Page 1 of 3 1 2 3
Sonic check frustrations **Updated** #1769713
03/03/15 01:35 AM
03/03/15 01:35 AM
W. Kentucky
justinp61 Offline OP
W. Kentucky
Update: I got the block checked today, all cylinders looked good on minor and major thrust sides. The non thrust sides were a different story, four cylinders under .100", #1 .091", #2 .090" #3 .087" and #5 .092". It's at 4.08 now and needs to go 4.10". Paper weight?
Are machine shops that offer sonic checking the minority? I just bought a R1 block that's 4.08", one of the cylinders has a spot in it. The deal is that it will take a 4.1" bore or I get a refund. My problem is that I can't find a local machine shop that can sonic check the block. Most likely I'll have to buy the instrument or go to Nashville TN to have my block checked out.
I know I'm not in the race hub of the US but none of the machine shops offer this service. The instrument is around $1200, it seems to me it would pay for it's self.
Anyone else run into this?
Re: Sonic check frustrations [Re: justinp61] #1769714
03/03/15 01:41 AM
03/03/15 01:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I just bought a new sonic checker for $220... I'm
not home yet to test it out
EDIT
this is what I bought but with the options
http://www.ebay.com/itm/TM8812-Digital-U...=item4d2e75554f
Re: Sonic check frustrations [Re: MR_P_BODY] #1769715
03/03/15 01:56 AM
03/03/15 01:56 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Gary Stanton in Nicholasville will have one...Not sure how close that is.
Todd
Re: Sonic check frustrations [Re: MR_P_BODY] #1769716
03/03/15 02:18 AM
03/03/15 02:18 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
EDIT
P ......how wide is the head on that probe ? ... I got one on eBay toooo .... but the probe width is tooo wide to read smaller OD chassis tubing or the ID of a cyl wall.
Re: Sonic check frustrations [Re: dOc !] #1769717
03/03/15 02:30 AM
03/03/15 02:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
EDIT
Its 8mm.. I want to test it when I get home to see
if I need to grind the probe housing.. but at 8mm
I dont think I will
Re: Sonic check frustrations [Re: MR_P_BODY] #1769718
03/03/15 02:51 AM
03/03/15 02:51 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
I dont think I will
.315 ? ... I think that is toooo wide. I think mine is .250 and my chassis guy says(IIRC) that it needs to be .125 or so to fully contact the material being measured.
Re: Sonic check frustrations [Re: MR_P_BODY] #1769719
03/03/15 03:02 AM
03/03/15 03:02 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
reeeeeeaaaaaaaaaaly? (in Jim Carrys voice)
I have had 3 5.9 mag blocks at the machine shop across the street for a month now waiting to be tested for $75 a pop
Re: Sonic check frustrations [Re: dOc !] #1769720
03/03/15 03:08 AM
03/03/15 03:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont think I will
It gave a min bore spec that it could read.. it was
in the 3" range... if I need to grind the housing I will
it only has a single bar in the center for the signal
EDIT
I know the meter I use to bring home from work had a
larger probe than a 1/8"(.125).. I'm sure it was over
a 1/4"(.250) and it read great... did you ever try yours
Re: Sonic check frustrations [Re: MR_P_BODY] #1769721
03/03/15 12:32 PM
03/03/15 12:32 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I dont think I will
I purchased mine w/ a 6mm diameter flat-face probe and was the smallest they offered. I contacted the vendor about buying a second at the same time, because I suspected I was going to have to hand-fit one of them to read the curved surface of a cylinder bore properly... and I was right.
I spent some time w/ 600-grit wet-or-dry profiling the face of the probe to have a concave surface that appeared to seat properly against the inside of my 4.375" tapered ring compressor.
Re: Sonic check frustrations [Re: BradH] #1769722
03/03/15 12:44 PM
03/03/15 12:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont think I will
I was gonna spin up a 4" ID tube as a test piece
and contour to it.. I'll make it fit a 3.9" that
would be the smallest ID I'd measure..it should be
fine on OD
Re: Sonic check frustrations [Re: MR_P_BODY] #1769723
03/03/15 03:02 PM
03/03/15 03:02 PM
dogdays Offline
dogdays  Offline
Uh, Brad, that's convex. Concave would be for measuring the outside of a cylinder.
R.
Re: Sonic check frustrations [Re: dogdays] #1769724
03/03/15 04:03 PM
03/03/15 04:03 PM
BradH Offline
BradH  Offline
R.
Correct; wrong term, right modification. /
Re: Sonic check frustrations [Re: MR_P_BODY] #1769725
03/03/15 05:12 PM
03/03/15 05:12 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
EDIT
Try mine ? ... reads dead-on(in mm only) on flat stock but not on a curved piece. I have been in touch with the seller trying to see if I can adapt another smaller probe to it ... but they don't know ...yet.
Re: Sonic check frustrations [Re: dOc !] #1769726
03/03/15 07:21 PM
03/03/15 07:21 PM
Q
Quicktree Offline
Quicktree  Offline
Q
none of the basic Chevy/ford shops around here have sonic checkers. guess they don't have that issue.
Re: Sonic check frustrations [Re: Quicktree] #1769727
03/03/15 07:25 PM
03/03/15 07:25 PM
BradH Offline
BradH  Offline
Ignorance is bliss... 'til the bliss starts to leak through the crack in the cylinder wall.
Re: Sonic check frustrations [Re: justinp61] #1769728
03/03/15 07:32 PM
03/03/15 07:32 PM
an8sec70cuda Offline
I had a real hard time finding one around here to check my World hemi block a while back. Finally found one at a smaller race engine shop (Naylor's) about an hour and a half drive away.
Even Gene Fulton and PAR don't have a sonic checker...said they don't need one for anything they do. Naylor said he only uses his on certain cylinder heads for round track classes.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Sonic check frustrations [Re: Quicktree] #1769729
03/03/15 07:32 PM
03/03/15 07:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I know my buddy has real thick walls on his 460..
at least twice what we play with.. he can safely go
.120 over
Re: Sonic check frustrations [Re: MR_P_BODY] #1769730
03/03/15 08:38 PM
03/03/15 08:38 PM
dogdays Offline
dogdays  Offline
Bigblock chevies, at least the MarkIV which are the original 396s, 427s and 454s, could usually go 0.125 over with no problem. I'm not sure about the 402s, because they might have been built on the 396 cores but bored out a little.
On the other hand 400 and smaller ford engines are quite thin in the walls, at least in the Cleveland and 335 families, and on many they were done at 0.030 over.
The 385 family, 429 and 460s, had thicker walls and blocks were quite stout.
R.
Re: Sonic check frustrations [Re: MR_P_BODY] #1769731
03/03/15 08:39 PM
03/03/15 08:39 PM
White House,TN
stroked470 Offline
stroked470  Offline
White House,TN
I know a guy local that has a BHJ sonic checker. He checked a couple of 340 blocks for me. Let me see what he would charge to do one.
Re: Sonic check frustrations [Re: stroked470] #1769732
03/03/15 08:46 PM
03/03/15 08:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use to pay $75 for a sonic job... he gave me 64
readings per cyl.. then I started bringing home the
sonic tester from work and did my own... but since
I retired I havent done any... but I still have all
the blocks that I tested... except one... it blew up
due to a rod tearing in half... damn Viper rods
Page 1 of 3 1 2 3
