Header Paint? #1765464
02/28/15 08:22 PM
02/28/15 08:22 PM
N.Y.
sixpacksteve Offline OP
N.Y.
just got brand new hedman huslers. Whats best paint? don't want to ceramic coat them!
Hell Hath No Fury Like Mine
Re: Header Paint? [Re: sixpacksteve] #1765465
02/28/15 10:24 PM
02/28/15 10:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Find the highest temp BBQ paint you can.. I like
Rustoleoum BBQ paint.. doesnt gray out like some of
the cheaper paints
Re: Header Paint? [Re: MR_P_BODY] #1765466
02/28/15 10:50 PM
02/28/15 10:50 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
i've had good luck with BBQ paint also. Steel wool or scotch brite them good and clean with lacquer thinner helps too
Re: Header Paint? [Re: MR_P_BODY] #1765467
03/01/15 12:01 AM
03/01/15 12:01 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Rustoleum BBQ paint on mine, easy to touch up if needed.
Re: Header Paint? [Re: ProSport] #1765468
03/01/15 12:17 AM
03/01/15 12:17 AM
Lowes
steve660 Offline
steve660  Offline
Lowes
Would the BBQ paint work on bare headers? Im lookin at getting some TTI's and would rather have the uncoated ones and use the Hi Temp BBQ paint. That way if they get scratched or gouged (they will) they can be touched up.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Header Paint? [Re: steve660] #1765469
03/01/15 03:06 AM
03/01/15 03:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes it will... clean the steel with thinner then give
them a few coats
Re: Header Paint? [Re: sixpacksteve] #1765470
03/01/15 03:20 AM
03/01/15 03:20 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
VHT has ceramic header paint out there...
Re: Header Paint? [Re: RSNOMO] #1765471
03/01/15 04:00 AM
03/01/15 04:00 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Re: Header Paint? [Re: MR_P_BODY] #1765472
03/01/15 05:40 AM
03/01/15 05:40 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
What about the rustoleum high temp paint? It's good for 2000°.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Header Paint? [Re: DemonDust] #1765473
03/01/15 12:03 PM
03/01/15 12:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its good stuff I like it
Re: Header Paint? [Re: steve660] #1765474
03/01/15 12:10 PM
03/01/15 12:10 PM
Q
Quicktree Offline
Quicktree  Offline
Q
they will last a lot longer if get the coated ones...
Re: Header Paint? [Re: MR_P_BODY] #1765475
03/02/15 02:22 PM
03/02/15 02:22 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
the cheaper paints
BBQ Black here also
