Re: Mechanical Adjustable Rocker Arms
[Re: JohnnyBeGood]
#176888
12/28/08 12:49 AM
12/28/08 12:49 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Youll get alot of opinions on this, but I will suggest three things......
1. Dont buy cheap roller rockers, there are loads of horror stories with them.
2. I would suggest Isky/Crane ductile iroon rockers. Cheap and strong.
3. You didnt dpecify what cam and combo youre running, but if its really wild, youll need to step up to something serious.
[Re: NTOLERANCE]
#176889
12/28/08 01:26 AM
12/28/08 01:26 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Spot on...
[Re: 1_WILD_RT]
#176890
12/28/08 03:14 AM
12/28/08 03:14 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
[Re: 383man]
#176891
12/28/08 10:35 AM
12/28/08 10:35 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
There is a place up in Washington or somewhere that rebuilds, rebushes and bluprints the Isky Ductile Iron rocker arms. Heck, I still have a set of them down in the basement.
The only problem with them I remember, was that they could gaul themselves and the rocker shaft. Once bushed and with a hardened shaft, I think they would be a great reliable set-up.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#176892
12/28/08 02:14 PM
12/28/08 02:14 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Bannana groove shafts take care of that issue, the same company that installs bushings also sells shafts... http://www.rockerarms.com/
[Re: 1_WILD_RT]
#176894
12/28/08 10:19 PM
12/28/08 10:19 PM
excellent work and customer service
[Re: NTOLERANCE]
#176895
12/29/08 01:41 AM
12/29/08 01:41 AM
Posts: 5,440 So Cal
Sinitro
So Cal
If you can find a set of the Isky rockers, go for it. However the Cranes are another story, Crane had a bad run for ductile iron rockers they were not hardened properly, the valve stem would wear into the contact point. We went through a long argument with Crane, at first they denied any quality problem then they conceded certain issues. This took several months of debating back/forth with Crane and eventually we tossed the rockers into the dumpster and installed Harland Sharps, never looked back. This was about a couple of years back, and hopefully now they have kleened up their BS.
For me I will never use another Crane product, even if it was free for my weedwacker..
Just my ..
[Re: GOLDENCOMMANDO]
#176899
12/29/08 11:08 AM
12/29/08 11:08 AM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Years ago (over 10?) the Iskys were visually different than the cranes. Like a rib along the top of the body. Man us Mopar guys really pay thru the $$ when we need to deviate from the stamped steel stockers. I remember my brother buying Harland Sharpes back in 1986 for his 440. Back then he spent 2 weeks pay for a set (around $375 in 1986). Adj after adj kept breaking. They kept sending new ones for free until finally all the bad adjusters were weeded out. Seems their vendor had a "FURNACE PROBLEM" and a bad batch of adjusters made it thru. That infamous re ocurring "furnace problem" has increased business for a company called Smith Brothers.
Keep old mopars alive.
