opinions on step headers #1769213
03/02/15 02:18 PM
03/02/15 02:18 PM
Midland,Tx
wyldebill Offline OP
Midland,Tx
ive been told both direction, about step headers. some say it has no value, some say they make horsepower. anyone have any information proving or dis-proving claims?
Re: opinions on step headers [Re: wyldebill] #1769214
03/02/15 02:37 PM
03/02/15 02:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I never did a side by side test on the dyno when I
was building headers so I dont have data but I believe
in them enough that I built a 3 set for the race car
but I built a straight set for the street rod... this
is just a opinion but I think they help if the tubes
are equal length to set up the draw at the proper time
which helps them
Re: opinions on step headers [Re: MR_P_BODY] #1769215
03/02/15 02:43 PM
03/02/15 02:43 PM
dogdays Offline
dogdays  Offline
And I think they help reversion.
I don't think they hurt in any case.
R.
Re: opinions on step headers [Re: wyldebill] #1769216
03/02/15 02:59 PM
03/02/15 02:59 PM
Locomotion Offline
Locomotion  Offline
I'm a firm believer in "steps". A lot of Stock class cars have step header, some as small as 1 3/8" and go up 1 or 2 more sizes. Persoanlly I use the TTI 1 5/8" - 1 3/4" step headers on my 360. They have a broad application range. I've been 11-teens at 3,540 lbs.
There is a dyno comparison of a variety of OEM exhaust manifolds and a few headers, including TTI, on a mild 360.
The TTI step were several numbers better in HP and torque than 1 5/8" straight and 1 3/4" straight headers. But I'm at work and can't find it at the moment.
As with anything else, the actual results can vary with each different application. Jetting may need to be different from straight headers. But I don't see where they hurt.
Re: opinions on step headers [Re: wyldebill] #1769217
03/02/15 05:18 PM
03/02/15 05:18 PM
NC
440Jim Offline
440Jim  Offline
NC
My 2-cents/opinion:
If your application needs big tubes (ie final dia), then the step header from the initial dia stepped up to the final dia will perform better then a full length of the initial dia.
Using a smaller initial dia can help with clearance to the header retaining bolts in some applications.
I will also stick my neck out (opinion) that any gain from using a stepped header rather than a full length at the final/optimum dia will mostly be at levels at/below peak torque rather than near peak hp.
Re: opinions on step headers [Re: 440Jim] #1769218
03/02/15 05:34 PM
03/02/15 05:34 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
That's a topic that could be the basis for a whole lotta R&D to filter out the opinions from the facts.
The fact that they are used in specific top-level categories is a pretty good indicator that they work for certain combinations. How much of what works at that level still applies when you scale back the performance dramatically is a another question entirely... and one I'm in no position to answer from any position of knowledge.
Re: opinions on step headers [Re: BradH] #1769219
03/02/15 07:28 PM
03/02/15 07:28 PM
Locomotion Offline
Locomotion  Offline
Here is the Hot Rod dyno test article on a 360/300hp Mopar crate engine. Most of the info is listed with the pics. The dyno numbers are in the last one.
I wish higher rpm numbers were available for this test or a stronger combo.
Hot Rod Magazine exhaust dyno test.
Re: opinions on step headers [Re: Locomotion] #1769220
03/02/15 08:43 PM
03/02/15 08:43 PM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
hi, a few years ago, had a friend with 383 dart stocker. it had step headers on it, 1 5/8, 1 3/4 with 3 " collector. changed to a 1 3/4, 1 7/8, 2" step header. it was worth 4 tenths over smaller headers. then added 3 1/2 dia by 16 " collector, picked up . 15 faster over 3" collector. like you say every car is different.
Re: opinions on step headers [Re: perfmachst] #1769221
03/02/15 08:50 PM
03/02/15 08:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In a LOT of cases the 3.5 collector works better(if
its the correct length)... mainly due to RPM.. the
3" is just too small in most cases but thats what
a lot of the header companies want to run(cost is
one reason)... I put 3.5" on MOST of my headers or
larger
Re: opinions on step headers [Re: wyldebill] #1769222
03/02/15 10:02 PM
03/02/15 10:02 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
Trying to find the dyno sheets but when we went from big tubes on the dyno to TTI steps we lost 12 hp ended up having a set of equal length big tubes with 4 1/2 collectors made.
