Flex plate sensor?
#1770896
03/03/15 11:56 PM
03/03/15 11:56 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
What is the sensor aimed at the flex plate on a '94 1/2 ton 4x4?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Flex plate sensor?
[Re: moretoys]
#1770898
03/04/15 01:22 AM
03/04/15 01:22 AM
dfsmopars
Kentucky
Thanks for the answer. I helped a friend pull a trans tonight. Does the crank sensor have a long life? That thing is in a tight spot and I'd hate to have to replace it with the trans back in. Do those sensors usually last the life of the vehicle?
[Re: dfsmopars]
#1770899
03/04/15 09:57 AM
03/04/15 09:57 AM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
Make sure that you don't bump the crank sensor on removal or installation of transmission. It doesn't take much of a bump to hurt it....
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: dfsmopars]
#1770900
03/04/15 11:14 AM
03/04/15 11:14 AM
Posts: 178 Tidewater, VA
TMCCuda
Tidewater, VA
I had one last 280,000 mi on my 94 318. The only reason I had to replace it is I broke it while swapping to a built 5.9L. I don't think it's a common problem area. Now the crank sensor on a 4.0L Cherokee is a different story.
1970 Plymouth Barracuda
1994 Ram 1500 4x4 5.2L
2004 Ram 1500 4x4 5.7L Quad Cab
