Raising compression on a 318 #176906
12/28/08 01:41 AM
12/28/08 01:41 AM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
I recently bought a 318 that had just been rebuilt. Has been bored .040 over. The pistons are flattops that are about .1 down in the hole at top dead center. The head gaskets are .05 thick. The heads are 1976 318 heads with the numbers 4027163 on them. Id like to get the compression up in the 9's if I can without altering the short block. I do have a set of 302 heads if they would help.
Re: Raising compression on a 318 [Re: derekeh] #176907
12/28/08 02:02 AM
12/28/08 02:02 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
here is your best deal on head gaskets..the old mopar performance thin .024 are no longer available...
http://store.summitracing.com/partdetail.asp?part=MRG%2D1121&autoview=sku
Tony
70 AARCuda Vitamin C
Re: Raising compression on a 318 [Re: derekeh] #176908
12/28/08 02:09 AM
12/28/08 02:09 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
yes definatly go to the 302 heads and shave at least .020 off , more than .020 and you will also have to cut the intake face also .
use the thinest head gasket you an find.
usig taller pistons would also be good .
Re: Raising compression on a 318 [Re: calrobb2000] #176909
12/28/08 02:51 AM
12/28/08 02:51 AM
dulcich Offline
dulcich  Offline
With the 302 heads and .024 gaskets you will be about 8.8:1.
I wouldn't spend the coin on rebuilding another set of heads, and would just run it as-is. Even with this set-up the pistons are always going to be a mile down in the hole.
Put headers, small cam, and two-plane intake on it and don't worry about the compression if you can't swap the pistons for now. Finding the heads and getting them rebuilt and swapped is way, way, more work and time and money than swapping pistons, and the 302's aren't any good for flow without a lot of port work and bigger valves anyway.
The best thing to do is re-piston and then add some good heads as time and money allows.
-dulcich
Re: Raising compression on a 318 [Re: dulcich] #176910
12/28/08 09:36 AM
12/28/08 09:36 AM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
I have quite a few 360 heads lying around also. What would be a good piston to use and would it require rebalancing?
Re: Raising compression on a 318 [Re: derekeh] #176911
12/28/08 09:44 AM
12/28/08 09:44 AM
Montana
FuryUs Offline
FuryUs  Offline
Montana
360 heads are going to kill the compression. Don't go that way if you want compression unless you're making changes tot he short block to get the pistons up in the bore.
Re: Raising compression on a 318 [Re: FuryUs] #176912
12/28/08 10:15 AM
12/28/08 10:15 AM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
Thats why I asked what would be a good piston to use
Re: Raising compression on a 318 [Re: derekeh] #176913
12/28/08 11:25 AM
12/28/08 11:25 AM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
KB399's will work good with 360 heads in a 318, you can't swap to magnums/edelbrocks/302's later if you use them since they are domes. A KB 167 will work too, it's a flat top and has around 9.2 comp with 360 heads.
I'm have a 318 going together with a set of 399's, planning on making a mild street motor with 308 heads and a hyd roller.
Re: Raising compression on a 318 [Re: derekeh] #176914
12/28/08 12:04 PM
12/28/08 12:04 PM
If you do end up altering the short block & ch pistons make your selection(piston/gasket/heads) which will give you proper quench if not as said thinner gaskets/302 heads(or magnums) is about all you can do & you might adv the cam. I'm in the same position my 360 build is .110" in the hole so I might continue to look for a 3.79 crank or a 4" er if the pistons will stand enough milling but thats not looking too promising or maybe a custom cometic head(& intake) gasket(s)
Re: Raising compression on a 318 [Re: derekeh] #176915
12/28/08 05:20 PM
12/28/08 05:20 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
if the engine was recently rebuilt, why not run it as is? sure, it will be less than ideal, but changing pistons and heads will be almost like starting over. i think i would put the engine in and enjoy it while saving to build the engine you really want. keep in mind, if starting from scratch, a 360 can be built as cheaply as a 318.
Re: Raising compression on a 318 [Re: dulcich] #176916
12/29/08 09:12 AM
12/29/08 09:12 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
-dulcich
pistons to use would be KB167's...some other options would be to tear the motor down and get the block decked about .050 or so....
another option would be to get some enginequest 318B magnum style heads. they have about 5cc smaller chambers than the open chamber 318 heads, and with the thin head gasket should put you at 8.5-8.8:1.....you can get a set of new heads assembled with springs good for .5" lift for about $650/pr, which is a better deal than rebuilding some 302's...
2017 Grand Cherokee Overland
Re: Raising compression on a 318 [Re: derekeh] #176917
12/29/08 02:01 PM
12/29/08 02:01 PM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
Just a thought, another way to raise compression would be to angle mill a set of heads. Careful pre-planning is the word of the day, though the results would be worth while. Don't go crazy on cam lift and no knotching of pistons required.
Other wise re-piston with some KB 167's and the thinest head gaskets you can find.
Good luck!
Jim Burch
Re: Raising compression on a 318 [Re: JBurch] #176918
12/29/08 04:59 PM
12/29/08 04:59 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
Ill probably just leave the engine alone then. Someone just gave me the 302 heads and I was looking for a cheap way to get the compression up. My idea was a home porting job on the heads and getting bigger valves put in. But if its not worth doing Ill just leave the engine as is. It has a bigger than stock cam but Ive been unable to find out what kind it is
Re: Raising compression on a 318 [Re: derekeh] #176919
12/29/08 08:13 PM
12/29/08 08:13 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Yep ! Go with KB's 167 piston......throw magnum heads on them and you'll have plenty of fun in the streets !
Dan
Re: Raising compression on a 318 [Re: derekeh] #176920
12/30/08 09:06 AM
12/30/08 09:06 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
well, the bummer with this is by the time you buy new oversize 2.02 or 1.88/1.60 valves and re-cut the heads for them, you're probably in to it for ~$350-400 or so, plus probably another $100 for springs/retainers. and you still have heads that flow ~150/100 int/ex. then you have your time for porting, and these heads, done by a professional porter will likely max out at about 230/135 int/ex, (probably less by someone like us w/o access to a flow bench or a lot of experience), which is about the same (or slightly worse) flow than as-cast enginequest mag heads, for about the same $$ as new, assembled EQ heads.
if you wanted to do heads on the cheap, if you can find a set of used magnums, do a valve job, maybe open up the pushrod pinch a skoash, and put some GM3100 springs and retainers on them, or find some junkyard 2.2L retainers and a good 1.4" diameter spring on them, and probably save about $200-300 over a new set of enginequests.
but the "cheapest" way to up compression is to either mill your existing heads, or if your engine is fresh enough, get some KB167's in the same overbore as your motor, do a quickie hone, and toss them in...
Re: Raising compression on a 318 [Re: patrick] #176921
01/01/09 11:24 AM
01/01/09 11:24 AM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
I have a set of magnum heads but they are for another engine lol. I have some 360 heads that ill just put some JB Weld in the combustion chamber to help up the compression. Always has worked before
Re: Raising compression on a 318 [Re: derekeh] #176922
01/01/09 12:31 PM
01/01/09 12:31 PM
Am I invited
