Correct 340 Oil Pan #176960
12/28/08 09:48 AM
12/28/08 09:48 AM
NY
old340dog Offline OP
NY
I beginning to buy parts for my 340 motor rebuild. I've got a 73 Duster 340. I want to replace the oil pan since I noticed it was pretty rusty, so I figure is a good time to replace it during the rebuild. The car is in storage presently, so I can't get a look at the oil pan. But I've noticed there are rear sump and front pump styles availible.Does someone know which one I need to order for my car? Want to make sure I have the correct one before I get started.
thanks,
old340dog
Re: Correct 340 Oil Pan [Re: old340dog] #176961
12/28/08 05:09 PM
12/28/08 05:09 PM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline
The correct pan would be a center sump. Readily available, and pretty cheap.
Re: Correct 340 Oil Pan [Re: Barnabas_Kriss] #176962
12/28/08 08:46 PM
12/28/08 08:46 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Re: Correct 340 Oil Pan [Re: 69Cuda340S] #176963
12/28/08 08:51 PM
12/28/08 08:51 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
yes
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
