Re: opinions on step headers
[Re: wyldebill]
#1769214
03/02/15 02:37 PM
03/02/15 02:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I never did a side by side test on the dyno when I was building headers so I dont have data but I believe in them enough that I built a 3 set for the race car but I built a straight set for the street rod... this is just a opinion but I think they help if the tubes are equal length to set up the draw at the proper time which helps them
[Re: wyldebill]
#1769216
03/02/15 02:59 PM
03/02/15 02:59 PM
Posts: 5,894 Florida
Locomotion
I'm a firm believer in "steps". A lot of Stock class cars have step header, some as small as 1 3/8" and go up 1 or 2 more sizes. Persoanlly I use the TTI 1 5/8" - 1 3/4" step headers on my 360. They have a broad application range. I've been 11-teens at 3,540 lbs.
There is a dyno comparison of a variety of OEM exhaust manifolds and a few headers, including TTI, on a mild 360. The TTI step were several numbers better in HP and torque than 1 5/8" straight and 1 3/4" straight headers. But I'm at work and can't find it at the moment.
As with anything else, the actual results can vary with each different application. Jetting may need to be different from straight headers. But I don't see where they hurt.
[Re: BradH]
#1769219
03/02/15 07:28 PM
03/02/15 07:28 PM
Locomotion
Here is the Hot Rod dyno test article on a 360/300hp Mopar crate engine. Most of the info is listed with the pics. The dyno numbers are in the last one. I wish higher rpm numbers were available for this test or a stronger combo. Hot Rod Magazine exhaust dyno test.
[Re: perfmachst]
#1769221
03/02/15 08:50 PM
03/02/15 08:50 PM
MR_P_BODY
hi, a few years ago, had a friend with 383 dart stocker. it had step headers on it, 1 5/8, 1 3/4 with 3 " collector. changed to a 1 3/4, 1 7/8, 2" step header. it was worth 4 tenths over smaller headers. then added 3 1/2 dia by 16 " collector, picked up . 15 faster over 3" collector. like you say every car is different.
In a LOT of cases the 3.5 collector works better(if its the correct length)... mainly due to RPM.. the 3" is just too small in most cases but thats what a lot of the header companies want to run(cost is one reason)... I put 3.5" on MOST of my headers or larger
[Re: LaRoy Engines]
#1769224
03/02/15 11:06 PM
03/02/15 11:06 PM
MR_P_BODY
I don't know what engine you are using and what rpm range you are running. I don't have an opinion. But I do have the results on a 600hp pump gas small block dyno test. When we switched from Summit Racing $136 1-5/8 headers to TTI 1-5/8" x 1-3/4" step headers we gained an average of 1 lb-ft and 1hp from 3,000-6,000 rpm. The peak horsepower difference was +12hp @ 6,300 rpm. But boy, for an extra $500 those TTI headers are really pretty.
Myself.. I dont call TTI headers very good.. they fit nice and are fairly easy to install... thats it and they sure arent made for max power... NO shelf header fits ALL
[Re: MR_P_BODY]
#1769225
03/02/15 11:07 PM
03/02/15 11:07 PM
Posts: 1,770 Pa
Wv68charger
Pa
[Re: perfmachst]
#1769228
03/03/15 12:43 AM
03/03/15 12:43 AM
Posts: 9,846 MI, usa
dvw
MI, usa
. The first set must have been crushed. That would be a roughly a 50-60 hp gain. 5 1/2 tenths ET reduction with a header an collector change? Smells a little fishy. Doug
[Re: wyldebill]
#1769230
03/03/15 09:21 AM
03/03/15 09:21 AM
dvw
MI, usa
Here is the combo so far. 560 aluminum low deck, 12.5 to 1. Zeeker heads (-1) indy tunnel ram. A body should be under 3000 lbs. Manuel trans,and a conservative 3.73 gear. 10.5 slick. do you put the big tube on it to kill off a little bottom end?
It'll all depend on your suspension, 1st gear ratio in your trans, and if you have an adjustable clutch. 3.73 isn't much ratio for a stick car. If I could find more low end for my car I'd take it (15-1 572, 4.10, 3340lb, on 10.5) It currently runs 2 1/8" w/3 1/2" collector. Doug
[Re: wyldebill]
#1769231
03/03/15 09:21 AM
03/03/15 09:21 AM
Posts: 16,928 NC
440Jim
NC
Chuck at BEST Machine dyno tested an engine close to that size with a couple pairs of headers. Do a search and see if your engine combo is close to his and the difference it made. As I recall, the really big tube headers made more peak HP, and lost torque below about 5900 rpm. With a high stall converter, you will hardly see that at the drag stripe.
EDIT: https://board.moparts.org/ubbthreads/show...rue#Post8276607 1) 2.125 straight tubes 2) 2.125 stepped to 2.375 then to 2.500 big tubes
[Re: 440Jim]
#1769232
03/03/15 12:28 PM
03/03/15 12:28 PM
Posts: 774 Midland,Tx
wyldebill
Midland,Tx
im running a 2.45 first. the reason of the 3.73 is im going to try and drive it on dragweek. i dont have an overdrive. i can go to a shorter slick at the track to try and recover some gear. as far as the chassis goes. c/m k member with coilover shocks read in momo leif with assasin bars.there are guys running much faster than me with simmular components
