Re: '70 Superbee underhood wiring details
[Re: Paul]
#176626
12/27/08 11:33 PM
12/27/08 11:33 PM
Posts: 6,679 Va. Beach, Va
69superbee383
Va. Beach, Va
ok here ya go...from my 70 383 4 bbl Coronet
first from the alternator over to the right side inner fender
77 Macho Power Wagon LWB factory 440
70 Coronet 440 N code 3 speed
[Re: 69superbee383]
#176627
12/27/08 11:34 PM
12/27/08 11:34 PM
69superbee383
Va. Beach, Va
next at the inner fender under the washer tank
[Re: 69superbee383]
#176630
12/27/08 11:37 PM
12/27/08 11:37 PM
69superbee383
Va. Beach, Va
and the bottom horn
wires are green with tracer
[Re: 69superbee383]
#176631
12/27/08 11:40 PM
12/27/08 11:40 PM
69superbee383
Va. Beach, Va
I just did the engine and forward light harnesses on the car last weekend. I will see if I can grab a pic of the relay under the dash
[Re: 69superbee383]
#176632
12/27/08 11:50 PM
12/27/08 11:50 PM
69superbee383
Va. Beach, Va
Ok here ya go. Not a good pic but it should work. You can see the parking brake handle in the left lower corner for orientation. the shiny object next to the oval hole is the mounting screw and you can see the gray plug as well as the relay thru the oval hole
[Re: 69superbee383]
#176633
12/27/08 11:52 PM
12/27/08 11:52 PM
69superbee383
Va. Beach, Va
And here is the relay. the mounting screw is at the bottom and you can see all three wires pretty decent here.
[Re: 69superbee383]
#176634
12/28/08 02:38 AM
12/28/08 02:38 AM
Posts: 5,135 Kingsburg Calif.
Quikshft
Kingsburg Calif.
Hotdog, that's what I need. For whatever reason, the horn relay was not plugged in and two of the wires were jumped. That's one of the only butcher jobs I've seen so far on my original wiring harness. Thanks again.
[Re: Quikshft]
#176635
12/28/08 03:03 AM
12/28/08 03:03 AM
69superbee383
Va. Beach, Va
I have seen them do that when the horn button in the column fails and they wire in an under dash button instead.
[Re: Quikshft]
#176638
12/28/08 01:21 PM
12/28/08 01:21 PM
Quikshft
Kingsburg Calif.
Here's another problem, my regulator is an earlier style which I know isn't right. I got the '70 only bracket that mounts to the firewall, now I need a regulator. I'm hunting around online and all I see are the ones with the funky triangular 3 prong connector. I don't think those are the right thing? What do I need and where can I get it? Here's a pic of what's at Napa or Autozone typical down below; Here's a pic of Lonnie's (Hakkarcharger) car which I'm using for reference;
[Re: Quikshft]
#176642
12/28/08 10:56 PM
12/28/08 10:56 PM
69superbee383
Va. Beach, Va
I just got one of the Mopar repops. I think it was 25 bucks and yep that is the connector. Oh and if you get the Mopar black one take the paint off the back for a good ground...dont ask me how I know this
[Re: 69superbee383]
#176643
12/28/08 11:01 PM
12/28/08 11:01 PM
69superbee383
Va. Beach, Va
Here is an odd ball for you. Coronet 440 post coupe with the 383 4 bbl and 3 speed manual.
[Re: Quikshft]
#176645
12/29/08 12:54 AM
12/29/08 12:54 AM
69superbee383
Va. Beach, Va
Looks like a 69 and earlier regulator and harness. Here is a pic of one I pulled from a 70. First pic is the bulkhead connector the reg. plug and wires to the ballast and oil press send.
[Re: 69superbee383]
#176646
12/29/08 12:56 AM
12/29/08 12:56 AM
69superbee383
Va. Beach, Va
here is a pic of the reg plug and ballast wires also can see the oil press wire
[Re: 69superbee383]
#176647
12/29/08 01:01 AM
12/29/08 01:01 AM
69superbee383
Va. Beach, Va
Go down the engine harness to the alt. connectors. Do you have one or two field wires? If just one dk green would be a 69 and earlier if there are two should be one dk green and one with two blue in one connection thats a 70. Scroll up to my pic with the alternator showing and you can see the blue field wires.
[Re: Quikshft]
#176649
12/29/08 01:18 AM
12/29/08 01:18 AM
69superbee383
Va. Beach, Va
Well the engine harness was around 85 bucks from Year One. Seems someone went to a lot of trouble to change that out.
[Re: Quikshft]
#176651
12/29/08 01:39 AM
12/29/08 01:39 AM
69superbee383
Va. Beach, Va
I think you can still use Moparts 15 and get a 15% discount. They are made by M and H and Year One has the market sewed up on them.
[Re: 69superbee383]
#176652
12/31/08 11:15 AM
12/31/08 11:15 AM
i got a harness from evan's wiring in erie pa. it is perfect and he will gladly tell you where all the wires go. he has a wiring harness to let you use electronic ignition on the older cars also. if you need it i will get his phone number.
