Comp Cams cam button #1769676
03/03/15 01:11 AM
03/03/15 01:11 AM
State, country, etc.
gss Offline OP
gss  Offline OP
I can't find any information on how they are installed. What holds them on?
Re: Comp Cams cam button [Re: gss] #1769677
03/03/15 01:21 AM
03/03/15 01:21 AM
Cab_Burge Online work
Cab_Burge  Online Work
It depends on which motor and which cam gear, IE single bolt or three bolts on BB, Hemi or if your working on a L.A SB motor OOPS, not needed on LA motors with the stock cam retaining plates
Re: Comp Cams cam button [Re: gss] #1769678
03/03/15 02:03 AM
03/03/15 02:03 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The timing cover holds them in !!!
Re: Comp Cams cam button [Re: Cab_Burge] #1769679
03/03/15 02:07 AM
03/03/15 02:07 AM
gss Offline OP
gss  Offline OP
It's a 3 bolt Comp Cams XR280R
Re: Comp Cams cam button [Re: gss] #1769680
04/01/15 12:44 AM
04/01/15 12:44 AM
gss Offline OP
gss  Offline OP
Well this is starting to get a little aggravating. The cam/lifter/timing gear set I got from Comp cams didn't include the required cam button or the 3 cam bolts. So I get the recommended button from CC and the smallest head cam bolts I can find from ARP and the button still doesn't fit without hitting the bolt heads. Am I expected to put this button in a lathe and turn in down? There has got to be a better solution. What do you guys do with these?
Re: Comp Cams cam button [Re: gss] #1769681
04/01/15 01:30 AM
04/01/15 01:30 AM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
Allen headed bolts worked just fine. Just finished one this week. The real problem is clearance. I like .004 to.006 cam end play. I install the cam with button and gear in place and nothing else. Then I bolt on water pump housing with gaskets in place using a feeler gauge I find the clearance between back of housing and button. Measure thickness of timing cover then find a washer that when tack welded to cover will give the clearance I want. Aluminum cover will not flex but steel cover will flex a lot.
Re: Comp Cams cam button [Re: Cuda367] #1769682
04/01/15 11:53 AM
04/01/15 11:53 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The only bolts I've found that a) have a narrow enough head for a button to fit and b) fit under the cover without hitting are called "low head socket head cap screws". These look like an allen head cap screw but are about half the height. You won't find these at Lowes or Home Depot - you'll need to go to a place that specializes in nuts and bolts.
Any time I tried, standard allen head bolts didn't fit under the cover.
Re: Comp Cams cam button [Re: gss] #1769683
04/01/15 11:59 AM
04/01/15 11:59 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The topic was well covered a while back. Do a search on "cam walk"
Re: Comp Cams cam button [Re: Stanton] #1769684
04/01/15 04:46 PM
04/01/15 04:46 PM
gss Offline OP
gss  Offline OP
There is some good info in that thread, thanks
I tried allen head bolts but they only fit if I leave out the washers. I will check with Fastenal for low allen head bolts.
Re: Comp Cams cam button [Re: gss] #1769685
04/01/15 05:27 PM
04/01/15 05:27 PM
AndyF Offline
AndyF  Offline
It is all application specific. I think most engine builder come up with a combination that works for them. I used to use Hex-a-just timing sets with my own cam button and ARP bolts. But as soon as you switch brands you run into issues. Everyone builds their stuff to slightly different dimensions. Typical hot rodding problem.
Re: Comp Cams cam button [Re: AndyF] #1769686
04/01/15 06:10 PM
04/01/15 06:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Ditch the washers.
Re: Comp Cams cam button [Re: Stanton] #1769687
04/02/15 02:07 AM
04/02/15 02:07 AM
gss Offline OP
gss  Offline OP
After taking a closer look, even after removing the washers, the button still hits the ARP bolts. Allen head bolts are even larger in diameter than the ARP bolts. If someone here has installed a Comp Cams nylon button, I would like know how you cleared the bolts.
Re: Comp Cams cam button [Re: gss] #1769688
04/02/15 09:05 AM
04/02/15 09:05 AM
The Great White North
RAMM Offline
RAMM  Offline
Just went through this last week. Had to turn down the button in my lathe. PITA for an issue that should have been solved 20+ years ago. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Comp Cams cam button [Re: gss] #1769689
04/02/15 11:49 AM
04/02/15 11:49 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
I went through the same thing on the first one I did. I turned the button around and machined(actually did it with drill and bench grinder when I didn't have access to a lathe) the big end to fit the timing gear and faced it so the large end step goes flush with the face of gear. Then the bolts and washers capture the button so it can't fall out. Now, I keep a 1" diameter piece of Delrin acetyl plastic around and make them as needed. Done a couple since. I machine the cover side of button small enough so there is no problem with bolt or washer interference. Like said, I did the first one with a drill and grinder. Not too sterile but that motor has been thrashed on with a ton of nitrous and still together sitting on the floor ready for it's next venture. Sorry, don't have a pic.
P.S. As memory serves on that first one, the small end was too big to chuck in drill so I drilled a 1/4 inch hole through the center of the button as straight as possible, then pressed the appropriate size drill bit in to serve as a mandrel and worked slow. Again, not ideal but did what I did. For the others, I used a lathe, much nicer
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Comp Cams cam button [Re: RAMM] #1769690
04/02/15 11:51 AM
04/02/15 11:51 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
It doesn't have to be pretty ... hit it with a grinder or whatever. Nylon will not wear unless the contact surface (the timing cover) is rough so it doesn't matter if the end is round. You're likely going to have to grind the end to get the right clearance anyway.
Re: Comp Cams cam button [Re: Stanton] #1769691
04/02/15 12:41 PM
04/02/15 12:41 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
just take a die grinder and a burr and clearance the 3 spots where it hits the bolts. not a big deal.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Comp Cams cam button [Re: 68 HEMI GTS] #1769692
04/05/15 11:13 PM
04/05/15 11:13 PM
gss Offline OP
gss  Offline OP
That is what I ended up doing. End play is .012". If I leave the gasket out, then I measure .009". I am surprised it is that loose. I would think they would make them oversize so they can be cut down for the desired end play. I'd rather not dimple the timing cover or weld to the inside so I may just go with the .012". Max end play is usually around .010" but I don't see another .002" causing problems. What do ya think?
Re: Comp Cams cam button [Re: gss] #1769693
04/06/15 11:34 AM
04/06/15 11:34 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Cut a small piece of the appropriate thickness of feeler gauge and put it in behind the button. But .012 isn't the end of the world !!
Re: Comp Cams cam button [Re: Stanton] #1807230
04/19/15 09:13 PM
04/19/15 09:13 PM
gss Offline OP
gss  Offline OP
Ok finally have some time to get back to this engine build.
From what I have read, it sounds like I need to fill the gap between the water pump and the timing cover to keep the cam from bowing out the timing cover. I could tack on some sort of metal spacer to the timing cover with a MIG welder. Would that create some distortion that would alter the cam end play?
It wouldn't take much to mess it up when we are talking a few thousandths. Would a little duraglass or epoxy putty between the water pump and timing cover work?
Re: Comp Cams cam button [Re: gss] #1807267
04/19/15 10:14 PM
04/19/15 10:14 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Absolutely !! Stick a piece of saran wrap to the timing cover first so it only sticks to the water pump.
