Rusty MSD distributor
#1769533
03/02/15 09:01 PM
03/02/15 09:01 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I took my MSD distributor out yesterday and looked under the cap and it looks awful. The reluctor wheel is covered with rust. Would it be ok to take the shaft out of the distributor and sand blast the reluctor wheel.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Rusty MSD distributor
[Re: CHAPPER]
#1769537
03/03/15 10:10 PM
03/03/15 10:10 PM
D-50
North, Alabama
Would it be ok to paint the reluctor after it is sand blasted so it would not rust again quickly., of course I would sand the paint off the ends.
[Re: D-50]
#1769539
03/03/15 10:24 PM
03/03/15 10:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I dont see any issue... the tips are what counts
[Re: MR_P_BODY]
#1769540
03/04/15 12:15 AM
03/04/15 12:15 AM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Drill some holes in the cap for ventilation to stop the rusting.
[Re: markz528]
#1769541
03/04/15 02:32 AM
03/04/15 02:32 AM
Posts: 993 Addison,IL
OUTLAWSSAA
Addison,IL
This is correct. Ozone is created from the spark in the cap, thus creating the rust. Drilling the holes will help alleviate the problem.
[Re: MartyQ]
#1769543
03/05/15 12:10 PM
03/05/15 12:10 PM
markz528
Morrow, OH
Got this from Google but it is what we did with my cousin's car that had the same rusting problem as you. In addition, it was destroying his carbon electrode.
You should also vent the cap by drilling 2 - 1/4” holes 180 degrees across from each other midway up the cap between two of the poles. This will allow you to using the spinning of the rotor to draw fresh air through the cap and keep that ionizing of the collected moisture to a minimum. If this does not seem to work as well as we planned, drill an additional two holes at 90 degrees from the original holes.
See attachment
The rust or corrosion is a by product of moisture being trapped inside the cap and the high energy of the MSD ionizing that moisture. By venting the cap, we use the action of the rotor to continually draw fresh air through the cap keeping the moisture down to a minimum.
Thanks, MSD Tech
