Page 1 of 3 1 2 3
Electric fuel pump push fuel through a mechanical pump #1769577
03/02/15 11:08 PM
03/02/15 11:08 PM
Chilliwack B.C. Canada
RUNCHARGER Offline OP
Enough's enough with this crappy fuel we have today. I am not running my cars for one more season having to prime the carbs by hand anymore.
School me on electic pumps, I would like to install an electric fuel pump in both cars just to prime the darn carbs after sitting. I would just as soon keep the mechanical pumps for when the cars are actually running as I don't need the electric pump noise.
Will the electric pump push fuel through the mechanical pump when the engine is not running?
The way I see it I can mount the electric pump parrallel to the regular fuel line near the tank where it's supposed to be or in parrallel to the mechanical pump but that's not where an electric pump is supposed to be. I plan on going parralel either at the back or the front with a check valve in the other line to prevent it pumping backwards back to the tank.
Sheldon
Re: Electric fuel pump push fuel through a mechanical pump [Re: RUNCHARGER] #1769578
03/02/15 11:24 PM
03/02/15 11:24 PM
No cuz one valve has to be closed when the other is open, tho an elec pump would likely pressurize the mech pump sufficiently so you wouldn't need to hand prime anymore. (& a mech pump will pull fuel thru the elec pump even if the elec pump ain't running) so you might be able to use the elec to help prime it tho I ain't sure if the elec would up the psi at the carb enough to need a reg. Consider this a BTT & wait for experienced others to chime in
Re: Electric fuel pump push fuel through a mechanical pump [Re: RUNCHARGER] #1769579
03/03/15 02:49 AM
03/03/15 02:49 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
yes a elect pump wll push fuel through a mech pump .
i have had mine that way for years .
drain holley change jets hit switch ad refill carb before starting engine .
1 problem in hot weather mech pump will sometimes not pull enough fuel through elec pump for climing steep grades or w o t operation in which case i flip the on switch and prob solved .
Re: Electric fuel pump push fuel through a mechanical pump [Re: calrobb2000] #1769580
03/03/15 02:56 AM
03/03/15 02:56 AM
yes a elect pump wll push fuel through a mech pump.
Ahhh I learned something today
Re: Electric fuel pump push fuel through a mechanical pump [Re: RapidRobert] #1769581
03/03/15 02:56 AM
03/03/15 02:56 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Something is wrong if you're having to prime the carb everytime you start your car. The carb should have gas in the fuel bowl without needing the pump to fill it each time. I can let my car sit for a month or more, and it fires right up with no choke, my setup is just a Carter street pump feeding a Holley double pumper. The question you should be asking is why is my carburetor empty and where is the fuel thats supposed to be in it going?
My 2-cents says you've got other problems. I wouldn't be suprised if you're dealing with a flooding issue, not lack of fuel (??).
Re: Electric fuel pump push fuel through a mechanical pump [Re: StealthWedge67] #1769582
03/03/15 03:35 AM
03/03/15 03:35 AM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
I've run the holley red as a push thu to a carter mechanical pump for years.
Depending on you quality of fuel you will have evaporation problems. Ethanol is mandatory around here - Everyone told me it was my carb - I switched over to pure gas - ( Stromberg carb so it isn't something easy to just jet up) and all the problems went away.
I have used one of those cheap square Facet pumps just to prime or to help prevent vapor lock on very hot days and it worked fine.
Edelbrock has there own version. I was going to try one of those in the future.
Re: Electric fuel pump push fuel through a mechanical pump [Re: SSAAHemiFan] #1769583
03/03/15 11:22 AM
03/03/15 11:22 AM
PA
Jack Zupan Offline
Jack Zupan  Offline
PA
I've had this problem with my Roadrunner when it had a 383 and now with a hemi. I would have to crank the engine for a very long time before it would start. I put a small electric fuel pump next to the tank and use it only to prime the carbs. It works like a charm. I then outsmarted myself, I added a vapor separator and 1/4" return line to look like a hemi setup. The electric pump only had enough pressure to run the fuel back to the tank through the return line. Pinched off the return line and now it works fine again. Don't forget you need a low pressure electic pump or you will blow out the carb seals.
Re: Electric fuel pump push fuel through a mechanical pump [Re: Jack Zupan] #1769584
03/03/15 12:04 PM
03/03/15 12:04 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
a nice Carter 4070 series pump would be the ticket for this. 6psi with plenty of flow. the down side is if there is an issue with the diaphragm in the mechanical pump you flood your oil with fuel without knowing it....
Re: Electric fuel pump push fuel through a mechanical pump [Re: RUNCHARGER] #1769585
03/03/15 12:32 PM
03/03/15 12:32 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
It will work fine but you do not have to run parallel lines. I have a Holley electric back by the tank and it pushes through the mechanical just fine. I have both a manual switch under the dash for priming and the like and a micro switch that is actuated by the secondaries on the carb.
That way, I don't have to listen to the electric pump all the time, but have the flow when I need it. This system has fed the Dominator on the street and track for years now.
Master, again and still
Re: Electric fuel pump push fuel through a mechanical pump [Re: DaveRS23] #1769586
03/03/15 02:00 PM
03/03/15 02:00 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Nope.
I have done this for over 20 years. I started off with just an electric pump but even the best ($$$) seemed to burn up with all the driving I did.
Under the hood I have a Carter race mechanical pump and out back I have a Carter electric pump mounted in the trunk with a large Fram race filter.
