Page 1 of 4 1 2 3 4
Expensive 9 inch rears! #1771113
03/04/15 03:02 PM
03/04/15 03:02 PM
Hilltown Pa
1967dartgt Offline OP
Hilltown Pa
Here is a housing with ends to your length.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Expensive 9 inch rears! [Re: 1967dartgt] #1771114
03/04/15 03:07 PM
03/04/15 03:07 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Not bad at all but I wouldn't order one with ends welded on, prior to back bracing. When I built mine, I just got a junkyard housing. But' I had almost that much tied up in the housing and axle ends.
Re: Expensive 9 inch rears! [Re: 1967dartgt] #1771115
03/04/15 03:07 PM
03/04/15 03:07 PM
Hilltown Pa
Hilltown Pa
Complete center sections your choice of gears set up for you.
Re: Expensive 9 inch rears! [Re: 1967dartgt] #1771116
03/04/15 03:09 PM
03/04/15 03:09 PM
Hilltown Pa
Hilltown Pa
A bit more racy
Re: Expensive 9 inch rears! [Re: 1967dartgt] #1771117
03/04/15 03:11 PM
03/04/15 03:11 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
The OP is
Mopar Performance
Re: Expensive 9 inch rears! [Re: STEFF] #1771118
03/04/15 03:12 PM
03/04/15 03:12 PM
Hilltown Pa
Hilltown Pa
For 169.00 more you can get them to weld it on for you.
Re: Expensive 9 inch rears! [Re: moparniac] #1771119
03/04/15 03:21 PM
03/04/15 03:21 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The OP is
Re: Expensive 9 inch rears! [Re: BradH] #1771120
03/04/15 03:23 PM
03/04/15 03:23 PM
Hilltown Pa
Hilltown Pa
For the street guys that don't want a spool.
Re: Expensive 9 inch rears! [Re: 1967dartgt] #1771121
03/04/15 03:31 PM
03/04/15 03:31 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
I paid $80 for a D60 with 3.73 locker from a '79 F350. It has a 30 spline carrier so I can slide my stock axles in after I change the housing ends. I might have $500-600 into it once I buy brakes and gaskets/lube/fittings. If someone doesn't have a welder and alignment bar then I guess there is $150 or so added to have someone do it. If I decide to upgrade to 35 spline I might spend another $600 for axles and a spool.
Not saying everyone should go with a junkyard D60 but it's a decent option for street/strip cars.
Re: Expensive 9 inch rears! [Re: moparniac] #1771122
03/04/15 03:34 PM
03/04/15 03:34 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
The OP is
Ya think...??
If you like drag racing, support your local track.
Re: Expensive 9 inch rears! [Re: CHAPPER] #1771123
03/04/15 07:27 PM
03/04/15 07:27 PM
Q
Quicktree Offline
Quicktree  Offline
Q
hell I have a brand new Strange 9" Nodular with 410 gears and a Lenco billet locker for $1200 cash. cost over $2K
Re: Expensive 9 inch rears! [Re: Quicktree] #1771124
03/04/15 08:47 PM
03/04/15 08:47 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I can see now these are much better than a junkyard Dana. And I like the ability to change the gear ratio at only $1000 a pop. Heck, I think I'll carry 2-3 to suit my needs. So for the initial investment of say roughly $1800 plus extra center sections ($3000) cause they're easy to swap I'll be all set, thanks.
Doug
Re: Expensive 9 inch rears! [Re: Quicktree] #1771125
03/04/15 09:27 PM
03/04/15 09:27 PM
Locomotion Offline
Locomotion  Offline
Both Moser and Strange have COMPLETE race Dana 60s for around $2,000.
Hmmmm, 9" center section or complete Dana 60 rear? Decisions, decisions. Such a difficult decision!
Re: Expensive 9 inch rears! [Re: Locomotion] #1771126
03/04/15 09:30 PM
03/04/15 09:30 PM
Q
Quicktree Offline
Quicktree  Offline
Q
at your power level you could use a 7.25
Re: Expensive 9 inch rears! [Re: Quicktree] #1771127
03/04/15 09:40 PM
03/04/15 09:40 PM
Locomotion Offline
Locomotion  Offline
Yea, those Mopar rears are pretty strong! Even the little ones. But I feel more comfortable with my 8 3/4" or a Dana 60. They look cool too!
But the point is that the new $2,000 Dana 60s will handle just as much HP as your $2,000 center section PLUS the cost of the rest of the rear. ...and probably be faster due to efficiency.
Re: Expensive 9 inch rears! [Re: Locomotion] #1771128
03/04/15 10:09 PM
03/04/15 10:09 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Yep, you're right, proved your point. Every Mopar in the world should have a Dana. Thread closed, problem solved, nothing to see here people, move along........LOL!!!!
Re: Expensive 9 inch rears! [Re: Monte_Smith] #1771129
03/04/15 10:13 PM
03/04/15 10:13 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I think im going to every junk yard and buy up every dana in the nation. I could get rich off these guys
Re: Expensive 9 inch rears! [Re: Quicktree] #1771130
03/04/15 10:34 PM
03/04/15 10:34 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
My as well buy all the 9"s also, sell them to the other side of this posting. make twice as much money.
Re: Expensive 9 inch rears! [Re: rowin4] #1771131
03/04/15 10:36 PM
03/04/15 10:36 PM
Q
Quicktree Offline
Quicktree  Offline
Q
naaa there's plenty of after market race parts.
Re: Expensive 9 inch rears! [Re: Monte_Smith] #1771132
03/04/15 10:39 PM
03/04/15 10:39 PM
Locomotion Offline
Locomotion  Offline
Ford 9" has it's place and obviously it's quite popular in SS and the factory race cars, among others, for many reasons. I'm just trying to take the edge off of Quicktree who thinks that EVERY BRAND of race car in the world should have a Ford 9", even the average bracket racer!
LCOMOTION
UICKTREE
Page 1 of 4 1 2 3 4
