Re: Thumper Carbs? [Re: mikeysmopars] #1771244
03/17/15 01:25 AM
03/17/15 01:25 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
What is your body style and how much does it weigh?. Looks good under the hood
Re: Thumper Carbs? [Re: mikeysmopars] #1771245
03/17/15 01:25 AM
03/17/15 01:25 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
ET, 60ft and all that is great, but mph is power and you are down some. Could be the weather, but you need to jet for mph and then work on the ET.
Monte
Re: Thumper Carbs? [Re: Mopar-Al] #1771246
03/17/15 01:29 AM
03/17/15 01:29 AM
fresno ca
mikeysmopars Offline
fresno ca
hood [/quote
Thanks,68 Dart
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Thumper Carbs? [Re: Monte_Smith] #1771247
03/17/15 01:50 AM
03/17/15 01:50 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Monte
I agree and this is a different carb than what he ran before so no back to back test and the weather was apparently warmer than the 9.98 best. What fuel do you run and what compression Mikey?
Re: Thumper Carbs? [Re: Thumperdart] #1771248
03/17/15 02:06 AM
03/17/15 02:06 AM
fresno ca
fresno ca
110 sunoco and 12.5 compression.
Keep in mind i had dist issues so first run was 9:30 and three bad runs and last one was a good one for how hot it was.
My next TNT will be MATS in two weeks so trying to sort out anything i can before.
Re: Thumper Carbs? [Re: mikeysmopars] #1771249
03/17/15 02:39 AM
03/17/15 02:39 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Heard great things about the C12 fuel from Mark Monte and others so who knows there. What were the afrs from the start and through the midrange.
Re: Thumper Carbs? [Re: Thumperdart] #1771250
03/17/15 03:21 AM
03/17/15 03:21 AM
fresno ca
fresno ca
Only really got to see the last run and held from 12 to 13 after i shifted to second and high gear. My Buddie was able to turn the gopro off and on from his phone and download it but couldnt zoom in on it on the first few runs but was in the green digital lights the whole time. I need to mount it closer to the gauge to really read it.
Still it never ran that good in the heat so it was encouraging
Re: Thumper Carbs? [Re: mikeysmopars] #1771251
03/17/15 03:39 AM
03/17/15 03:39 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
There's more there for sure but good runs. In thr green is not enuff info so see what's needed to see the gauge and can you post plug pics?
Re: Thumper Carbs? [Re: Thumperdart] #1771252
03/17/15 11:30 AM
03/17/15 11:30 AM
fresno ca
fresno ca
I'll try today
Re: Thumper Carbs? [Re: Thumperdart] #1771253
03/17/15 11:48 AM
03/17/15 11:48 AM
fresno ca
fresno ca
Here is what they look like after idling back from last run but I'll post one later from my phone right before I jetted it
Re: Thumper Carbs? [Re: mikeysmopars] #1771254
03/17/15 12:18 PM
03/17/15 12:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What heat range and gap.
Re: Thumper Carbs? [Re: Thumperdart] #1771255
03/17/15 02:01 PM
03/17/15 02:01 PM
fresno ca
fresno ca
after last run in 90 degree heat
Re: Thumper Carbs? [Re: mikeysmopars] #1771256
03/17/15 02:11 PM
03/17/15 02:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
As we spoke earlier jet up till it slows then we can tweek the high speeds if necessary.
Re: Thumper Carbs? [Re: Thumperdart] #1771257
03/20/15 09:19 PM
03/20/15 09:19 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Got my fuel filter today, installed it, put fuel in the cell,,fired right up!!! About 3-4 minutes of warming up, I could get out of car and check the timing, as I had the distributor out priming the new oil through the motor after oil change. I reset the timing to 35* as it was at 40* from my priming and replacing,etc. Let it warm up to 190* and adjusted idle RPM. Gave the idle air screws about 1/8 turn out and all was good. Sounds VERY clean and CRISP at idle and revs quickly. The Township went by today with their sweeper getting the cinders off the road, SO, I'm thinking they know I'm getting ready to roll here!! THANKS Dom!!
If you like drag racing, support your local track.
Re: Thumper Carbs? [Re: CHAPPER] #1771258
03/20/15 10:10 PM
03/20/15 10:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Great to hear. .........
Re: Thumper Carbs? [Re: mikeysmopars] #1771259
03/21/15 03:08 AM
03/21/15 03:08 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
There is nothing to see mixture wise on that plug. The only thing the threads and strap tell you is heat. The mixture is read off the very base of the porcelain. Out there on the end means little to nothing