When I start the car I kick on the electric pump till I hear the bowls fill and pressure stabilize. Pump 4-5 times and hit the key and it lights right off. Shut down the electric.
For most of your futzing around driving the big mech under the hood will provide enough fuel. Sustained WOT just hit the dash switch to turn the pump out back on and hammer away. Been meaning to add a WOT switch or even a low fuel pressure switch to have it kick in automatically but its been that way for so long its second nature now.
The gas around here is junk and evaporates in nothing flat. Even with the Carters on top of the tunnel ram out in the breeze the fuel is gone in a day or two.
"I think its got a hemi"
Re: Electric fuel pump push fuel through a mechanical pump [Re: gdonovan] #1769587
03/03/15 02:07 PM
03/03/15 02:07 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I looked at doing this and using a 5 second relay: ignition on, 5 seconds of priming, pump off, start engine, ignition off, ignition on, 5 seconds of priming, pump off, start engine...but the relays are 40 dollars each. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Electric fuel pump push fuel through a mechanical pump [Re: StealthWedge67] #1769588
03/03/15 05:09 PM
03/03/15 05:09 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Modern fuel evaporates more quickly depending on its volatility/vapor pressure...it's not at all unusual to have empty bowls after the car sits for an extended time.
Not all electric pumps will allow the mechanical pump to "pull through" when the electrical pump is shut off.
Re: Electric fuel pump push fuel through a mechanical pump [Re: John_Kunkel] #1769589
03/03/15 05:12 PM
03/03/15 05:12 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have found using a stock enclosed air filter housing has slowed the evaporation of the fuel in my carb verses a open air, air filter.
Re: Electric fuel pump push fuel through a mechanical pump [Re: Challenger 1] #1769590
03/03/15 09:32 PM
03/03/15 09:32 PM
PA
Jack Zupan Offline
Jack Zupan  Offline
PA
What does this mean? Open vs. closed?
Re: Electric fuel pump push fuel through a mechanical pump [Re: Jack Zupan] #1769591
03/03/15 09:51 PM
03/03/15 09:51 PM
Norcal
W
Wildjones Offline
Wildjones  Offline
W
Norcal
I'm thinking he is referring to a snorkel type air filter as being "closed" and a K&N style as being "open".
Re: Electric fuel pump push fuel through a mechanical pump [Re: Wildjones] #1769592
03/03/15 10:46 PM
03/03/15 10:46 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I did this exact same thing a few years ago. At some point I even posted all the part numbers for all the fitting and check valve I used for a really compact arrangement. I have mine tucked up in the axle tunnel and it works great. Just switch on for 15-20 seconds and both carbs prime up. Pump gas pedal to set the choke and it fires right up.
Re: Electric fuel pump push fuel through a mechanical pump [Re: 68jim] #1769593
03/03/15 10:55 PM
03/03/15 10:55 PM
Thanks for the help guys, there's absolutely nothing wrong with the car just the modern fuel. I have a new small 72GPH Carter but I may buy a 110GPH one instead, I don't want to starve the 528 at WOT. It has the Race Carter mechanical on there with a regulator.
My 472 has a stock Hemi Carter mechanical with of course no regulator. I can prime it without too much trouble through the stock vent tubes but the AVS's under the shaker on the 528 are not so easy and I'll rig it out first and see how happy I am with it.
Sheldon
Re: Electric fuel pump push fuel through a mechanical pump [Re: RUNCHARGER] #1769594
03/04/15 12:57 AM
03/04/15 12:57 AM
IN
ahy Offline
ahy  Offline
IN
Electric push through mechanical works for me ('47 Power Wagon). The stock fuel system was prone to vapor lock while running in hotter temps with today's fuel. Hot re-start not possible unless the fuel pump and nearby line was hosed down with cool water. Cold start after sitting required long crank times.
An auxiliary electric pump on a toggle switch mounted to the frame rail near the tank fixed all the above. It is a carb type electric pump set up with a bypass check valve so the engine mounted pump can draw fuel with electric pump off. The check valve is a 3/8" brass version from the hardware store. Other types are available.
Tests include 1) Run down the road in hot weather until she sputters and looses power. Turn electric pump on and smoothes right out 2) Hot re-start. Starts up quickly with electric pump on. Will not re-start with electric pump off. 3) start after sitting weeks or even months. Starts up promptly with electric pump on. Not so with pump off. Lots of cranking.
I kept the original fuel pump because it has integral filter, also since it is original style and because it is reliable in cooler weather.
Re: Electric fuel pump push fuel through a mechanical pump [Re: RUNCHARGER] #1769595
03/04/15 02:52 AM
03/04/15 02:52 AM
I'd run a psi gauge (isolated or otherwise) to the inside & you'd want several psi at WOT in high gear right at the carb inlet fitting(s). On the "otherwise" you wouldn't wanna a direct gauge inside permanently but for a 1 day test you'll know right then if your delivery setup is adequate. You dont wanna fry that beast from it going lean
Re: Electric fuel pump push fuel through a mechanical pump [Re: RUNCHARGER] #1769596
03/04/15 03:55 AM
03/04/15 03:55 AM
Dr Dave Offline
Dr Dave  Offline
Please let me know what you come up with. I have a similar setup, 528", dual quads, shaker, not easy to prime the carbs and want to do something with an electric pump.
Page 1 of 3 1 2 3
