Thoughts on max wedge ported stock castings #177100
12/28/08 04:24 PM
12/28/08 04:24 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Ive run into a semilocal set of stock BB castings that have been opened up to mw size. I really havent paid any attention to the stock castings with MW size runners before. Do the MW size ports on stock castings hurt low lift flow? Do they increase high lift flow that much or is the benefit in intake selection? Any thoughts appreciated.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Thoughts on max wedge ported stock castings [Re: Von] #177101
12/28/08 05:10 PM
12/28/08 05:10 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Are we talking about stock Max Wedge Cast heads, or later 906/452 heads that has been opended up?
Re: Thoughts on max wedge ported stock castings [Re: Bob_Coomer] #177102
12/28/08 06:02 PM
12/28/08 06:02 PM
It usually helps the flow of H2O from the water jacket into the intake or exhaust ports. Did in my case
Re: Thoughts on max wedge ported stock castings [Re: Bob_Coomer] #177103
12/28/08 08:40 PM
12/28/08 08:40 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
906/452 castings
Re: Thoughts on max wedge ported stock castings [Re: Von] #177104
12/28/08 08:50 PM
12/28/08 08:50 PM
SoCal
Brian Hafliger Offline
SoCal
I did a set for myself years and years ago, back in 1991.
I used a 906 casting, and opened it up to max wedge and ran it as high as I could go to right before the spring seat area. Then tapered it down from there.
It made quite a bit of difference. I just cut the ports off of a stock valley pan and silicon'd the edges to the intake manifold. I used an M1 that I also raised the roof all the way into the plenum.
It was alot of work, but in my Charger it picked up 3.5 tenths...and I did mill the heads down from 85cc to 82cc so it wasn't all head work.
This was an 800DP on a flattappet 440.
Car weighted in at 3820lbs. with me!!
It went from 11.72 to 11.38 with only those mods.
Brian
Brian Hafliger
Re: Thoughts on max wedge ported stock castings [Re: Von] #177105
12/28/08 11:58 PM
12/28/08 11:58 PM
Cab_Burge Online work
Cab_Burge  Online Work
Von, be very careful on buying a used set of ported 906 to M.W. intake port size. It is very easy to mess those heads up trying to make them better,(to many valve jobs, cut in the wrong places and so on ) if you really want them take them to a reputable machine shop with a good flow bench and have them tested, post the results on here before buying them to see what the knowleagable head guys on here think of those flow #s first before buying for the heads
Re: Thoughts on max wedge ported stock castings [Re: Cab_Burge] #177106
12/29/08 12:18 AM
12/29/08 12:18 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Good advice Cab. I wouldnt buy a set of used heads without reputable flow numbers.
Re: Thoughts on max wedge ported stock castings [Re: Von] #177107
12/29/08 12:22 AM
12/29/08 12:22 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
is any one looking for a set of MW heads...
have friend who looking to sell a set that she has owned for many years...
Tony
70 AARCuda Vitamin C
Re: Thoughts on max wedge ported stock castings [Re: 70AARcuda] #177108
12/29/08 12:57 AM
12/29/08 12:57 AM
mi.usa
1fast383 Offline
1fast383  Offline
mi.usa
How much $ will determine how interested we are.
Re: Thoughts on max wedge ported stock castings [Re: Von] #177109
12/29/08 01:26 AM
12/29/08 01:26 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Cab , has some good advice Id stay away from those heads unless they were really cheap. Even then, Id be afraid of those heads. As in maybe cracking and hydraulicing your motor.
Imo opening up a 906 head to MW size wont make it Flow any better numbers. But that doesnt mean it wont make the car run any faster as it will have extra port volume.
The choker on the 906 port isnt the opening its the inner throat and short turn. That will dictate the max airflow not the size of the port opening. Whether it be OE or MW size.
Also when porting a old OE head the metal fatigues rather quickly with the beating of the grinder burr. The more you grind/port over the same area the more Fragile/fatigued it becomes.
If you want to see how fragile these OE steel cast heads are. Take a Small ballpeen hammer and start swinging away.
You can bust these cast steel heads to bits, no problem. A over ported port will not only be thin but also serverly fatigued IMO mike
Re: Thoughts on max wedge ported stock castings [Re: 1fast383] #177110
12/29/08 02:01 AM
12/29/08 02:01 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
PM me and i will give you here email and phone number..i dont know what she wants for the parts...
Tony
Re: Thoughts on max wedge ported stock castings [Re: Sport440] #177111
12/29/08 03:11 AM
12/29/08 03:11 AM
SoCal
SoCal
That was pretty much my first thought way back when...but to my surprise the port picked up 12 cfm at .500 lift!
And it slowed the air down and helped the port hang on better above .550 lift.
Brian
Brian Hafliger
