Flex plate sensor? #1770896
03/03/15 11:56 PM
03/03/15 11:56 PM
Kentucky
dfsmopars Offline OP
Kentucky
What is the sensor aimed at the flex plate on a '94 1/2 ton 4x4?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Flex plate sensor? [Re: dfsmopars] #1770897
03/04/15 12:08 AM
03/04/15 12:08 AM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
crank sensor
Re: Flex plate sensor? [Re: moretoys] #1770898
03/04/15 01:22 AM
03/04/15 01:22 AM
Kentucky
Kentucky
Thanks for the answer. I helped a friend pull a trans tonight. Does the crank sensor have a long life? That thing is in a tight spot and I'd hate to have to replace it with the trans back in. Do those sensors usually last the life of the vehicle?
Re: Flex plate sensor? [Re: dfsmopars] #1770899
03/04/15 09:57 AM
03/04/15 09:57 AM
Ringtown, Pa.
Dartsport540 Online boogie
Dartsport540  Online Boogie
Ringtown, Pa.
Make sure that you don't bump the crank sensor on removal or installation of transmission. It doesn't take much of a bump to hurt it....
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Flex plate sensor? [Re: dfsmopars] #1770900
03/04/15 11:14 AM
03/04/15 11:14 AM
Tidewater, VA
TMCCuda Offline
TMCCuda  Offline
Tidewater, VA
I had one last 280,000 mi on my 94 318. The only reason I had to replace it is I broke it while swapping to a built 5.9L. I don't think it's a common problem area. Now the crank sensor on a 4.0L Cherokee is a different story.
1970 Plymouth Barracuda 1994 Ram 1500 4x4 5.2L 2004 Ram 1500 4x4 5.7L Quad Cab
Re: Flex plate sensor? [Re: Dartsport540] #1770901
03/04/15 05:16 PM
03/04/15 05:16 PM
Kentucky
Kentucky
Yea I didn't know it was there when we pulled the trans but I am always careful pulling a trans so I think it is in good shape. I think the rubber seal around it is a pretty good cushion. I guess things changed somewhere after '94 because I installed a 2002 A518 in a '72 Charger and it did not have a notch in the housing for the sensor.
