 06:06 PM
03/06/15 06:06 PM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
The A-833 with OD swap will take place sometime before the year is out. I drive one or two days a week, with maybe 30-40 of the 110 or so mile I may drive being at those engine speeds. All variables such as coolant temp and oil pressure have not changed in the past year. I am also in Southern California.
Re: Highway RPMs [Re: MoparJ] #1773445
03/06/15 06:34 PM
03/06/15 06:34 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
My 340 Challenger runs 3500rpms at 70mph (255/60/15's & 3:91's) and I never sweat it!
Re: Highway RPMs [Re: YO7_A66] #1773446
03/06/15 06:43 PM
03/06/15 06:43 PM
P
Paul_Fancsali Offline
P
Same here the 340 runs 3500-4000 depending on the 4.10s or the 4.56 with short tires Actually I find it blows out the putt putt crap from the engine. On my 360 with 4.30s I used to hold 4000 constantly for 2 hours plus and it never seemed to bother it
Re: Highway RPMs [Re: Paul_Fancsali] #1773447
03/06/15 07:25 PM
03/06/15 07:25 PM
BDW Offline
BDW  Offline
Couldn't take my 340 screaming as everyone passéd me on the highway.
Car is much funner to drive with the 518 w/LU.
3.73 gears, 26.7 inch tires.
Re: Highway RPMs [Re: BDW] #1773448
03/06/15 10:58 PM
03/06/15 10:58 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I wouldn't worry about it. I don't think you'll ever notice increased engine wear. I doubt you'll every put enough milei on it to ever get to that point. I'm talking 150-200k miles. Ive run my civic for hours at 3600rpm at 78 mph. Still knocked down some great mpg! Only reason for the Od trans is noise, peace of mind and some mpg gains. Im doing the od in mine too, mostly because I can't stand to see the tach sit that high!
Re: Highway RPMs [Re: DaytonaTurbo] #1773449
03/07/15 12:21 AM
03/07/15 12:21 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I drive the 90 mile run to Carlise at 60 mph in my 63 with 4.30's. I use a 30" tall tire and it runs about 3200 at 60 mph. Its no problem for me to run the 90 miles at 3200 rpm as it usually takes me about an hr and a half. Ron
Re: Highway RPMs [Re: stumpy] #1773450
03/07/15 01:18 AM
03/07/15 01:18 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: Highway RPMs [Re: MoparJ] #1773451
03/07/15 02:56 AM
03/07/15 02:56 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Best thing you will ever do.
As far as will high rpm on the highway hurt it? Eventually, yes: there's a reason why new vehicles with overdrive are hitting 300,000 miles and the old girls barely made 100,000.
Did a head gasket on a '98 350 700R4 half-ton and at 170,000 miles the cylinders still had cross hatch in them.
Mo' Farts
Moderated by "tbagger".
Re: Highway RPMs [Re: Grizzly] #1773452
03/07/15 03:14 AM
03/07/15 03:14 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
No offense, but considerably more involved than just final drive ratio....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Highway RPMs [Re: MoparJ] #1773453
03/07/15 10:28 AM
03/07/15 10:28 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
3.91s have been our gear of choice forever. So hiway RPMs has always been something we keep an eye on. 3,000 has been the dividing line so to speak. Staying there abouts or under is preferable and the farther over that you get and the longer you stay there, then the more pounding you are doing to the engine.
Master, again and still
Re: Highway RPMs [Re: DaveRS23] #1773454
03/07/15 04:51 PM
03/07/15 04:51 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I've always used 3,000 rpm as the dividing line as well. No testing, data, or science, just feels about right.
Re: Highway RPMs [Re: BSB67] #1773455
03/07/15 05:36 PM
03/07/15 05:36 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I've always used 3,000 rpm as the didviding line as well. No testing, data, or science, just feels about right.
Thats not a bad idea. But I will say with the solid flat tappet cam I use my eng sounds real nice singing along about 3200 RPM with my cam. Ron
Page 1 of 3 1 2 3
