Soaking a hinge to free it up #1770753
03/03/15 09:27 PM
03/03/15 09:27 PM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
I got these hinges and I would like to soak them to free them up, what should I use?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Soaking a hinge to free it up [Re: AZ_A12_BEE] #1770754
03/03/15 09:43 PM
03/03/15 09:43 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Are they rusted ? I would go evaporust or kroil if you can find it.
Re: Soaking a hinge to free it up [Re: ademon] #1770755
03/03/15 09:45 PM
03/03/15 09:45 PM
Dreaming of the 808
Dreaming of the 808
Mike not frozen but they have a sticky spot or two, I would really like them to move freely, the are for the front window of my 37
Re: Soaking a hinge to free it up [Re: AZ_A12_BEE] #1770756
03/03/15 10:34 PM
03/03/15 10:34 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Can you drive the pin out? Then you could clean all the pieces & put it back together.
Are they bent? That would cause tight spots too.
Re: Soaking a hinge to free it up [Re: RestoRick] #1770757
03/03/15 10:37 PM
03/03/15 10:37 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Jsta' lite warm up with a propane torch and some WD40 should do the trick
Re: Soaking a hinge to free it up [Re: dOrk !] #1770758
03/03/15 10:42 PM
03/03/15 10:42 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
From the pic they look a bit bent, not much maybe just the pic ???
Re: Soaking a hinge to free it up [Re: ademon] #1770759
03/03/15 10:52 PM
03/03/15 10:52 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Lube/unstick = 50/50 mix of acetone and ATF or PB Blaster.
Derust = Evaporust
Make them smooth and last another 50 years = disassemble and machine to straight smooth bores and a fresh, straight pin.
I'm looking into this for my van hinges, but the side and rear door hinge halves on the doors are riveted. I'll have to machine in place or disturb the rivets, which I'd prefer not to do...
Re: Soaking a hinge to free it up [Re: AZ_A12_BEE] #1770760
03/04/15 01:45 AM
03/04/15 01:45 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I agree with the kroil. Amazon has it, or buy direct from kano labs.
Re: Soaking a hinge to free it up [Re: AZ_A12_BEE] #1770761
03/04/15 08:15 PM
03/04/15 08:15 PM
Lakewood, WA
rick@laysons Offline
Lakewood, WA
Mix diesel fuel and ATF in a 50-50 ratio....works like a champ!
Re: Soaking a hinge to free it up [Re: rick@laysons] #1770762
03/04/15 08:53 PM
03/04/15 08:53 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
GIBBS... can get it in spray cans or gallon container...Farmers use it to free up seized equipment left out during winter months...Ive used it on antique firearms with no damage to the original finish..
Looking at the pin gaps they do look bent..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