Re: opinions on step headers [Re: wyldebill] #1769223
03/02/15 10:50 PM
03/02/15 10:50 PM
Idaho
LaRoy Engines Offline
Idaho
I don't know what engine you are using and what rpm range you are running. I don't have an opinion. But I do have the results on a 600hp pump gas small block dyno test. When we switched from Summit Racing $136 1-5/8 headers to TTI 1-5/8" x 1-3/4" step headers we gained an average of 1 lb-ft and 1hp from 3,000-6,000 rpm. The peak horsepower difference was +12hp @ 6,300 rpm. But boy, for an extra $500 those TTI headers are really pretty.
Re: opinions on step headers [Re: LaRoy Engines] #1769224
03/02/15 11:06 PM
03/02/15 11:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Myself.. I dont call TTI headers very good.. they
fit nice and are fairly easy to install... thats it
and they sure arent made for max power... NO shelf
header fits ALL
Re: opinions on step headers [Re: MR_P_BODY] #1769225
03/02/15 11:07 PM
03/02/15 11:07 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
Re: opinions on step headers [Re: Wv68charger] #1769226
03/02/15 11:14 PM
03/02/15 11:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
https://board.moparts.org/ubbthreads/show...rue#Post8275923
MAYBE they are a closer match to that set up.. but
that would be one set up... I will repeat... shelf
headers dont fit all... they were designed on a single
engine
Re: opinions on step headers [Re: MR_P_BODY] #1769227
03/02/15 11:23 PM
03/02/15 11:23 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
engine
I agree that's why we went with a custom set
Re: opinions on step headers [Re: perfmachst] #1769228
03/03/15 12:43 AM
03/03/15 12:43 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The first set must have been crushed. That would be a roughly a 50-60 hp gain. 5 1/2 tenths ET reduction with a header an collector change? Smells a little fishy.
Doug
Re: opinions on step headers [Re: dvw] #1769229
03/03/15 03:11 AM
03/03/15 03:11 AM
Midland,Tx
Midland,Tx
Here is the combo so far. 560 aluminum low deck, 12.5 to 1. Zeeker heads (-1) indy tunnel ram. A body should be under 3000 lbs. Manuel trans,and a conservative 3.73 gear. 10.5 slick. do you put the big tube on it to kill off a little bottom end?
Re: opinions on step headers [Re: wyldebill] #1769230
03/03/15 09:21 AM
03/03/15 09:21 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It'll all depend on your suspension, 1st gear ratio in your trans, and if you have an adjustable clutch. 3.73 isn't much ratio for a stick car. If I could find more low end for my car I'd take it (15-1 572, 4.10, 3340lb, on 10.5) It currently runs 2 1/8" w/3 1/2" collector.
Doug
Re: opinions on step headers [Re: wyldebill] #1769231
03/03/15 09:21 AM
03/03/15 09:21 AM
NC
440Jim Offline
440Jim  Offline
NC
Chuck at BEST Machine dyno tested an engine close to that size with a couple pairs of headers. Do a search and see if your engine combo is close to his and the difference it made. As I recall, the really big tube headers made more peak HP, and lost torque below about 5900 rpm. With a high stall converter, you will hardly see that at the drag stripe.
EDIT: https://board.moparts.org/ubbthreads/show...rue#Post8276607
1) 2.125 straight tubes
2) 2.125 stepped to 2.375 then to 2.500 big tubes
Re: opinions on step headers [Re: 440Jim] #1769232
03/03/15 12:28 PM
03/03/15 12:28 PM
Midland,Tx
Midland,Tx
im running a 2.45 first. the reason of the 3.73 is im going to try and drive it on dragweek. i dont have an overdrive. i can go to a shorter slick at the track to try and recover some gear. as far as the chassis goes. c/m k member with coilover shocks read in momo leif with assasin bars.there are guys running much faster than me with simmular components
