Re: XV level II front suspension. Who is using it?
[Re: BergmanAutoCraft]
#1770425
03/28/15 12:28 PM
03/28/15 12:28 PM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
I understand that, Peter, but if you look a couple posts back, you'll see that I already have a set of SPC arms here. Therefore, I would like to know how much to make this upgrade...
2 Demons...no, not my kids!
[Re: 4speeds4me]
#1770428
03/28/15 08:01 PM
03/28/15 08:01 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Delrin bushings are some of the easiest things to machine. That stuff turns like a lathe operator's dream. If he can't supply then, I can probably remove the sleeves from yours and pop delrin bushings in without too much fuss.
[Re: feets]
#1770429
03/29/15 03:23 AM
03/29/15 03:23 AM
4speeds4me
Thanks for trying, guys. Supercuda- I already own SPC arms. Not paying $395USD for another set to replace the brand new ones I have here just to have different bushings. 67autocross- Unless I missed it, the only Delrin bushings I saw listed were for the LCAs, not UCAs. feets- At the rate things are going getting an answer, that might be my only option!
[Re: 4speeds4me]
#1770431
03/30/15 04:21 PM
03/30/15 04:21 PM
feets
Senior Management
Senior Management
Irving, TX
I made replacement LCA bushings and sleeves to fit larger bolts in my bro-in-law's RZR. They've held up to a couple years for racing.
[Re: autoxcuda]
#1770435
04/05/15 12:21 PM
04/05/15 12:21 PM
Posts: 22,728 Bitopia
jcc
Bitopia
I understand that its easy to get feelings hurt, but we are supposed to be grown ups, nobody is perfect, everything can be made better, and if iI don't make a critical comment, some else or your competitor will, and good engineering design is not arm chair engineering, and most manufacturers leave because they find it easier to close their ears then open their eyes. Yes, this is a tough crowd, and running off any manufacturer helps no one, and is never mine nor I suspect anyone else'e intent. Making a better product is. In my case my suggestions require very little effort to implement other then maybe eating at the absolute worst case a little crow and agreeing a slight change makes for an improvement. I don't see the problem. Wanting all glory and no heat for a product is not realistic. We want you to succeed, if you are listening.
Yes, but some don't act like grown up. And just want to rudely impolitely nit pick and over scrutinize any ideas that are not their own.
And refuse to believe there are possibly two ways to get to the same place (maybe even three?).
With such a blistering indictment, and not even few examples in this thread to support the above claim, its hard to assume it has merit.
