Page 1 of 3 1 2 3
572 with B1 Originals #1772972
03/06/15 12:25 AM
03/06/15 12:25 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
How many of you are there out there and what kind of numbers does it have? I've been told my Originals are garbage and they will never make power.. So was just wondering what its real life capabilities are for a motor this size..
Re: 572 with B1 Originals [Re: Jeepmon] #1772973
03/06/15 12:28 AM
03/06/15 12:28 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I'm hoping for a little over 600 HP out of mine.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 572 with B1 Originals [Re: pittsburghracer] #1772974
03/06/15 12:37 AM
03/06/15 12:37 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Based on that HP vs CI thread.. that should easily reach your goal of 600...
Re: 572 with B1 Originals [Re: Jeepmon] #1772975
03/06/15 12:43 AM
03/06/15 12:43 AM
gregsdart Offline
gregsdart  Offline
A number of builds I can think of did well with B1s and less cubes. B1Wes made 940 hp with 540 cubes, partially ported B1 originals on race gas. In the Fastest car list, B1 Ken went 8.178 at 2430 lbs, stock block B1 511 cubes, single four. Others in that list show decent power for B1 motors.
Re: 572 with B1 Originals [Re: gregsdart] #1772976
03/06/15 12:46 AM
03/06/15 12:46 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Don,
It should make a 1000, maybe a little more. Mine did.
Re: 572 with B1 Originals [Re: Jeepmon] #1772977
03/06/15 01:32 AM
03/06/15 01:32 AM
I'm in the process of building a 539.5 C.I. bracket motor, 4.995 bore x 4.250 stroke, that Koffels is doing the porting on the original B1 heads right now, I'm hoping to make 900 + HP on race gas with 13.0 to 1 compression ratio with a single Dominator carb on the B1 cast intake in Boise on a Super Flow dyno I would really like to make more power than that but the limits the customer put on this build, no vacume pump, 7000 RPM peak HP goal and so on I'll be happy with 900+HP If I am remembering correctly the 526 C.I. B1 motor Al got from Chris made over 2.0 HP per C.I. with ported B1 heads on it Don't tell him I said this
Re: 572 with B1 Originals [Re: Cab_Burge] #1772978
03/06/15 01:58 AM
03/06/15 01:58 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
I'm in the process of building a 539.5 C.I. bracket motor, 4.995 bore x 4.250 stroke,]
That would be 666.25 c.i. I think you meant 4.495 bore.
Re: 572 with B1 Originals [Re: qwkmopardan] #1772979
03/06/15 03:12 AM
03/06/15 03:12 AM
sg66mopar Offline
sg66mopar  Offline
Don, want to donate those "garbage" B1s? Might make my tank run a little better.
Seriously though, what makes you think they're garbage? I bet Tommy or Al could fix them up to make some power.
Re: 572 with B1 Originals [Re: sg66mopar] #1772980
03/06/15 03:27 AM
03/06/15 03:27 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thats just what I've heard from guys that build motors that make power.. No matter how strong the short block can be.. that the B1's are the limiting factor
But it sounds like these heads are very capable of 1000 hp and personally speaking, I wouldnt call that weak
Re: 572 with B1 Originals [Re: Jeepmon] #1772981
03/06/15 04:57 AM
03/06/15 04:57 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
What type of engine are you building, street or race.
Re: 572 with B1 Originals [Re: qwkmopardan] #1772982
03/06/15 05:06 AM
03/06/15 05:06 AM
You be correct My mistake, the second one this year
Re: 572 with B1 Originals [Re: 572B1] #1772983
03/06/15 05:13 AM
03/06/15 05:13 AM
Arizona
Chris'sBarracuda Offline
Arizona
Well Don..
There are waaaaay too many so called 1000+ hp motors out there running the same ET as mine, and at less weight.
My CAR has run 8.78 @ 154.9 here in Phoenix. Approx. 2800-3200 DA. 540" B1 Originals.. P/G, 1150 Holley, 4:30's, 14 x 32's
1.24 60 ft. glide.. Really set up for S/ST.
