? for the painters: When to replace air hose? #1769306
03/02/15 04:53 PM
03/02/15 04:53 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
I am getting ready to spray some paint in a couple of months and have some air hose questions. I was told that I should replace my air hose periodically to prevent an older hose from breaking down and allowing small bits of deteriorating hose to become mixed with the paint.
How often should I replace the hose?
Is there a specific hose brand that is better than others? Any brand to stay away from?
Thanks!
Stan
Re: ? for the painters: When to replace air hose? [Re: HemiStan] #1769307
03/02/15 05:28 PM
03/02/15 05:28 PM
Shingle Springs Ca
haddixj Offline
haddixj  Offline
Shingle Springs Ca
I would buy one from the local body supply store or on amazon you can get a devilbiss brand hose that is good
70 duster 25.1E,73 barracuda, 70 gran coupe, 71 cuda
Re: ? for the painters: When to replace air hose? [Re: haddixj] #1769308
03/02/15 05:54 PM
03/02/15 05:54 PM
So. Illinois
bronze69 Offline
bronze69  Offline
So. Illinois
Once you use a Flexzilla air hose, you will not want to use anything else.
68 Gold Met. 383-4spd Roadrunner 69 T5 Hemi 4-spd Roadrunner 70 Limelight 440-6 Auto Superbird
Re: ? for the painters: When to replace air hose? [Re: HemiStan] #1769309
03/02/15 05:58 PM
03/02/15 05:58 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I used the same air hose in my FG operation for 20+ years .... FG spray-up, parting agent, gel-coating and even limited amount of painting. NEVER had any issues with the hose coming apart.
Re: ? for the painters: When to replace air hose? [Re: HemiStan] #1769310
03/02/15 06:26 PM
03/02/15 06:26 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
My hoses at work last about 5-7 years, not because they fall apart on the inside but because they wear out on the outside.
They make filters that go on the air line before the spray gun that will protect the spray gun. I have never used one in 25+ years of painting. I have a air dryer/filter on the wall about 75-100 feet away from my compressor that my hose is supplied by.
I would not worry about the hose. I would be concerned with your air line piping in your shop to keep water out of the air hose when painting though. How's that laid out?
Re: ? for the painters: When to replace air hose? [Re: HemiStan] #1769311
03/02/15 06:39 PM
03/02/15 06:39 PM
Cincinnati, Ohio
Cincinnati, Ohio
Rubber hoses are nicer to use than plastic coating hoses. I use both kinds, both red in color but the plastic like hoses are much stiffer in the cold air and suck to use outside in the winter.
About 15-20 years ago the hose manufactures where forced to stop using something to make rubber hoses. So now the rubber hoses don't relax like they used to. Now they want to stay coiled up and are a bigger pain to use than older made hose was to handle. Coiled up air hose is a problem when dragging it around a fresh paint job.
I buy and use 150' long 1" LP hose AND 175'long 1 1/4" diesel and gas hoses that we use on tanker trucks. We notice how they handle and behave.
Air hose are the same deal. The rubber air hoses I buy today are not like the old air hoses of the days gone by because of the EPA.
Re: ? for the painters: When to replace air hose? [Re: bronze69] #1769312
03/02/15 07:30 PM
03/02/15 07:30 PM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks for the post, might try one.
Re: ? for the painters: When to replace air hose? [Re: Challenger 1] #1769313
03/02/15 10:59 PM
03/02/15 10:59 PM
western PA
mopar4ya Offline
mopar4ya  Offline
western PA
Just a word of caution. I had a older air hose cause me to wet sand the clear coat off twice before I figured out it was contamination coming from the hose that was causing my problem. This was also the same hose I had just used to lay down the black base that looked just fine .
Dan.
Re: ? for the painters: When to replace air hose? [Re: HemiStan] #1769314
03/02/15 11:02 PM
03/02/15 11:02 PM
santa anna, Tx.
charles6970 Offline
charles6970  Offline
santa anna, Tx.
very important to have a filter on your paint gun,
as for hoses, goodyear red rubber air hoses are what i prefer.
Re: ? for the painters: When to replace air hose? [Re: charles6970] #1769315
03/03/15 09:23 AM
03/03/15 09:23 AM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Thanks for the info. I will be checking out a few these different air hoses.
Stan
Re: ? for the painters: When to replace air hose? [Re: HemiStan] #1769316
03/03/15 11:56 AM
03/03/15 11:56 AM
Central NY
O
OneBadBeagle Offline
O
Central NY
I second the Flexilla recommendation, will never buy any other hose now
