W2 headache #1770950
03/04/15 12:49 AM
03/04/15 12:49 AM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
Do they all take this much grinding? Tons of grinding on the ductile rockers then when you get it to clear the spring and retainer the 3/8 PR is pressed against the side of the PR tube
I am building it for a friend and he wants it to hold up at 8000 RPM so I am a little leary to run a 5/16 PR.
Everyone kept telling me when I build a W2 I won't want to build a SB with anything else but this is a real pain
Re: W2 headache [Re: HotRodDave] #1770951
03/04/15 01:12 AM
03/04/15 01:12 AM
north west LA
W
W2DODGE Offline
W2DODGE  Offline
W
north west LA
8000 RPM will need better parts.
Re: W2 headache [Re: HotRodDave] #1770952
03/04/15 01:29 AM
03/04/15 01:29 AM
USA
B3RE Offline
B3RE  Offline
USA
Hey Dave,
How much lift is he running with the ductile rockers? Depending on this valve lift, you could use a lash cap, get better geometry, and gain some needed clearance. Of course, the pushrod side is gonna be fun with a 3/8 pushrod though.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: W2 headache [Re: B3RE] #1770953
03/04/15 02:33 AM
03/04/15 02:33 AM
Kalispell Mt.
Kalispell Mt.
Starting out with a .590 solid flat tappet. I did have to use a lash cap to get geometry correct and it did help the clearance also. I thought about making an offset block but that would make the PR clearance worse and everything I did with the lash caps I would have to re-do.
Re: W2 headache [Re: HotRodDave] #1770954
03/04/15 11:08 AM
03/04/15 11:08 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Wanting to do 8000RPM with a .590 cam seems odd. No reason to spin it there if it doesn't need it.
Remember RPM Ruins Peoples Motors
68 Barracuda Formula S 340
Re: W2 headache [Re: HotRodDave] #1770955
03/04/15 11:22 AM
03/04/15 11:22 AM
Locomotion Offline
Locomotion  Offline
I've always been leary of much grinding on the rockers to clear the springs/retainers. I've seen too many ductile iron and aluminum rockers that had broken there because of it.
It was many years ago, but I had lot of issues like that too. Blocks could relocate the shafts & rockers away, but also changed the height. Certain offsets/heights were designed to work with certain valve stem heights. But then you also need offset holes in the shafts.
I did use 5/16" pushrods, but had to open up the holes a bit in some cases. Thicker walls are an option for strength.
Are there any beehive springs (for clearance) that would fall into the specs you need? Comp Cams and Pac have some that can get over 400 lbs open. But if it's a flat tappet, you may not need that much. It concerns me over 350 with a flat tappet anyway unless expensive alternative parts are used.
FWIW, I had several W-2 360's with cams between .575" and .590" lift. I don't remember if it was an isolated incident related to a particular cam, but I found that it ran just as well shifting at 6,800 rpm as it did at 7,200. So I settled in at 6,800. It may have been with a set of heads ported with the Mopar Performance template kit. 10.22 @ 130 + in a 2,800 lb Challenger footbraking.
Re: W2 headache [Re: HotRodDave] #1770956
03/04/15 11:27 AM
03/04/15 11:27 AM
USA
B3RE Offline
B3RE  Offline
USA
Assuming you are using a standard length valve, and an .080" lash cap, the geometry ought to be near perfect, unless something is really out of whack. You might be able to get by with a thick walled 5/16th pushrod and save some aggravation. Is this the Mopar 590 cam?
Mike Beachel
Re: W2 headache [Re: B3RE] #1770957
03/04/15 03:47 PM
03/04/15 03:47 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Manton makes an 11/32" pushrod
I used a roller with offset MRL lifters and also used the Hughes BB Victor intake rockers and standard BB exhausts, my pushrods are fairly straight by W2 standards anyway.
WIZE
In Car:
Re: W2 headache [Re: Streetwize] #1770958
03/04/15 04:15 PM
03/04/15 04:15 PM
Kalispell Mt.
Kalispell Mt.
It is the mopar cam, he wants to run it for now and switch to a solid roller after a couple years getting used to the car and working out bugs, letting the wallet recover... Solid rollers are gonna make the problems worse
BTW the bottom end is real nice, SCAT crank, crower 6.5" rods super light pistons, 71 really thick wall block...
