b-body 8 3/4 in an a body #1768391
03/01/15 04:07 PM
03/01/15 04:07 PM
minnesota
P
president61 Offline OP
P
minnesota
I'm putting a 67 8 3/4 in my swinger. my question is the brake hose. the hole in the housing where the vent bolt goes is closer to the center on the 8 3/4 compared to the 8 1/4. has anybody ran into this issue? basically i need to know if the stock 8 1/4 hose will reach the stock location on the car.
Re: b-body 8 3/4 in an a body [Re: president61] #1768392
03/01/15 04:15 PM
03/01/15 04:15 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The hose for the 8 3/4 usually incorporates the breather vent, so you might want to use that one. Some 8 1/4 hoses don't have this. The housing does need to breathe.
Re: b-body 8 3/4 in an a body [Re: president61] #1768393
03/01/15 04:20 PM
03/01/15 04:20 PM
CA
crackedback Offline
crackedback  Offline
CA
Plug the original hole, drill and tap a fresh hole for the brake tee.
Re: b-body 8 3/4 in an a body [Re: president61] #1768394
03/01/15 04:29 PM
03/01/15 04:29 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You can use a '69 and older A-body hose and tee, as the vent-hole is in the same location.
Re: b-body 8 3/4 in an a body [Re: DoctorDiff] #1768395
03/02/15 12:06 AM
03/02/15 12:06 AM
minnesota
P
P
minnesota
ok thanks