Wallace put me @ 890 hp uncorrected and 950ish corrected.. (That's what dynos are... Corrected)
Never did the Dyno thing, but the real numbers at the track are the ONLY thing that matters..
Put the motor in the car and start tuning..
BTW.. My B1 originals flowed 416 @ .850 on 3 different benches.. AND my Barracuda weighs 3000#..
Chris..
Re: 572 with B1 Originals [Re: Chris'sBarracuda] #1772984
03/06/15 05:39 AM
03/06/15 05:39 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The term "garbage" heads had a context. Might be good idea to recall the conversation. And compared to other stuff at this shop the term "scrap" might be a better term There is more Aussie Pro Stock stuff lying around than one can shake a stick at, not to mention all the record setting Comp and SS stuff.
Man are Mopar guys sensitive. The more I try the more I am convinced of it.
Re: 572 with B1 Originals [Re: Jeepmon] #1772985
03/06/15 10:13 AM
03/06/15 10:13 AM
NC
440Jim Offline
440Jim  Offline
NC
I've been told my Originals are garbage and they will never make power...
Depends on your porting and induction (single 4, tunnel ram, etc.).
I think it is safe to say if your goal is 1000 hp or less, they are suitable.
Re: 572 with B1 Originals [Re: 440Jim] #1772986
03/06/15 11:20 AM
03/06/15 11:20 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
When people are used to working on real high end prostock and comp stuff, comparably, B1's are weak. I know you can make at least 1040 with originals, and 1100 with MC's. I am convinced though that you can make 2+ HP per CI with B1 heads, if you are willing to spend what it costs and spin it up with 500 CI. They did it in Pro Stock in the early 90's. It all relative.
Re: 572 with B1 Originals [Re: camastomcat] #1772987
03/06/15 12:35 PM
03/06/15 12:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Big cubes and that head it will just peak sooner(rpm)..
no big deal
Re: 572 with B1 Originals [Re: MR_P_BODY] #1772988
03/06/15 01:04 PM
03/06/15 01:04 PM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
My 588 made 1051hp n/a on Self's dyno with originals in nitrous trim...Still makes 1000+ @ 8200rpm but we don't turn it that hard !!
Been 4.86 @ 146mph with a 44 jet(around 450hp) weighing 3275# on a 275 drag radial !!
Re: 572 with B1 Originals [Re: Al_Alguire] #1772989
03/06/15 01:42 PM
03/06/15 01:42 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
I dont think sensitivity is appropriate here, as its all a learning curve to me..
But when you're talking to a respected engine builder about the B1-O heads and the word "garbage" flows out of his mouth.. and then is followed up with "dont waste the money on a set of Ti valves".. Well, thats gonna get your attention and is in need of follow-up..
In my opinion, these heads are better than most and not as good as others, but they are serviceable considering the money I dont have to throw at it right now..
But the purpose of this thread was to gauge how efficient my motor is compared to others that are out there..
Re: 572 with B1 Originals [Re: Jeepmon] #1772990
03/06/15 02:36 PM
03/06/15 02:36 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well we both know what yours made and what the issues were that are robbing it of at LEAST 30hp. AS for titanium valves. The engine was built to be a reliable low RPM deal. Titanium valves are not needed it makes peak power at 6900 and IMO that money could be better spent to address some other issues that need to be addressed.
Just trying to ad context here. Even with the issues you are almost at 1.7, not "just" 1.6. Once the big issue is repaired it will be over 1.7 even if it picks up only 6 HP it will be there.
Re: 572 with B1 Originals [Re: Al_Alguire] #1772991
03/06/15 03:29 PM
03/06/15 03:29 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Since the cat is pretty much out of the bag... Here is a picture of a partial dyno sheet from earlier this week..
The only thing worth mentioning is the vacuum pump we have on the motor, didnt work well and could not create enough vacuum to make power.. Rick Watters suggested a new vacuum pump could be worth another 40 HP...
But it is.. what it is.. enjoy
Page 1 of 3 1 2 3
