pictures of duster with inner fenders removed #1772365
03/05/15 03:50 PM
03/05/15 03:50 PM
florida
crooksduster Offline OP
florida
Looking for a few pictures of dusters that have had the inner fenders around the shock towers removed. I want to remove as much as I can but still be able to hang the fiberglass fenders in the stock holes. Thanks Crook
Re: pictures of duster with inner fenders removed [Re: crooksduster] #1772366
03/05/15 04:29 PM
03/05/15 04:29 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Stock holes? What you have left is 1 bolt on the top of the fire wall, and the radiator support. After removing the inner fenders you need to support the front frame rails with down tube pipe supported by the roll cage or to the fire wall down to the front of the frame rails. The shock towers should also be tied into the tubes by brackets. If this is not supported your car will fold up.
Re: pictures of duster with inner fenders removed [Re: rowin4] #1772367
03/05/15 04:46 PM
03/05/15 04:46 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If you saw how light and easy it is to remove the whole front end with steel fenders you would rethink going to fiberglass. Two bolts and its on the ground making the car super easy to work on
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
