Re: E-Body Rear End Adjustment
[Re: Steve Bryant]
#1772622
03/05/15 08:04 PM
03/05/15 08:04 PM
RapidRobert
First thing I'd do is put a piece of flat stock across the rear tires & see if their heights are the same & continue measureing to see where the difference is coming from (spring arch etc). where specifically the height difference that you are measuring? No opinion if the less than 1 inch difference is acceptable or not. You wouldn't wanna change the tbar heights as that would possibly mess up your front alignment settings
[Re: Steve Bryant]
#1772625
03/06/15 01:26 PM
03/06/15 01:26 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Check all 4 corners to see it the front is low on the opposite side. If the front is even with each other then T-bar adjustment might not be in order. Do you by chance have super stock springs?
Careful, your character's showing!
