Re: oil pressure fluctuations
[Re: slickrock]
#1772474
03/05/15 07:21 PM
03/05/15 07:21 PM
Posts: 25,756 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Factory gauge? What RPM when the pressure drops?
[Re: slickrock]
#1772478
03/05/15 07:29 PM
03/05/15 07:29 PM
Posts: 549 WV
JohnH
WV
If there is not one there, very could be your problem,, the higher the RPM the more wind off the crank.. It's foaming the oil.. If there is one on there you will see the side of it,, along with 2 oil pan gaskets..
[Re: Pacnorthcuda]
#1772482
03/05/15 07:47 PM
03/05/15 07:47 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I like to check the simple things first. Stock gauge or mechanical? Have you tried a different gauge or sender unit? Stock pan should hold 5 quarts of oil. I always put in 6. 1 for the filter.
I have mechanical Aptitude. I can screw up anything.
[Re: slickrock]
#1772484
03/05/15 08:03 PM
03/05/15 08:03 PM
bboogieart
Lost and Spaced
I'd make sure the gauge is working before digging into the motor. Worth a shot, right?
[Re: bboogieart]
#1772485
03/05/15 08:05 PM
03/05/15 08:05 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
Incorrect. A stock pan holds 4 quarts of oil, and one for the filter. Page 9-98 in the specifications section, of the 1970 factory service manual.
RF-4C Phantom 69-370 Zweibrucken, Germany
