Stripping paint from plastic parts - 70 cuda grille #176535
12/27/08 07:42 PM
12/27/08 07:42 PM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline OP
What would be the best way to strip the paint from a 70 cuda grille and rocker moldings? The rocker moldings have 2-3 coats of paint on them, I want to strip everything to the bare plastic.
Re: Stripping paint from plastic parts - 70 cuda grille [Re: Barnabas_Kriss] #176536
12/27/08 08:16 PM
12/27/08 08:16 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
Original Easy-Off oven cleaner in the yellow can.Works great!
Re: Stripping paint from plastic parts - 70 cuda grille [Re: Barnabas_Kriss] #176537
12/27/08 08:23 PM
12/27/08 08:23 PM
go to your auto body supply place and ask
for corvette paint stripper..
Re: Stripping paint from plastic parts - 70 cuda grille #176538
12/28/08 12:01 AM
12/28/08 12:01 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
That one I'd avoid, it will remove the paint but as soon as it hits plastic it can and will start to melt it, if left on too long it will destroy a good grille.
The Corvette (fiberglass safe) stripper will typically work but ALWAYS test it (for a good long time) on a test sample first.
Re: Stripping paint from plastic parts - 70 cuda grille [Re: Barnabas_Kriss] #176539
12/28/08 12:09 AM
12/28/08 12:09 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I used to use brake fluid on models.
Sheldon
Re: Stripping paint from plastic parts - 70 cuda grille [Re: RUNCHARGER] #176540
12/28/08 12:13 AM
12/28/08 12:13 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I used easy off on a 71 challenger grille. and Ruined it.
Re: Stripping paint from plastic parts - 70 cuda grille [Re: ScottSmith_Harms] #176541
12/28/08 11:37 AM
12/28/08 11:37 AM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Thats funny because I used the oven cleaner on model cars to strip paint off and it never harmed the plastic.
Re: Stripping paint from plastic parts - 70 cuda grille [Re: RV2] #176542
12/28/08 11:52 AM
12/28/08 11:52 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
#1. Not all plastics have the same chemical resistance, in fact nearly every type varies in that area, VAST differences between them. I.E. you can pour gasoline from a plastic jug (Polyethylene) right into a plastic cup (Styrene) and watch the gas melt it's way right through and drain onto your foot!
#2. Your model was likely Styrene (one base ingrediant in ABS Grilles, The "S" stands for Styrene) it's likey you simply didn't leave it on long enough to do any damage, or that the models plastic had other modifiers in it's blend to help prevent some types of chemical attacks.
#3. Don't want free advice? Don't take it, live and learn with your oven cleaner
Re: Stripping paint from plastic parts - 70 cuda grille [Re: ScottSmith_Harms] #176543
12/28/08 12:05 PM
12/28/08 12:05 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i have had good luck stripping plastic grilles with a hand held sandblaster. use LOW air pressure and work carefully, don't stay in one place long and keep it moving. it use the gravity feed one you can buy at harbour freight for under $20. yes it will rough up the plastic but so will a chemical stripper so you have to sand it smooth anyway. remove 80% of the paint and sand the rest off.
perception is 90% of reality
Re: Stripping paint from plastic parts - 70 cuda grille [Re: ScottSmith_Harms] #176544
12/28/08 12:12 PM
12/28/08 12:12 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Maybee your right on the chemical resistance because I had the oven cleaner on for 4-5 days.
Re: Stripping paint from plastic parts - 70 cuda grille [Re: RV2] #176545
12/28/08 12:20 PM
12/28/08 12:20 PM
Millersville, PA
HemiChallenger Offline
Millersville, PA
hand sanding is your best bet. Not the funnest nor the fastest but your in total control of whats going on. I would say start with some 80 once you hit that second layer of paint go to 180 then once you hit the factory coating switch or 220. 220 should be good enough for a smooth finish.
Steve
Re: Stripping paint from plastic parts - 70 cuda grille [Re: RV2] #176546
12/28/08 12:28 PM
12/28/08 12:28 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I agree totally, I've used easy off and brake fluids on model cars both vintage and newer with excellant results. Thats why I used the easy off on a spare grille,,,,,, never again.
Fortunately I had a spare grill to do the hand sanding thing, my wrists hurt for weeks and that was 10 years ago. If I had to do it agian, I'd try the glass bead under light pressure
Re: Stripping paint from plastic parts - 70 cuda grille [Re: gtx6970] #176547
12/28/08 04:41 PM
12/28/08 04:41 PM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
...Could a plastic media be used to strip the paint ????
Re: Stripping paint from plastic parts - 70 cuda grille [Re: screamindriver] #176548
12/28/08 04:53 PM
12/28/08 04:53 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
INE soda blasting causes the least amount of damage to most hard plastics, however, it's usually too powerful to use on small pieces.
Re: Stripping paint from plastic parts - 70 cuda grille [Re: ScottSmith_Harms] #176549
12/28/08 06:52 PM
12/28/08 06:52 PM
Mr T2U Offline
Mr T2U  Offline
i use fine silica sand. put a mini air DIAPHRAM REGULATOR on the air line powering the GRAVITY sandblaster. NOT one of those screw air restriction valves.
start out with LOW, 5psi, air pressure and work up from there. use your head and think when blasting. support the thinner areas with paint sticks taped behind some of the thin spots, the thin grille lines.
if you keep the air pressure down and work SLOWLY the damage caused by it will be minimal.
i have never done a 70 grille. i have stripped 4 71 grilles this way with good results.
Re: Stripping paint from plastic parts - 70 cuda grille [Re: ScottSmith_Harms] #176550
12/28/08 11:42 PM
12/28/08 11:42 PM
i've done 2 challenger grilles and 2 challenger header panels with it and have i have had no problems with it ,it isn't nearly as strong as regular stripper so if there is more then one layer of paint on it will take a bit of work to get it all off.
if not that,then start sanding..
Re: Stripping paint from plastic parts - 70 cuda grille #176551
12/28/08 11:47 PM
12/28/08 11:47 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
My comment to always test it is not due to doubt in your case, it's due to the possible variable in chemical content from one brand to the next.
Re: Stripping paint from plastic parts - 70 cuda grille [Re: ScottSmith_Harms] #176552
12/30/08 10:37 PM
12/30/08 10:37 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Has anybody ever tried bead blasting plastic? I have some interior ebody door panels that I have considered trying this on....I don't want to ruin the texture of the panels though.
Re: Stripping paint from plastic parts - 70 cuda grille [Re: Quicksilver440] #176553
12/31/08 08:12 PM
12/31/08 08:12 PM
Alberta, Canada
4004spd Offline
4004spd  Offline
Alberta, Canada
Beadblasting worked good for me, went from dry and chalky to soft and smooth!
Re: Stripping paint from plastic parts - 70 cuda grille [Re: 4004spd] #176554
12/31/08 08:13 PM
12/31/08 08:13 PM
Alberta, Canada
4004spd Offline
4004spd  Offline
Alberta, Canada
After pic:
