Are aluminum shackle bushings a bad idea? #177141
12/28/08 05:48 PM
12/28/08 05:48 PM
CJV5314 Offline OP
CJV5314  Offline OP
Are aluminum shackle bushings a bad idea? Putting them on my driver but only if they are going to last a while. At first I thought they might but the more I think about it the more unsure I am. I've already fabricated 4 out of some unkown grade of aluminum round stock. Check out the pics. Any thoughts?
Re: Are aluminum shackle bushings a bad idea? [Re: CJV5314] #177142
12/28/08 05:52 PM
12/28/08 05:52 PM
CJV5314 Offline OP
CJV5314  Offline OP
pic of upper mount. not all the way pressed in yet!
Re: Are aluminum shackle bushings a bad idea? [Re: CJV5314] #177143
12/28/08 10:02 PM
12/28/08 10:02 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Before I would say a bad idea, Why do you feel you need them vs other choices?
Re: Are aluminum shackle bushings a bad idea? [Re: CJV5314] #177144
12/28/08 10:08 PM
12/28/08 10:08 PM
CA
David Lee Offline
David Lee  Offline
CA
they will increase the harshness of your ride and will they will not last that long. If this is a daily driver that will not see that much strip time I would suggest another form of bushing
Ah...so many pedestrians, so little time...
Re: Are aluminum shackle bushings a bad idea? [Re: CJV5314] #177145
12/28/08 11:19 PM
12/28/08 11:19 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
(Are aluminum shackle bushings a bad idea?) On a street car, yes.
Re: Are aluminum shackle bushings a bad idea? [Re: CJV5314] #177146
12/28/08 11:56 PM
12/28/08 11:56 PM
Since you have gone to the time & used your extensive skills to fabricate them (& they ARE IN) you gotta try them. Otherwise you will never know & will be basing your decision on someone elses opinion/experience & if they end up being too harsh(& I dont think they will) you can R&R them. But you will have YOUR answer & will have successfully concluded your experiment.
Re: Are aluminum shackle bushings a bad idea? [Re: RapidRobert] #177147
12/29/08 12:00 AM
12/29/08 12:00 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Bronze or brass would hold up better but still be a harder ride than rubber. On the other hand, if they are easy enough to reproduce and cheap, make a whole bunch and replace as needed
Re: Are aluminum shackle bushings a bad idea? [Re: RapidRobert] #177148
12/29/08 12:06 AM
12/29/08 12:06 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
On one side I agree they are already in place take them for a ride....As far as the "& I dont think they will" I took a ride in a car today with solid spring eye bushings, it's amazing how effective polyurethane is at damping harshness while still controlling spring position..
