indy low deck block #1768535
03/01/15 07:05 PM
03/01/15 07:05 PM
Midland,Tx
wyldebill Offline OP
Midland,Tx
hey guys, i recently bought an indy aluminum low deck block. what is the most stroke you can put in this thing. i have a 4.3 stroke (bb chevy rod) but i know of a 4.4 (bb chevy rod) crank i can get my hands on. this block has stock cam location. what would you do? i have to get a custom piston built either way.
Re: indy low deck block [Re: wyldebill] #1768536
03/01/15 08:12 PM
03/01/15 08:12 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I've heard of a 4.5"x4.5" low deck 572 so go for it!
Re: indy low deck block [Re: wyldebill] #1768537
03/01/15 11:54 PM
03/01/15 11:54 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
I have a 4.375 stroke with a 6.535 rod in a 4.500 bore in an low deck Indy block. Be sure to check the clearance of the piston skirt to the top of main web. Mine hit and I had to notch for clearance.
Re: indy low deck block [Re: PLUM BAD] #1768538
03/02/15 12:56 AM
03/02/15 12:56 AM
Midland,Tx
Midland,Tx
What pistons are you running?
Re: indy low deck block [Re: wyldebill] #1768539
03/02/15 02:04 AM
03/02/15 02:04 AM
downunder
3
383ute Offline
383ute  Offline
downunder
what are the weight savings using the alloy low deck?
Re: indy low deck block [Re: wyldebill] #1768540
03/02/15 02:30 AM
03/02/15 02:30 AM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
Diamond
Re: indy low deck block [Re: PLUM BAD] #1768541
03/02/15 03:18 AM
03/02/15 03:18 AM
Midland,Tx
Midland,Tx
Indy claims the block weights 133 lbs
Re: indy low deck block [Re: wyldebill] #1768542
03/02/15 12:59 PM
03/02/15 12:59 PM
Western Kentucky
Muscles Offline
Muscles  Offline
Western Kentucky
I had to notch my block the same way, using a 4.25 stroke crank.
Re: indy low deck block [Re: Muscles] #1768543
03/02/15 02:19 PM
03/02/15 02:19 PM
S.E. Michigan
cl440 Offline
Happy Birthday cl440  Offline
S.E. Michigan
On our 4.25 stroke / 6.535 / 4.5 bore the bottom of the pin bosses hit the crank throws also. Dont forget to check that.
Re: indy low deck block [Re: cl440] #1768544
03/02/15 02:22 PM
03/02/15 02:22 PM
Midland,Tx
Midland,Tx
i had a 400 block with 4.3 stroke and 6.7 rod everything cleared
Re: indy low deck block [Re: wyldebill] #1768545
03/02/15 02:45 PM
03/02/15 02:45 PM
dogdays Offline
dogdays  Offline
Weight savings on the block alone are from 90 - 100lb.
R.
Re: indy low deck block [Re: cl440] #1768546
03/02/15 05:33 PM
03/02/15 05:33 PM
NC
440Jim Offline
440Jim  Offline
NC
I run that combo in my KB block. Discuss this with the piston manufacturer when custom ordering. I have seen the thickness under the pin (on the boss) from 0.150 to 0.230" depending on application.
Here is the math for that one.
CWmax = Counter Weight max dia
Pthick= Piston thickness below the pin
Pin = Piston pin dia
Rod = Rod Length
CWmax = 2(Rod - Stroke/2 - Pin/2 - Pthick - Clearance)
For example:
CWmax = 2(6.535 - 4.25/2 - 0.990/2 - 0.190 - 0.125)
CWmax = 2(6.535 - 2.125 - 0.495 - 0.190 - 0.125 )
CWmax = 7.20" dia
If you are OK with 0.060" clearance and want 4.44 stroke:
CWmax = 2(6.535 - 4.44/2 - 0.990/2 - 0.190 - 0.060)
CWmax = 2(6.535 - 2.22 - 0.495 - 0.190 - 0.060 )
CWmax = 7.14" dia
If you need more thickness under the pin (on the piston) you will need smaller crank counterweights and maybe heavy metal slugs to balance. For those longer strokes, you could use a longer rod and very short piston compression height.
Re: indy low deck block [Re: PLUM BAD] #1768547
03/02/15 11:45 PM
03/02/15 11:45 PM
NC
440Jim Offline
440Jim  Offline
NC
By any chance do you have the skirt and piston dimensions compared to my Diamond pistons?
Specifically the total skirt length (2.555)? (that isn't exactly your problem)
And the 0.190" dimension below the piston pin?
I didn't have a problem but mine is a 4.250" stroke, 6.535" rod, in a KB low deck and I think the cylinder liner is 6.10" long ? (not measured) I wonder if it is the piston/stroke or the block...
Re: indy low deck block [Re: 440Jim] #1768548
03/03/15 11:57 AM
03/03/15 11:57 AM
S.E. Michigan
cl440 Offline
S.E. Michigan
I think I have some of the dimensions at home. They didnt hit on all counter weights but a few and not the full length of the weight. There were "high" spots on a few counter weights that were an issue. Instead of removing the crank and cutting down counter weights and rebalancing we manually removed some material from the pin boss bottom side to clearance. Worked fine but an area to check for sure.
Re: indy low deck block [Re: cl440] #1768549
03/03/15 12:27 PM
03/03/15 12:27 PM
mi usa
O
old yeller Offline
old yeller  Offline
O
mi usa
A 572ci low deck is old news.....
Re: indy low deck block [Re: cl440] #1768550
03/03/15 12:38 PM
03/03/15 12:38 PM
NC
440Jim Offline
440Jim  Offline
NC
PlumBad,
Did you have clearance at the pin boss (yellow)?
From your pictures, it looked like the block interference was at the red area.
Do you know what the crank counter weight dia (or radius) was? As you can see from my calcs, somewhere around 7.1"-7.3" dia is typically needed and most cranks will come between 7.32-7.5. My Callies 4.250" crank came cam cut to 7.32 where it approaches the piston at BDC, but larger at the leading and trailing ends of the counter weight. But I cut mine down to 7.1x dia for balancing.
Re: indy low deck block [Re: 440Jim] #1768551
03/03/15 09:53 PM
03/03/15 09:53 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
Jim, sorry I do not have any of the dimensions you asked for. The pin boss cleared fine. The interference was a little farther down the curve of the skirt. I don't know what the counter weight diameter is either. The crank is a Crower and when we ordered it they asked for the rod length we were going to use to cut the counter weight. The tag that came with the crank says CWT Cut for 6.536 Rod C-C. Sorry I couldn't be of more help.
Re: indy low deck block [Re: PLUM BAD] #1768552
03/04/15 12:09 AM
03/04/15 12:09 AM
NC
440Jim Offline
440Jim  Offline
NC
OK.
You have more stroke so I don't know if it is the added stroke, the piston skirt design, or the Indy block.
I do remember the builder I ordered my pistons from (the smart guy between me and Diamond) told both me and Diamond to not notch the bottom of the bores so that the piston could have a little more skirt for stability. And it didn't hit the bottom of the bore/cylinder (block) with 4.250" stroke.
I have compared various pistons with ~1.32 compression heights and the skirt length can vary a bunch (2.38-2.755). But the transition from the piston boss to the skirt can vary also. Your experience taught me one more thing to consider when ordering all the parts. I just don't know if the KB cylinder liners for their low deck is longer than the Indy low deck.
I didn't see any clearancing at the bottom of the cylinder from the top, but the attached view when I did the mock-up at BDC seems to show a KB relief at the blue arrow?
