Page 2 of 3 1 2 3
Re: Electric fuel pump push fuel through a mechanical pump [Re: Dr Dave] #1769597
03/04/15 05:10 AM
03/04/15 05:10 AM
Chilliwack B.C. Canada
RUNCHARGER Offline OP
My plan is to loop off at the sending unit, build a bracket that bolts to the tie down attachments (E body) that mounts a 110 GPH electric pump and use the stock 3/8 fuel line up to the HP mechanical pump. All the repro stainless steel fuel lines will be uncut and if I have to run the electric pump all the time that's what I'll do but it sounds like I'll be able to just use it for a cold start and maybe when using WOT in 3rd and 4th. I'll let everyone know after I test it. I'll tie strap a fuel pressure gauge to the cowl when I first install the extra pump.
Sheldon
Re: Electric fuel pump push fuel through a mechanical pump [Re: RUNCHARGER] #1769598
03/04/15 06:50 AM
03/04/15 06:50 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
If the engine just will not start unless the bowls are hand primed, that's one thing - I would certainly fix that issue.
But I never understand why people want a stone cold engine that has sat even overnight to start instantly in the first couple rotations. Pretty good chance that all the oil has drained back into the pan, possibly draining the oil passages and the oil filter. There is also the possibility of lifters bleeding down. If they have sat overnight, I rarely attempt to fire any performance engine until I've cranked it and seen oil pressure. IMO an engine that needs to crank 10 seconds or so on that first startup after sitting any length of time is actually doing itself a favor and priming the oil system before it starts, and eliminating any possible dry startup damage. Many hydraulic cammed engines will sound totally different on startup if you "pre-lube" them first, since it gives the lifters on open lobes that have bled down a little a chance to pump up fully and "tighten" the valve train up.
Just a little food for thought about starting that engine that has sat for a while - do you REALLY want it to start first roll?
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Electric fuel pump push fuel through a mechanical pump [Re: Evil Spirit] #1769599
03/04/15 02:04 PM
03/04/15 02:04 PM
Dr Dave Offline
Dr Dave  Offline
I'm mostly concerned about cam lobe and lifter face wear on cranking without rapid startup.
Re: Electric fuel pump push fuel through a mechanical pump [Re: Dr Dave] #1769600
03/04/15 02:33 PM
03/04/15 02:33 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
My root beer GTX would crank almost 2 minutes with the factory pump before it got fuel to fire off after sitting.
No thanks, I'll take the rapid fire off every time. The 440 in my blue GTX with solid lifter cam was assembled in 92 or 93 and is still kicking ass. Long crank times are not good for a number of components.
"I think its got a hemi"
Re: Electric fuel pump push fuel through a mechanical pump [Re: Evil Spirit] #1769601
03/04/15 08:54 PM
03/04/15 08:54 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Absolutely, its a lot easier on the starter and the oil pressure comes up faster. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Electric fuel pump push fuel through a mechanical pump [Re: astjp2] #1769602
03/04/15 10:14 PM
03/04/15 10:14 PM
Camshaft and lifters are what I am concerned about as well. Solid lifters so they don't bleed down and I don't rev it more than I have to when cold. It cranks for at least 1 minute before firing, that isn't good for anything.
Sheldon
Re: Electric fuel pump push fuel through a mechanical pump [Re: RUNCHARGER] #1769603
03/04/15 10:24 PM
03/04/15 10:24 PM
IN
ahy Offline
ahy  Offline
IN
Sheldon
In general the electric pump will not flow fuel when turned off. The mechanical pump will not be able to "suck" through it. An electric pump bypass line with check valve is needed to allow the engine to operate with electric pump off. I used a brass check valve from the hardware store on my truck... more compact automotive type valves are available from Summit and others.
Re: Electric fuel pump push fuel through a mechanical pump [Re: ahy] #1769604
03/04/15 10:47 PM
03/04/15 10:47 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Sheldon
Sorry to disagree, but the mech pump WILL pull through an elec pump. I have a Holley pump mounted by the tank that only runs when switched on. 99% of time the mech pump runs the Cuda pulling fuel through the elec pump. Been that way for years now. And this is the second or third car I have plumbed like that.
Just sayin'.
