1970 440 a/c brackets #177092
12/28/08 04:16 PM
12/28/08 04:16 PM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
I have a 1970 440 Challenger I purchased in pieces and I am trying to figure out what brackets I need and how they are set up on the engine. The power steering is ok and I have the correct compressor. What I am trying to find out is how the alternator and the idler bolt up to the head and the waterpump housing. I have attached a picture of the brackets that I have but do not know if any of them are correct or what I need. Can anyone help? Thanks, Gerry.
Re: 1970 440 a/c brackets [Re: GKMOPAR] #177093
12/28/08 04:24 PM
12/28/08 04:24 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Here's a previous thread about the big block A/C brackets and idler... link And this site has some good info and also sells any parts you may be missing.. http://www.bouchillonperformance.com/BPEalternatorbracketkits.asp
Re: 1970 440 a/c brackets [Re: screamindriver] #177094
12/28/08 05:15 PM
12/28/08 05:15 PM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline
Not the best picture, but hopefully it will help.
Re: 1970 440 a/c brackets [Re: GKMOPAR] #177095
12/28/08 08:48 PM
12/28/08 08:48 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If you don't already know it the bottom adjuster arm in your picture is extra..
Re: 1970 440 a/c brackets [Re: 1_WILD_RT] #177096
12/28/08 11:48 PM
12/28/08 11:48 PM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
I just went out and tried the setup. It looks like I have everything I need! Thanks for your help! Gerry.
Re: 1970 440 a/c brackets [Re: GKMOPAR] #177097
12/29/08 01:23 PM
12/29/08 01:23 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
You didn't show it in your photo, but there is a plastic coated metal bracket that mounts towards the top and holds the neater hoses away from the fan. It looks like a single blade of a fan.
You can somewhat see it in one of the photos.
Also, does anyone know if anyone reproduces the tensioner pulley? Or maybe just restores the bearing?
Re: 1970 440 a/c brackets [Re: RP's R/T's] #177098
12/29/08 06:59 PM
12/29/08 06:59 PM
Harrisburg, Pa.
Harrisburg, Pa.
Are you asking about the A/C idler pulley ??? Here's one about half way down the page... ... idler
Re: 1970 440 a/c brackets [Re: screamindriver] #177099
12/30/08 01:46 PM
12/30/08 01:46 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
Yea.
I was hoping for one that was more original (didn't have the bolt running through the middle). These work, and will be my fall back.
