Right hand rotation 440 #1771568
03/04/15 08:37 PM
03/04/15 08:37 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
disassembled this 440 with a gear driven cam, cam is like new condition (.235 lift X 1.5 rocker gives .352 valve lift) Should I toss it or build a truck engine using it? Engine had 516 heads.
What can be known about this engines performance?
Re: Right hand rotation 440 [Re: MO_PA] #1771569
03/04/15 09:13 PM
03/04/15 09:13 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Are you sure it's a right hand rotation 440?
Gear drive RBs were left hand, only the cam turned backwards. Compare the oil pump drive teeth to a regular LH drive, they should be cut backwards.
The true right hand 440s I've seen had a timing chain, the crank and cam turned backwards.
Re: Right hand rotation 440 [Re: B5 Bee] #1771570
03/04/15 11:44 PM
03/04/15 11:44 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
It is indeed a right hand rotation engine and as you mentioned, the oil pump drive gear has backwards teeth.
Re: Right hand rotation 440 [Re: MO_PA] #1771571
03/05/15 01:31 PM
03/05/15 01:31 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
I know it is not your question, and maybe I am cornfused, but check the knurling on the rear main seal area.
No personal knowledge but have seen mention of "reverse" knurling and oil leaks?
It takes gasoline to interest me.
Re: Right hand rotation 440 [Re: MO_PA] #1771572
03/05/15 03:08 PM
03/05/15 03:08 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I get the feeling that it is one of the industrial engines that turns the conventional direction but used a gear driven cam. Those cams were ground to run in the opposite direction of the crank.
The cam, cam drive, oil pump drive, oil pump, and distribtor are different. All other parts are conventional.
They can be dropped in a vehicle and used like any other engine. Just be sure to wire the distributor accordingly.
- Stu Harmon
Re: Right hand rotation 440 [Re: feets] #1771573
03/05/15 03:29 PM
03/05/15 03:29 PM
Enfield, Ct
Moe Offline
Moe  Offline
Enfield, Ct
Boat engines worked like this also?
Re: Right hand rotation 440 [Re: MO_PA] #1771574
03/05/15 03:35 PM
03/05/15 03:35 PM
dogdays Offline
dogdays  Offline
Right hand rotation = regular engine rotation. Gear drive means the cam turns backwards.
This same gear drive would allow use of a standard cam in a reverse rotation engine.
Unless you wanted to keep the gear drive, it'd be easier to swap in a regular cam and a timing chain.
Bullet regrinds hydraulic flat tappet cams for $60. I don't know if they're set up for reverse rotation cams, thoug.
No way would I run a bigblock with a .352" lift cam.
R.
Re: Right hand rotation 440 [Re: dogdays] #1771575
03/05/15 07:21 PM
03/05/15 07:21 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Seems to be some confusion on what is right and left hand rotation. Rotation is determined just like the left and right side of a car is.
Left - CCW, regular rotation, like in cars
Right - CW, backwards rotation, AKA reverse, common with Chrysler Marine engines.
The gear drive cam is not the same as a reverse rotation cam, only the rotation is the same, lobes are in different locations. The dist drive gear is the same. Also, a gear drive with a regular cam will not work in a reverse rotation motor.
Anyone that parts out a Marine or Industrial motor, save the cams, dist gears and cam gears. There aren't any new cam cores available, much less new dist drive and cam gears. People rebuilding Chrysler Marine motors need them.
Re: Right hand rotation 440 [Re: VL21] #1771576
03/05/15 07:30 PM
03/05/15 07:30 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
The right hand "reverse" rotation motor does have the knurling backwards. The knurling cam be polished out and a neoprene rear seal used, but why with all the extra unused 440 cranks laying around from all the big stroke motors being built.
Re: Right hand rotation 440 [Re: B5 Bee] #1771577
03/05/15 09:51 PM
03/05/15 09:51 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Understood.
I had the impression that the OP may have stated it incorrectly.
- Stu Harmon