Master, again and still
Re: Electric fuel pump push fuel through a mechanical pump [Re: ahy] #1769605
03/04/15 10:53 PM
03/04/15 10:53 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I have been doing it for 20+ years.
Others have chimed in not just the Carter pumps allow this too.
Re: Electric fuel pump push fuel through a mechanical pump [Re: Dr Dave] #1769606
03/04/15 11:36 PM
03/04/15 11:36 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
Please let me know what you come up with. I have a similar setup, 528", dual quads, shaker, not easy to prime the carbs and want to do something with an electric pump.
X2 no shaker here but I too would like to add a electric pump to prime for starts due to evaporation. I'm running a 528 hemi with dual quads and solid lift cam. I have extended crank times after the car has sat for longer periods.
Re: Electric fuel pump push fuel through a mechanical pump [Re: HEMIDOG 70] #1769607
03/05/15 04:33 AM
03/05/15 04:33 AM
Dr Dave Offline
Dr Dave  Offline
Ok, looks like whoever puts this together best is in business! Let us know what you did, what you used, heck, I will buy your "kit"!
Re: Electric fuel pump push fuel through a mechanical pump [Re: DaveRS23] #1769608
03/05/15 11:55 AM
03/05/15 11:55 AM
PA
Jack Zupan Offline
Jack Zupan  Offline
PA
Just sayin'.
Same here, Carter pump plumbed straight to the mechanical pump.
Re: Electric fuel pump push fuel through a mechanical pump [Re: Jack Zupan] #1769609
03/05/15 03:50 PM
03/05/15 03:50 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I have a Carter pump plumbed before the mechanical and I ended up bypassing the mechanical because at speeds over 50 mph the car starved for fuel.
Re: Electric fuel pump push fuel through a mechanical pump [Re: rapom] #1769610
03/05/15 04:25 PM
03/05/15 04:25 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
When I put a BB in my 91 Dakota, I left the stock electric pump in place. I only got a couple miles from home before the engine ran out of gas. Removing the electric pump from the system fixed it. Maybe a mechanical pump will pull through SOME electric pumps but they won't pull through ALL of them.
Re: Electric fuel pump push fuel through a mechanical pump [Re: rapom] #1769611
03/05/15 05:42 PM
03/05/15 05:42 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
What kind of mechanical? I can hit about 85-90mph sustained speed before I see the O2 drop off.
Re: Electric fuel pump push fuel through a mechanical pump [Re: DaveRS23] #1769612
03/05/15 06:15 PM
03/05/15 06:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
As I stated earlier, not true on some pumps...Carters in particular.
Re: Electric fuel pump push fuel through a mechanical pump [Re: gdonovan] #1769613
03/05/15 08:07 PM
03/05/15 08:07 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Just a new stock mechanical pump which worked just fine without the electric pump. I just got tired of prolonged cranking the car to start it. Kind of embaressing when at a car show.
Re: Electric fuel pump push fuel through a mechanical pump [Re: John_Kunkel] #1769614
03/05/15 08:23 PM
03/05/15 08:23 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I have a Carter pump, no problem.
Re: Electric fuel pump push fuel through a mechanical pump [Re: gdonovan] #1769615
03/06/15 06:22 PM
03/06/15 06:22 PM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
For the guys that have used this method of using both electrical and mechanical pumps, did it solve any vapor lock issues? Anytime my car gets to near 200 deg it runs like crap. The best we can buy here is the 91 octane junk.
Re: Electric fuel pump push fuel through a mechanical pump [Re: gdonovan] #1769616
03/06/15 07:19 PM
03/06/15 07:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You must have a vane-type pump, Carter gear rotor pumps are different:
"IMPORTANT NOTE:
When using a gear rotor type pump....
These pumps cannot be used as a secondary unit ie, on a dash switch. They MUST be wired to run continuously from the IGN circuit as your PRIMARY and ONLY PUMP.
This pump type uses a DRIVEN gear and a RING gear to create a positive displacement and force fuel through to the carb. The gearing is similar to your oil pump. They do NOT have any check valves like a mechanical fuel pump, thus if they aren't running, you cannot DRAW fuel through them via a mechanical pump, etc ( at least, enough to have the engine remain running)."
Page 2 of 3 1 2 3