Re: W2 headache [Re: HotRodDave] #1770959
03/04/15 10:15 PM
03/04/15 10:15 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I spoke with Terry Manton at length back before he passed when I was putting together my 416 I was running a .690 lift solid roller with springs that had 742lbs over the nose.
My head and rocker combo would not allow a 3/8 push rod on the intake he assured me that his series 3 pushrod 5/16x.118 wall would do just fine and it did.
I shifted at 7800 every shift never a pushrod issue.
Now I did have a short deck height of 9.350 so that kept the pushrod on the short side but that motor is still together running great 5 years later and hundreds of passes.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: W2 headache [Re: HotRodDave] #1976797
12/26/15 10:59 PM
12/26/15 10:59 PM
Kalispell Mt.
Kalispell Mt.
So I am back to working on this tird and got beehive springs to make rocker/retainer clearance so that is no longer an issue.
Back to the PR Tube I got them all to clear but the last one, it went through the port... so where can I get sleeves for the PR holes? I am ordering 5/16 PRs now and gonna sleeve all the PR holes...
After this I am so done with w2s. We bought these heads and rockers together just figuring it would all go together but nooooooo!
PS I wish I could find the angry face guys and hammerin guys and blow torch cartoon guys to let everyone know how frusterated I am with this!
Re: W2 headache [Re: HotRodDave] #1976811
12/26/15 11:12 PM
12/26/15 11:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Hobby centers carry the thin wall brass tubing in
multiple sizes
wave
Re: W2 headache [Re: MR_P_BODY] #1976829
12/26/15 11:28 PM
12/26/15 11:28 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
My local Ace Hardware store stocks it.
http://www.ksmetals.com/26.html
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: W2 headache [Re: pittsburghracer] #1976848
12/26/15 11:49 PM
12/26/15 11:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats the same stuff I get at the hobby shop
wave
Re: W2 headache [Re: HotRodDave] #1976852
12/26/15 11:59 PM
12/26/15 11:59 PM
Kalispell Mt.
Kalispell Mt.
So it looks like the holes are .720 according to my sliding calipers, could I put 3/4 tube in it if I freeze it and heat the head to about 200*?
Re: W2 headache [Re: HotRodDave] #1976857
12/27/15 12:10 AM
12/27/15 12:10 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Why not take them to a machine shop and have the ream to the correct size and install the tubes?
Re: W2 headache [Re: HotRodDave] #1976859
12/27/15 12:15 AM
12/27/15 12:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You wont change it .030 .. drill it undersize and
do a light press with JB Weld on it..I also covered
the ends to make sure they sealed... I actually used
a adjustable reamer to make the finished hole
wave
Re: W2 headache [Re: HotRodDave] #1977172
12/27/15 03:30 PM
12/27/15 03:30 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I've only built a few w2 motors, and it was almost 20 years ago.
It sounds to me like the rockers don't have enough offset. Are you sure you have w2 rockers and not t/a rockers?
I used the "econo" heads with T & D rockers(1.55 ratio) and had to do very little grinding.
Also, I don't think the iron rockers (if not bushed) and 8000rpm are going to get along very well.
Re: W2 headache [Re: HotRodDave] #1977331
12/27/15 07:19 PM
12/27/15 07:19 PM
Cab_Burge Online work
Cab_Burge  Online Work
Which W2 castings are you working on? Race or Econo castings? when I put 9secondPhil W2 motor together years ago with the race W2 heads I don't remember any isuues with the rockers or valve train anywhere confusedIt was a low compression pump gas combination set up for NOS so he could drive it anywhere, it had a custom grind Comp Cams solid lifter cam in it also shruggy It did have the extruded aluminum Crane W2 rockers that Mopar sold back then so maybe that had something to do with the no problems work
Re: W2 headache [Re: HotRodDave] #1977387
12/27/15 08:49 PM
12/27/15 08:49 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I wonder the same thing as Fast68Plymouth. My dad and I just built a W2 headed motor and had no trouble with 3/8" pushrods on a solid roller with around a .700 lift. This was with Erson 1.6 rockers on non econo heads.
